POV-Ray : Newsgroups : povray.binaries.images : The Tower (2) Server Time
30 Mar 2026 04:22:35 EDT (-0400)
  The Tower (2) (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: The Tower (2)
Date: 19 Feb 2008 18:53:14
Message: <47bb6bea@news.povray.org>
Kirk Andrews wrote:
> Some improvements.  Still can't find my pegasus to get there, though...
> (clouds were added in post-processing, of course.  I'm not patient enough for
> media.)
Beautiful.
My one suggestion, the water texture is stopping me.  I feel that with
that kind of almost still ripple there would be more variety, as if gust
s ripple some place and still in others.  Just seems a little too
regualr for that type of chop.  Maybe try throwing in a couple of
blackhole warps to vary things a bit?
Date: 19 Feb 2008 19:14:21
Message: <47bb70dd$1@news.povray.org>
I think what the water *really* needs is variable reflection.
(Just in case anyone doesn't know what I'm talking about:
http://www.povray.org/documentation/view/3.6.1/348/ )
That much should be only one or two extra lines of code. :-)
William Tracy
Date: 19 Feb 2008 20:00:01
Message: <web.47bb7b0f169c0233af0d79570@news.povray.org>
> William Tracy
> afi### [at] gmailcom -- wtr### [at] calpolyedu
Well, it did have variable reflection, but then of course the clouds were added
in post processing, and so was the reflection of the clouds, which messed it
all up, no doubt.  What I'll have to do is actually add the clouds into the
scene as an image map in the distance, and then the water will reflect it
properly.
The black hole warps are a good idea also--you're right, water is always smooth
in some places and rougher in others.
Thanks for the suggestions. I'll be putting more work into it...eventually.
Unfortunately, for now I have some catching up to do in other, less interesting
subjects.
Date: 19 Feb 2008 21:29:03
Message: <47bb906f@news.povray.org>
> properly.
Or real clouds instead of a picture of them :)
> subjects.
Work? Bah that always annoying...
Date: 19 Feb 2008 23:45:01
Message: <web.47bbb027169c0233af0d79570@news.povray.org>
<begin soapbox>
There have been many admirable efforts to get good-looking clouds purely through
media, and a few have been quite successful.  But even if I skipped all the
testing and retesting (...and retesting...and retesting...and retesting...) and
just cut and pasted their code, there's no guarantee that the clouds would look
even half-decent in my scene, with a different scale, different light and
radiosity settings, etc.  Even the very best media-cloud results don't look as
good as actual pictures of clouds, although they do have the distinct advantage
of actual 3D placement within your scene and interaction with your light
sources.
By using real pictures, however, I can easily choose clouds that look precisely
like I want without waiting hours for it to render (and make adjustments and
render again, and again, and again) so I can see if it even looks like I want.
So, very often, unless you need a cloud to serve a very particular purpose in
your scene, image-clouds can usually provide just as good or even better
results with much less frustration and time.  I therefore argue that POVers
should not be ashamed or afraid to use simple pictures for their skies.  :)
</end soapbox>
....well, I write all that, and now I am feeling tempted to try those blasted
media-clouds again...
Date: 20 Feb 2008 01:00:20
Message: <47bbc1f4$1@news.povray.org>
Well, if render times are the only issue, you might want to play with this:
http://runevision.com/3d/povgoodies/
I could have sworn that there used to be some macro called "FastCloud"
floating around. In fact, I remember it filling up my search results to
the point that I had to hunt to find anything else. Now I can't find it
at all. Am I going nuts?
William Tracy
One major known problem with supporting V-class is the complexity of its
PCI bus adapter (EPIC and SAGA). Support for the V-class isn't going to
happen until some really masochistic person who has access to a V-class
is, uh, challenged by this.
     -- from the Linux-on-HPPA FAQ
Date: 20 Feb 2008 03:23:36
Message: <47bbe388$1@news.povray.org>
"William Tracy" <wtr### [at] calpolyedu> schreef in bericht
news:47bbc1f4$1@news.povray.org...
> this:
> the point that I had to hunt to find anything else. Now I can't find it at
No. Not nuts. There is the FastClouds macro by Zeger Knaepen which I use
very often and gives really excellent results. I know Zeger posted the code
some time in the past but I am unable to find that post again.
Date: 20 Feb 2008 05:55:36
Message: <47bc0728$1@news.povray.org>
High!
Sven Littkowski schrieb:
> Do maybe a tiny platform on the left hill, just big enough for a single
> little bank to hold 2 persons.
Oh yes, a tiny little bank office, so small that two customers barely
can squeeze themselves in front of the automatic counters...
...you surely meant "bench", didn't you?
See you in Khyberspace!
Yadgar
Now playing: Traumboy (Frl. Menke) - New German Wave rules!
Date: 20 Feb 2008 08:58:37
Message: <47bc320d$1@news.povray.org>
"Thomas de Groot" <t.d### [at] internlDOTnet> wrote in message
news:47bbe388$1@news.povray.org...
>> this:
>> at
> code
yes, I should put it on my website actually :)
but for now: see attachment.  And here's a demo-scene:
--BEGIN CODE--
#include "fastclouds.inc"
fastclouds(<750,600,-500>*1000,.455,.1,0,10,.05,0,<1.5,1.3,1.1>,1)
fog {
  fog_type 2
  distance 75
  color rgb <213,205,194>/255 //<.6,.7,1>
  transmit 0
  fog_offset -1
  fog_alt 2
sky_sphere {
  planar
  color_map {
   [0 rgb <22,44,68>/255]
   [.5 rgb <88,120,179>/255]
   [1 rgb <213,205,194>/255]
--END CODE--
These are the macro-arguments:
1. Sun Location
2. cloud 'Cast' (0=no clouds, 1=fully clouded sky, can be >1)
3. 'Fluffyness', controls the sharpness (or lack thereof) of the clouds
4. Translate-vector for the cloud-pattern
5. Size of the cloud-skysphere (*500)
6. Size of the cloud-pattern
7. Minimum transparency, or: the main-transparency of the clouds (could be
seen as the cloud-thickness)
8. Color of the Sun
9. Color of the clouds
also, you can provide your own cloud-pattern by #declare'ing CloudForm
(which should be a pigment)
cu!
Download 'fastclouds.inc.txt' (2 KB)
Date: 20 Feb 2008 11:55:01
Message: <web.47bc5a5b169c0233b555cae70@news.povray.org>
> To me, this residence(?) looks unused now, as though it was abandoned in a
> hurry as it's now slightly overgrown around it. The tower doesn't look
> damaged in any way, i.e., through war, or bad workmanship - on the contrary,
> this place was built to the highest of standards, which, (in all
> likelihood), meant that it was built for a King, or moreover, a Prince, as a
> King would have two or more towers.
>   However, I think it needs 'more' trees around the tower and spreading up
> that hill to the right of it. It would also be nice if that tower had some
> ivy thrown around near the base, although, scale-wise, you may need quite a
> bit, which might produce a long render time. Worth a play though. :)
>    http://graphics.uni-konstanz.de/~luft/ivy_generator/
>      Beautiful scene.
>        ~Steve~
Thanks.
Good idea:  I had downloaded the ivy generator before on my old computer, but
not yet on my new one.  I'll be sure to add some ivy next time I render.
