POV-Ray : Newsgroups : povray.binaries.images : StarGate Server Time
11 Aug 2025 12:37:44 EDT (-0400)
  StarGate (Message 1 to 10 of 32)
Subject: StarGate
Date: 22 Jun 2008 19:20:01
Message: <web.485edd4adf4b5892b6e5c2470@news.povray.org>
http://blenderartists.org/forum/archive/index.php/t-103776.html
Freekin 30 meg StarGate.blend file. Doh.
Spent like 10 minutes trying write a Wavefront file with Blender,
gave up at around a 150meg obj file thinking I could make my own in less time!
http://en.wikipedia.org/wiki/Stargate_%28device%29
http://en.wikipedia.org/wiki/Image:Milky_way_stargate_with_very_detailed_glyphs2.svg
Any skilled ideas out there?
Something more like this, only not 30 or 150 megabytes:
http://en.wikipedia.org/wiki/Image:SG1stargate.jpg
or even like this:
http://www.stephenmeli.net/images/irisopen.jpg
Just to inflict interest, here a poor man's attempt:
Needs so much work. Like building a model, argh. Crude bumped disk so far.
Download 'stargate2.png' (360 KB)
Preview of image 'stargate2.png'
Subject: Re: StarGate
Date: 22 Jun 2008 20:10:01
Message: <web.485ee888cd5f2f2fb6e5c2470@news.povray.org>
wondering about a 3d-disc or cave-man wheel, a torus with right angles. how does
that get made? probably several ways, but the skilled way...
make it in parts for animation. add stationary bumped rings, certainly not
megabytes. Materials would be everything, ganite perhaps.
back to the drawing board as it were.
oh, who can make that lit up water effect in Stephen's version? way cool
Date: 22 Jun 2008 20:20:28
Message: <485eec4c$1@news.povray.org>
I've watched the show enough to know the stargate consists of 6 parts,
The outer ring, the inner ring, the chevrons, the top lights, the side
lights,
and the water fountain effect in the middle.
The outer ring is just a cylinder ring with some gear-like crenellations
around the inside lip. It's mostly textured with a stone-like normal,
and a smooth spot where the locks might engage.
The inner ring has all the interesting glyphs (39?), I think you could
save those out as heightfield images, it's probably most of the detail
of the stargate. There's some ribs between the glyphs, more
crenellation on a lip, and a tapered inner edge.
The chevrons are the same shape all the way around the ring,
they're T shaped, following the same curve as the disk, the
V shaped part has grating for lights (there is an inner solid
lip unlike the model you linked to, and I think there's more than
six slots for light). The chevrons move in and out to lock the
gate in position.
The top lights are brighter, along with it's 4 chevron lights,
which shine thru the chevron grates. The light frame is
mostly translucent, and doesn't move.
The side lights are dimmer, I think they might only have
2 side lights shining through the chevron grates as well.
The bottom lights are the same as the side lights,
you just never see them usually, in Stargate: Atlantis you
see them in space sometimes.
The center effect probably could be done with something
like Rune's particle system.
http://runevision.com/3d/include/particles/
Date: 22 Jun 2008 22:45:00
Message: <web.485f0cdacd5f2f2fb6e5c2470@news.povray.org>
> lights,
> gate in position.
Whoa! The long version. heh.
AS I see it the milky way portal has 9 Chevrons, 7 of which are used for a
7-symbol address. Actually this design could only have come from "myth leakage"
the reality of horizontal "Mills" or concentric circles that aligned symbols on
them, powered by the vortex created by nature spirits co-mingling from above
and below ... oops there i go again speaking truth unrecognizable to current
mortals.
I can handle assembly, clearly the challenge is in creating theses shapes to
assemble. You mention cylinder and I think need only give cylinder thickness.
cave-man wheel should be a primative, either a square torus or thick cylinder.
The sum of shapes and materials = what one has the ability to create.
Date: 23 Jun 2008 00:30:01
Message: <web.485f2622cd5f2f2fb6e5c2470@news.povray.org>
Sorry, left ya hangin' on that last one didn't I.
Might be interesting to see the faces that read this, some with a gleam in their
eye, some with a blank stare.
If you imagined it correctly, you have seen not a doughnut with a hole in the
middle, but a solid disc with symbols upon which the Elder stood. The outer
"doughnuts" rotate and align to point the way, "that way". Rarely reaching the
edge and poof he was gone.
Responsibility managed the destruction of 13 of the "Mills" because
inexperienced ones ended up places in which they could not afford or even be
aware. There were 14 but only 13 were known.
Date: 23 Jun 2008 12:00:01
Message: <web.485fc7f6cd5f2f2f86ff1d480@news.povray.org>
That Blender mesh purportedly weighs in at around a billion polygons, yikes!
Well, after seeing the render of the Blender model at
http://blenderartists.org/forum/showthread.php?t=103776 I'm inspired to try
making one too... I'm thinking a lot of CSG and some heightfields should do it
for the most part, along with a few detail pieces modeled in Wings3d. I see
lots of greebling around the discs too, hmmm.
Looks like fun :)
-Rob
Date: 23 Jun 2008 13:15:00
Message: <web.485fd973cd5f2f2fdb57da4b0@news.povray.org>
> Looks like fun :)
> -Rob
CSG was term I was looking for. POV can do it on its own, with the right author
I thought. Can't wait, presuming I might learn a thing or two. aQ
Date: 23 Jun 2008 14:26:47
Message: <485feae7$1@news.povray.org>
"Tim Attwood" <tim### [at] comcastnet> wrote in message
news:485eec4c$1@news.povray.org...
>> far.
Sounds like a perfect collaborative project for the object collection.
I reckon I can do the Glyphs for the Milky Way stargate pretty quickly
because there's an SVG by Max Willis on the Wiki, so I can convert them into
prism objects using Inkscape and cut them out of the inner disk using CSG.
So does the inner ring have a wedge shaped cross-section?
Chris B.
Date: 23 Jun 2008 16:02:23
Message: <4860014f@news.povray.org>
You could always try my HFArch include file at lib.povray.org. It's very
flexible for doing these kinds of things. I haven't thoroughly tested it
with the POV-Beta, but I know that the first example won't render
without a change in the minor radius of the arch. It works perfectly
with the official version.
http://lib.povray.org/collection/hfarch/sam%201.0/stbhfarch.jpg
http://lib.povray.org/collection/hfarch/sam%201.0/stbhfarch.html
Sam
Date: 23 Jun 2008 20:11:10
Message: <48603b9e@news.povray.org>
"Chris B" <nom### [at] nomailcom> wrote in message
news:485feae7$1@news.povray.org...
>>> far.
> into
I've posted the 39 Glyphs as prism objects on povray.binaries.scene-files
along with this very crude scene file that cuts them out of segments of a
ring and assembles the segments into a circle. If anyone wants to use them
to make a stargate I'd be happy to go through and scale and centre them as
needed.
Chris B.
Download 'Stargate.JPG' (20 KB)
Preview of image 'Stargate.JPG'
