POV-Ray : Newsgroups : povray.binaries.images : A puzzle Server Time
13 Mar 2026 05:53:07 EDT (-0400)
  A puzzle (Message 11 to 19 of 19)
Subject: Re: A puzzle
Date: 7 Aug 2006 16:05:00
Message: <web.44d79c18ced82d47d1a114be0@news.povray.org>
Sorry...sorry...it is, indeed, an infinite plane.  The shape was constructed
without any mathematical formulas, only shapes associated with each other
through Boolean algorithms (intersection, difference, union, etc.).  Hope
this clears things up a bit; any other guesses?
Date: 7 Aug 2006 16:16:06
Message: <zy7wsb2u7kh.dlg@news.nobbz.de>
Am Mon, 07 Aug 2006 13:52:26 -0600 schrieb Jim Henderson:
> I guess it's not really clear from the top post in the thread - I am
> pretty sure, though, that planes within POV aren't counted as finite
> objects, and assume that the walls are planes as well.
> Jim
Depending on that what the OP said I assume boxes there. And yes, planes
are INfinites, thats why I said two times that the OP has an typo in his
statistics.
But now, when I write about boxes... I have an idea:
The room is a box, and we are within it. So would remaining 5 finite
Objects for "Thingy" [1] In this case I would suggest one sphere-object,
but dunno what is substracted from it...
OP! Please give us a hint, and if it is only 'bout the counting of your
objects...
[1] I used this term so often today, slowly it comes to my mind to call
    my next cat like this :-)
Date: 7 Aug 2006 17:45:00
Message: <web.44d7b3cbced82d47d1a114be0@news.povray.org>
> statistics.
> objects...
Fine, fine, fine, a hint.  As before, the only boxes are those that form the
"walls" of the little room containing the object of mystery.  The object
itself is composed of three identical objects and a sphere, related through
an intersection.  All that's left now is the identity of the original
objects; any guesses?  Another hint: without the sphere involved, the
thingy would have pointy corners.
-Scowdich
Date: 7 Aug 2006 20:33:10
Message: <44d7dbc6$1@news.povray.org>
Norbert Melzer wrote:
> I hope we can solve this puzzle earlier or later (is there some phrase
The English phrase is:  sooner or later.
And it's a very commonly used expression.     :-)
      -=- Larry -=-
Date: 7 Aug 2006 20:47:19
Message: <pan.2006.08.08.00.47.16.562553@nospam.com>
On Mon, 07 Aug 2006 22:13:36 +0200, Norbert Melzer wrote:
> The room is a box,
That could well be it, didn't think of that one, and I often render inside
a box. <G>
Jim
Date: 7 Aug 2006 22:07:57
Message: <44d7f1fd@news.povray.org>
Intersection of a sphere and three perpendicular toruses?
Mark
Date: 8 Aug 2006 00:15:00
Message: <web.44d80f1cced82d47d1a114be0@news.povray.org>
> Mark
Wow!  Congratulations!  It is, indeed, three perpendicular tori, aligned
along perpendicular axes, with a ratio of major axis:minor axis of 5:4.  I
recently figured out how to hollow it, not by scaling the whole object and
constructing a difference (there would be trouble with the hole at the
middle), but by scaling the minor axis before intersecting the three tori.
It's rendering now; I hope it turns out all right, as there might be a
problem with the max trace level.  I'm pleasantly surprised that this
constructin generated so much interest; I might have to elaborate on it or
make more.  Thanks for joining in, everyone.  By the way...this was my
first construction in POV-Ray.  Any suggestions?
Date: 8 Aug 2006 00:20:01
Message: <web.44d80fc3ced82d472f8f336f0@news.povray.org>
> Mark
I couldn't get that to work, but cones (-1 to 1) produces something close.
However, there are no holes in the middle.
Mike
Download 'test.png' (106 KB)
Preview of image 'test.png'
Date: 8 Aug 2006 04:20:01
Message: <web.44d84796ced82d47d1a114be0@news.povray.org>
> Mike
Mike-
The three tori should work, as long as the minor radius is almost as large
as the major.  It would, however, be possible to create a central hole with
your cones: extend each cone so it intrudes into the cone opposite it; then,
differencing them all from the main sphere would produce the desired result.
To everyone:
Here's my original product, with some modifications.
-Hollowed out by differencing a version which uses slightly smaller minor
axes.
-Filled halfway with "water" - glass modified with an IOR of 1.33, equal to
that of water.
-Rendered for about 6 hours, rather than 15 minutes.
Unfortunately, I suffer the dread disease known as "Have to watch the huge
image render-itis".
Any suggestions for improvements?
Perhaps I'll make a Klein bottle and fill the universe with a quart of
water, or just fill the bottle with an infinite volume of water.  Heh.
-Scowdich
Download 'hollow torus1.jpg' (649 KB)
Preview of image 'hollow torus1.jpg'
