POV-Ray : Newsgroups : povray.binaries.images : chrome texture ? - 1 attachment Server Time
15 Apr 2026 23:29:04 EDT (-0400)
  chrome texture ? - 1 attachment (Message 1 to 10 of 11)
Subject: chrome texture ? - 1 attachment
Date: 19 Aug 2002 04:01:01
Message: <Xns926F6521FCFF2raf256com@204.213.191.226>
description, another views :
http://www.raf256.com/pov/chrome
generaly - image represents blured reflection made by very small normal and
big anit alias
Download '055.png' (328 KB)
Preview of image '055.png'
Subject: Re: chrome texture ? - 1 attachment
Date: 19 Aug 2002 04:27:28
Message: <3d60abf0@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> schrieb im Newsbeitrag
and
> big anit alias
Well ... that was a big file for such a generic picture. As you even gave a
URL, you could have made some nice small Jpeg.
Marc-Hendrik
Date: 19 Aug 2002 04:58:36
Message: <3D60B33C.21A3FECA@gmx.de>
> big anit alias
I wonder when you will manage to configure your newsreader to generate
readable attachments.
Some technical comments:
- a 15x15 area_light does not have much effect in such a scene apart from
making it slow.
- the finish could use metallic reflection.
- what's described in
http://www.students.tut.fi/~warp/povQandT/languageQandT.html#blurredreflection
is probably a better way for achieving realistic reflection blur.
- using 'recursion_limit 3' for radiosity would be similarly useless as
the 15x15 area_light.
Date: 19 Aug 2002 05:06:13
Message: <Xns926F703BEB053raf256com@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3D60B33C.21A3FECA@gmx.de
I do what I can... many peoples see attachment
> from making it slow.
at i.e 10x10 the difference was notacible
it use it, as described on www
> lection is probably a better way for achieving realistic reflection
> blur.
looks interesting :_ I'll play with it
Date: 19 Aug 2002 05:10:21
Message: <3D60B5FD.8D771834@gmx.de>
No, that's just for metallic specular highlights.
Date: 19 Aug 2002 06:20:26
Message: <3d60c669@news.povray.org>
  Hmmmm... I'm not that sure. You mean perhaps that it is much more easy to
setup and (somewhat) faster. But I tried both methods and can't still
decide wich one produces "more realistic" results.
  Rafal aproach is not that bad, but I found that it works better with
focal_blur than with aa. I also prefer the cells patern for this technique,
as it seems to give the most smooth results.  Here is a sample with 192
blur_samples (damn slow):
    http://www.ignorancia.org/images/microcells08-192bs.jpg
  and the same scene without "micro-normals":
    http://www.ignorancia.org/images/micro-no_brush.jpg
Jaime Vives Piqueres
Date: 19 Aug 2002 07:15:09
Message: <3D60D33D.D2E05C57@gmx.de>
I was mostly referring to speed, apart from that it's never good if a
technique totally depends on aa (or focal_blur) to function.
Using focal blur for smoothing will not work in the focal plane, you will
always get a grainy appearance there.
BTW, did you use the default normal accuracy or a different value?
Date: 19 Aug 2002 12:41:01
Message: <Xns926FBD6CD645Fraf256com@204.213.191.226>
news:3D60D33D.D2E05C57@gmx.de
yes, but this approach is realistic - if You zoom in real chrome object You
will see that in fact it is quite sharp (as in zoom in on www).
And my normal works exacly that way.
I alsow foght about strong AA needed, and imho best solution is to use
quality optin like
#declare QQ_DetailedNormal = 1;
and when option is "0" - use some i.e. bozo and ignore normals smalle rthen
i.e. 0.1 (on 50.0 radius sphere)
Date: 19 Aug 2002 13:14:46
Message: <3D612786.5D37542C@gmx.de>
I'm not sure what you think is realistic when rendering this technique in
a larger view, but the irregularities on a slightly dull metal surface are
always in microscopic scale (usually a few micrometer) so you won't see
them directly even if you 'zoom in'.  There is no point in trying to
create a physically correct model of the irregularities because you won't
be able to simulate the optical effects involved accurately.
> quality optin like
Would you mind taking a bit more care about typing?  I would not complain
if this was about language style but it seems just mixing up characters.
If the reason is some medical handicap i will understand of course.
Date: 19 Aug 2002 15:36:25
Message: <Xns926FDB2AD4AD3raf256com@204.213.191.226>
news:3D612786.5D37542C@gmx.de
>> object You will see that in fact it is quite sharp (as in zoom in on
>> www). And my normal works exacly that way.
> in a larger view, but the irregularities on a slightly dull metal
> surface are always in microscopic scale (usually a few micrometer) so
> you won't see them directly even if you 'zoom in'.  There is no point
ok. So this image is better to ilustrate tome type of not-polished, or
rusty chrome.
About blurred reflection - why this interesting future was not used in Pov
3.5 ? I meen - where there some problems, or just authors deside this is
not an important future ?
[FUT .general]
