POV-Ray : Newsgroups : povray.binaries.images : Visibility pattern test - visibility.JPG (1/1) Server Time
21 Mar 2026 17:44:30 EDT (-0400)
  Visibility pattern test - visibility.JPG (1/1) (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: Visibility pattern test - visibility.JPG (1/1)
Date: 6 Feb 2000 15:43:25
Message: <chrishuff_99-37C450.15442106022000@news.povray.org>
In article <389DDADB.5AB04519@ibm.net>, cli### [at] ibmnet wrote:
> That is pretty cool! I was just reading about something like that in
> Scientific American magazine...About virtual weathering.  I don't know
> if anyone has brought this up before, but the article is at:
> http://www.sciam.com/2000/0200issue/0200dorsey.html
> I look forward to the finished patch.
I must not have gotten that issue yet...or my parents lost it before I
could get my hands on it. I will take a look at that site, though...
Chris Huff
e-mail: chr### [at] yahoocom
Date: 7 Feb 2000 02:27:40
Message: <389e73ec@news.povray.org>
Although I certainly like what you're doing I wanted to ask if this is just
plain impossible as a texture pattern type of thing instead of a kind of media
sampling method which you are apparently trying out here.
It's the scattered look to the partial places that bothers me, if this were to
be considered a patina or similar then a smooth transition zone would probably
be considered best.
As is at least it could be faked well for more distant or smaller objects.
Date: 7 Feb 2000 16:20:41
Message: <chrishuff_99-876954.16213707022000@news.povray.org>
In article <389e73ec@news.povray.org>, "Bob Hughes"
> is just plain impossible as a texture pattern type of thing instead
> of a kind of media sampling method which you are apparently trying
> out here.
I am not sure what you mean here...this is an ordinary texture, no media
used. The sampling really has more in common with blurred
reflection/transparence, it isn't much like media. It shoots rays in a
hemisphere(so rays are not shot into the object) on the surface of the
object and returns the percentage of them that hit the object.
> this were to be considered a patina or similar then a smooth
> transition zone would probably be considered best. As is at least it
Using more samples would smooth it out, and there might be ways to use
the samples other than just calculating the percentage that hit that
would give smoother results.
Chris Huff
Date: 7 Feb 2000 19:48:27
Message: <elOfON+7XaP2yN5=Ux51qWrwPoaQ@4ax.com>
On Sun, 06 Feb 2000 12:42:08 -0500, Chris Huff
<chr### [at] yahoocom> wrote:
>This is my first success with my visibility pattern. It is supposed to
>be copper or a copper alloy with a patina on it, worn away in exposed
>areas. The syntax is simple, this is the code that produced this image:
In your code I don't see any limit on the direction the sample rays
are shot. I think it would be useful if one could specify a maximum
angle that the sample rays can form with the plane tangent to the
evaluated point. The minimum should of course be 0 because for all
angles below that the sample rays will hit the surface infinitesimally
close to the evaluated point. And the maximum angle is needed to save
the overhead of taking samples straight up when the greatest slope on
the surface is 1/1000. I hope I explained this well, I will illustrate
it with an image if you want.
Peter Popov
pet### [at] usanet
ICQ: 15002700
Date: 7 Feb 2000 20:11:00
Message: <chrishuff_99-54213E.20115807022000@news.povray.org>
In article <elOfON+7XaP2yN5=Ux51qWrwPoaQ@4ax.com>, Peter Popov
Yes, I am planning on adding those sort of controls later. This was just
my first working version...there is actually code for part of it(minimum
angle) that is currently commented out and a bit incomplete. This will
probably be the first thing I do when I get back to working on this
patch(I am currently working on a particle simulator, in C++).
Chris Huff
Date: 8 Feb 2000 05:45:21
Message: <389ff3c1@news.povray.org>
I can't really ask the right questions since I don't know how you're doing this,
and trying to explain it to me would perhaps be futile.
All I'm wondering though is if this "texture" were more a pattern type than a
sampling of a surface that it might be more linear I guess would be the term.
I'm just dreaming this up in a way that would mean the texture would follow the
contours of any object like a uv map or something and without the sampling sort
of stuff which obviously is hit and miss to deduce where it goes.
Plain and simple I can't understand the dynamics of your work anyhow, so excuse
me if I go way off track trying to figure it out.  What it causes me to think is
that if a object surface can be found and mimicked in a changed way like this
does do then it just seems then that the texture could follow that surface and
be applied as though a typical patterned texture is with the usual way.
I think I see how you might not be following what I say, it reads to me like
round in circles.
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-876954.16213707022000@news.povray.org...
| > out here.
| Chris Huff
| Web page: http://chrishuff.dhs.org/
Date: 8 Feb 2000 11:49:22
Message: <slrn8a0i89.v8.ron.parker@ron.gwmicro.com>
How about the percentage that hit the object within a specified
distance?  If the object is a statue of a man on horseback and
the point is in the center of the base, between the horse's legs,
lots of rays will hit the horse's body but the area is still quite
easy to clean.
These are my opinions.  I do NOT speak for the POV-Team.
The superpatch: http://www2.fwi.com/~parkerr/superpatch/
My other stuff: http://www2.fwi.com/~parkerr/traces.html
Date: 8 Feb 2000 15:49:02
Message: <chrishuff_99-60A0DD.15492508022000@news.povray.org>
In article <slr### [at] rongwmicrocom>,
> easy to clean.
That would be one way, and would help reduce the effects of just a few
rays that hit and give a wrong result. Another way would be to have the
contribution of each test ray vary depending on the hit distance. Or to
shoot rays in the general direction of the evaluation point from a
position slightly "above" it, and use their distance and normals to
calculate the curvature...
The first two would be easy to implement, I will work on them when I
take a break from my particle simulator.
Chris Huff
Date: 8 Feb 2000 16:03:59
Message: <chrishuff_99-338EF3.16045808022000@news.povray.org>
In article <389ff3c1@news.povray.org>, "Bob Hughes"
> doing this, and trying to explain it to me would perhaps be futile.
Well, I will try anyway.
> type than a sampling of a surface that it might be more linear I
> guess would be the term. I'm just dreaming this up in a way that
> would mean the texture would follow the contours of any object like a
> uv map or something and without the sampling sort of stuff which
It is a pattern, just like bozo, crackle, or wrinkles. It is calculated
a bit differently from most, but is used in the same way any other
pattern is used. It depends on the object, like slope.
At each point on the surface of the object, several rays are shot in all
directions that don't go "down" relative to the normal at that point.
They spread out in a half-sphere with the flat portion centered over the
point. The percentage of the rays that hit is returned.
Another way to think of it is as a pattern which returns the amount of
visible "sky". If the point is on the side of a box sitting on a plane,
and very close to the ground plane, about half of it's "sky" will be
covered by the plane. On a color_map ranging from black at 0 to white at
1, it would be 50% gray. If the point is on the surface of a sphere, the
whole sky will be visible, and the result will be white. If it is close
to the point of contact between two spheres, only a narrow strip of sky
will be visible, and you will get a dark gray.
It doesn't have anything to do with UV mapping, and I don't see how UV
mapping could be applied to this problem, unless you mean by using an
image_map or material_map to specify the areas with "patina".
> so excuse me if I go way off track trying to figure it out.  What it
> causes me to think is that if a object surface can be found and
> mimicked in a changed way like this does do then it just seems then
> that the texture could follow that surface and be applied as though a
Are you thinking of a possible way to use this kind of thing to control
UV mapping? So that the map is adjusted over the contours of the surface
of the object?
> me like round in circles.
I think I am starting to understand a little, although I am still unsure
what exactly you mean.
Chris Huff
Date: 9 Feb 2000 02:40:55
Message: <38a11a07@news.povray.org>
news:chrishuff_99-338EF3.16045808022000@news.povray.org...
| of the object?
I was using the term uv map loosely to describe what I thought might closely
resemble what your stuff was doing.  That is, following the surfaces of objects
and their normals.  Again I say I'm not knowledgeable enough about any of it I
was just trying to get the sense of what was going on and if there were any
potential of it being more pigment pattern-like than it appeared to be.
Instead of scattering points on a surface maybe spreading the texture on like a
second skin.  If that makes any sense.  It's of course impossible if there isn't
any way to follow the original object precisely and deform it from there I
suppose.
Nice try at explaining it, I got closer than ever at understanding you.
