POV-Ray : Newsgroups : povray.binaries.images : indoor lighting (radiosity) Server Time
2 Apr 2026 02:48:31 EDT (-0400)
  indoor lighting (radiosity) (Message 11 to 16 of 16)
Subject: Re: indoor lighting (radiosity)
Date: 25 Oct 2006 12:03:00
Message: <453f8ab4$1@news.povray.org>
Tim Nikias wrote:
>> I think that this image...
>> http://www.nolights.de/stills/gallery/images/prep4company.jpg
>> ..... is very beautiful and lighting is very realistic, I would like to see
>> the source pov code of this image in order to have an idea of what was
>> wrong in my image, comparing the materials, lights, radiosity,...
> Sure, I'm at the university right now, but when I get back home, I'll see
> what I can do. The chair and sofa are big meshes though, so I guess I'd
> have to take those out of the scene-file and replace them with something
> simpler (low-res, probably), but you'll get the materials and lighting.
I've just uploaded the ZIP with a slightly stripped down version of the
meshes and textures to povray.binaries.scene-files. Feel free to explore
and experiment with the settings. :-)
Tim
aka "Tim Nikias"
Date: 25 Oct 2006 12:05:01
Message: <web.453f8a843cae5eb8d8ef73430@news.povray.org>
This image has take too long to render because of the high resolution, I
tried to improve the definition of the objects and antialias, at the same
time, I try to add bright to the scene changing the key light with
<1,1,1>*3 and sky sphere <1,1,1>.
But, in order to reduce render time I changed the count to 300, and this has
produced blotchy surfaces.
The question is: It's possible to solve this problem without a count higher
than 300 (to don't increase render time)? Changing the rest of the
parameters of radiosity? (rest are default values in this image)
Thks,
JSR
Download 'indoor.jpg' (323 KB)
Preview of image 'indoor.jpg'
Date: 25 Oct 2006 14:00:01
Message: <web.453fa5d93cae5eb843a5e2560@news.povray.org>
Reduce pretrace_end to 0.01 or 0.005.  That tends to mitigate the
splotchiness caused by the low error_bound.
Date: 25 Oct 2006 17:41:18
Message: <453fd9fe@news.povray.org>
"JSR" <jsr### [at] gmailcom> wrote in message
news:web.453f8a843cae5eb8d8ef73430@news.povray.org...
> Hi,
has
higher
> Thks,
> JSR
just another quick thought. a room painted grey will always look gray, no
matter how nice the sunlight is coming in. find some nice paint samples and
borrow their colors :)
the room does look brighter now, anyway.
Date: 25 Oct 2006 20:12:38
Message: <453ffd76$1@news.povray.org>
JSR nous apporta ses lumieres en ce 25/10/2006 12:02:
> Hi,
> Thks,
> JSR
A low error_bound needs a high count to prevent blotchness. Try to increase
error_bound, maybe as high as 1. This will also decrease the render time.
You can compensate by using a smaller low_error_factor to get more sampling
during the last pretrace step. Also, adding 1 or pretrace steps can help.
Increasing nearest_count up to 20 (the maximum) can also help by averaging more
value to get the final illumination.
WARNING: The consumption of alcohol is a major factor in dancing like a retard.
Date: 26 Oct 2006 23:25:01
Message: <web.45417b5d3cae5eb8e49df0140@news.povray.org>
> Hello,
> I'm new to this newsgroup. I'm very interested in learning indoor lighting
> and rendering using lights and radiosity. I have been working with POV for
> a long, but I can't render images with impressive lighting like these:
> http://www.pacificommultimedia.com/architecture.html
> http://www.artvps.com/gallery/1/architecture.htm
> At the moment, the best image I rendered is this. I think that it is not
> very bad, but seems a little dark. If the brightness parameter is
> incremented then the image is burn.
> Suggestions are well received.
> Thanks,
> jsr.
Nice room!  One thing I noticed... the shadows are only possible with a
single point of light.  But a window is not a single point.  Rendering the
shadows correctly is very difficult (difficult on the computer).
