POV-Ray : Newsgroups : povray.binaries.images : electron microscope-like effect (152 k) Server Time
1 Apr 2026 17:20:32 EDT (-0400)
  electron microscope-like effect (152 k) (Message 4 to 13 of 23)
<<< Previous 3 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: electron microscope-like effect (152 k)
Date: 1 Aug 2005 18:25:01
Message: <web.42eea070badb99648072d1170@news.povray.org>
"HenryW" <pov### [at] henrywagnerorg> wrote:
> Wild!
> What kind of texture are you using?
#local Surface = texture {
 pigment { color rgb <0.804, 0.82, 0.85> }
 normal { agate scale 0.1 }
 finish { ambient 0 diffuse 1 }
It's the normal that gives the effect. The main spheres on the objects have
a radius of 1.0.
H
Date: 1 Aug 2005 18:40:00
Message: <web.42eea497badb99644daddc090@news.povray.org>
Very nodulistic!
It looks like you could achieve the same effect with no lights & an ambient
AOI pattern...
Mark.
Date: 1 Aug 2005 19:45:00
Message: <web.42eeb2febadb99648072d1170@news.povray.org>
"Mark Birch" <las### [at] hotmailcom> wrote:
> Very nodulistic!
> AOI pattern...
> Mark.
Explain please.
H
Date: 1 Aug 2005 20:01:14
Message: <42eeb7ca@news.povray.org>
"helge_h" <nomail@nomail> schreef in bericht
news:web.42eeb2febadb99648072d1170@news.povray.org...
> > Very nodulistic!
ambient
> > AOI pattern...
> > Mark.
> Explain please.
I was going to suggest the same thing Mark did.
you need no light, you only need a texture like this one:
        aoi
        color_map {[0 rgb 0][.5 rgb <0.804, 0.82, 0.85>]}
    finish { ambient 1 diffuse 0 }
You need MegaPov for the aoi-pattern though.
cu!
ZK AKA Gaeriel
http://www.povplace.com
"Begin the unnecessarily slow-moving dipping mechanism!"
Date: 1 Aug 2005 20:14:14
Message: <42eebad6$1@news.povray.org>
Creative usage of shadowless lights. Makes me think of nanobots.
I went looking for intersecting parts in there, because I knew if you didn't
use collision avoidance that I'd see a lot of that, and was about to think
there weren't any such places; then happened to notice the center. Just a
little to the left of exact center. I was looking around the sides and into
the background first.
Anyway, it's a very eye-catching image!
Subject: The Dark Side
Date: 2 Aug 2005 08:38:27
Message: <42ef6943@news.povray.org>
A different approach :
Only one point_light with a negative color at camera position, and an
ambient texture.
   location  <0.0, 0, -10.0>
   direction 1.5*z
   look_at   <0.0, 0.0,  0.0>
light_source {
   <0, 0, -15> // same as cam, to eliminate the side/parallax effect
   color rgb -2 // megative value for dark side, greater than 1 for good
contrast ;)
   shadowless
// the excellent texture, slightly modified
  finish { ambient 2 diffuse 1 }  // ambient greater than 1 for good
contrast
Download 'electronic.jpg' (76 KB)
Preview of image 'electronic.jpg'
Date: 2 Aug 2005 08:44:09
Message: <42ef6a99$1@news.povray.org>
Great !!!!!
Dark Skull Software
http://www.darkskull.net
A+
Date: 2 Aug 2005 12:00:00
Message: <web.42ef9755badb99648072d1170@news.povray.org>
Hey, this caused quite a lot of response, thanks for the interest.
MegaPov requires Windows, I believe; I'm on a Mac. But it would be nice to
see an example.
I saw it, but let's leave them alone; they're probably making more nanobots.
Thanks!
> zorglub:
Very nice! I had a similar idea, but I thought of using a positive light and
then inverting the image afterwards in Photoshop Elements. It didn't work
so well, so I abandoned it. But yours looks great!
H
Date: 2 Aug 2005 12:55:01
Message: <web.42efa455badb99647196f5900@news.povray.org>
> see an example.
http://users.skynet.be/smellenbergh/
(MacMegaPov -- I use it all the time, since my souped-up G3 has problems
with the official Mac compile of POVRay.  I "souped" it myself; that's most
likely the problem.)
Dave Matthews
Date: 2 Aug 2005 13:10:01
Message: <web.42efa87abadb99647fd377250@news.povray.org>
You can use slope to, and no lights:
camera{location -z*10 look_at 0}
#local TEX = texture{
  pigment{slope{<0,0,-10>} //the vector should be your camera position
    pigment_map{
    [0.25 rgb 1 transmit 0.5]
    [0.75 rgb 0 transmit 0.5]
  normal{agate scale 0.2}
  finish{ambient 1 diffuse 0} //the ambient controls the brightness
sphere{0,1 texture{TEX}}
Wagner
Download 'tempor.png' (21 KB)
Preview of image 'tempor.png'
