POV-Ray : Newsgroups : povray.binaries.images : Wireframe mobius thingy Server Time
20 Dec 2025 01:46:45 EST (-0500)
  Wireframe mobius thingy (Message 1 to 10 of 11)
Subject: Wireframe mobius thingy
Date: 12 Jul 2007 23:45:02
Message: <web.4696f4d539134c4082ce9eee0@news.povray.org>
I'm getting back into POV after my standard 6 month hiatus and here is my
first attempt.
I need some advice on lighting. I seem to have trouble getting the floor to
stay lit enough without resorting to using a shadowless white fill light. I
feel like I am doing something wrong. Any advice on light setups?
Also, I tried rendering at 1200x1200 and scaling in GIMP to 600x600, but I
still can't get the image to look non-jaggie. Any pointers on decent aa
techniques?
Comments and criticisms are appreciated as well. Thanks.
Download 'topmod1.jpg' (116 KB)
Preview of image 'topmod1.jpg'
Subject: Re: Wireframe mobius thingy
Date: 13 Jul 2007 13:29:12
Message: <4697b667@news.povray.org>
> first attempt.
> to stay lit enough without resorting to using a shadowless white fill
> light. I feel like I am doing something wrong. Any advice on light setups?
> techniques?
Nice - looks very mobiussy... :)
Stefan
Date: 13 Jul 2007 19:10:01
Message: <web.469805ce5c02c98cc4d0cd760@news.povray.org>
> first attempt.
> techniques?
Nice image,especially given a 6 month break. If I ever stop and come back
after even a short time I always have to create some really poor images
before getting something worthwhile out.
Out of interest how did you go about making the weaved bits in between the
supporting frame.
~Malcolm
Date: 13 Jul 2007 23:05:02
Message: <web.46983c4e5c02c98cd3935bce0@news.povray.org>
> first attempt.
What's the diffuse value on the plane? That would be my first guess at the
problem.
Sam Bleckley
http://www.meetsoup.com/
Date: 14 Jul 2007 06:45:01
Message: <web.4698a8c65c02c98cb2983be70@news.povray.org>
> techniques?
Nice pic and nice concept, but it doesn't look like a mobius strip to me. If
I follow one of the rows with the eye/finger/pen, after a complete turn I
end up exactly at the starting point. A mobius strip would make me reach
the other "face" after a complete turn.
Concerning AA, I assume you already tried rendering with +aa0.0 +am2? If
rendering at a higher resolution doesn't solve the problem you could apply
a little blur in the Gimp. Press V, make sure blur is selected, select an
opacity of at most 50%, and paint on the most jagged areas. If you want to
apply it on a straight line, press shift and you'll see a visor linking the
last clicked pixel to the current mouse position.
Date: 14 Jul 2007 11:55:01
Message: <web.4698f1725c02c98c82ce9eee0@news.povray.org>
Thanks.
> supporting frame.
I created the object in TopMod ->
http://www-viz.tamu.edu/faculty/ergun/research/topology/
It has a bit of a learning curve, but you can make some really neat stuff
with it.
Date: 14 Jul 2007 11:55:02
Message: <web.4698f1aa5c02c98c82ce9eee0@news.povray.org>
> problem.
plane {
   y, 0
   pigment {color White}
Yep...rather boring, that.
Date: 14 Jul 2007 12:00:02
Message: <web.4698f2415c02c98c82ce9eee0@news.povray.org>
You are absolutely correct. I just had no idea what else to call it.
Wirefram Rotating Thingy I guess :)
I actually did not use the built in aa as I remember reading several posts
regarding the technique of rendering a picture at 2x size and then
downsizing it in GIMP or PS and getting better results. I am not really
getting anywhere with my attempts so I will a) try your suggestion
regarding blur in GIMP, and b) rendering with aa in POV again.
Date: 16 Jul 2007 03:45:01
Message: <web.469b21975c02c98cd79c3b620@news.povray.org>
Actually the technique of doubling the size will work best if you already
have some antialiasing in, so you should use some aa (or focal blur
considering you have a simple plane/background). It's quite unlikely to get
better results with  a bigger render that uses no aa, unless you blow the
render up to some absurd resolution which would inevitably slow the render
to a crawl.
Date: 16 Jul 2007 13:22:16
Message: <469ba948$1@news.povray.org>
Hash: SHA1
> first attempt.
	Try moving your light source back and/or playing with brilliance on
the plane.
> techniques?
	+A0.1 +AM2 +R3 (in fact, for your picture +R2 might be enough). Do
not use +A0.0 as it will slow the render down for no real gain
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
iD8DBQFGm6lZd0kWM4JG3k8RAu4zAJ97iO52qT8c2MKZgbNbIkkq1S/s6ACfYs0d
h7kxQj4dmkctHeMtn3YuH0Q=
=u+HR
-----END PGP SIGNATURE-----
