Christoph Hormann wrote:
> > brightness 2
> Are you sure about that?
> brightness 1 is a fairly universal value that should be realistic in most
> cases. If you change an existing scene for using radiosity, it's often
> even useful to use lower values.
Well, it happens that I use brightness 2 in scenes where I have direct
photographic references (I just cut and pasted the settings here), so the
choice is only dictated by the similarity between the "real" scene and its
rendered version (I'm not talking about the Cornell box here, but of complex,
real-life pictures). These images also require extremely bright lights.
But you're right, brightness level depends on the scene. My "Contrast" image
used 1.2 for instance (but it was not based upon a photography). I don't
remember using values lower than 1. It's more an aesthetic choice than a
technical one IMHO.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Subject: Re: gallery - gallery9_lowkb.jpg [1/1]
Date: 30 Mar 2001 12:40:12
Message: <3AC4C4FC.18634B71@gmx.de>
Kevin Ellis wrote:
> In the room WIP I posted a while ago which only has one window I have to use
> a brightness of above 3 to be able to see anything except blackness, it all
> depends on how much of the scene is actually lit by direct light. I
> regularly use a brightness of about 2 though.
It's usually better to increase the ambient finish of the light emitting
objects than to increase brightness. While the fist only brings more
light in the scene, the brightness parameter strongly influences the
colors of the scene in an often unrealistic way.
Christoph Hormann <chr### [at] gmx de>
Date: 30 Mar 2001 12:46:04
Message: <3AC4C65C.5F516FD9@gmx.de>
Lutz-Peter Hooge wrote:
> I had to set it so 0.3, at 1 everything is white... maybe because I use
> colors > rgb 1.
As Gilles said, all finishes need to be changed, if you want to avoid
adapting the colors, you can try to play with the diffuse finish
component.
> But theres another problem: 0 PPS even with HQOn=0 :-(
> Only if I switch EVERYTHING off (reflections, isosurfaces, arealights
> etc), I can get a preview.
Be sure to turn off all additional light sources (just leave the sun
light). Of course reflections and isosurfaces slow down things too, but
at least the pretrace should run with 'visible speed'.
> In article <3AC4B8D0.47B58239@gmx.de>, chr### [at] gmx de says...
> colors > rgb 1.
Strange. I use HQOn=0 on my old, slow Pentium 133. Note that scenes that use
these settings :
- have only one light source
- all objects have ambient = 0
- have few reflections
- have few (or none !) objects with ior
- colors are normal (below rgb 1)
I hope this helps, but as I design images around radiosity, I can't say that
these settings are universal.
G.
Graphic experiments
Pov-ray gallery
Date: 30 Mar 2001 12:57:19
Message: <3AC4C8FF.56E542E5@gmx.de>
> technical one IMHO.
It could be that Indoor scenes often work quite well with increased
brightness, it probably is also mainly a questions what settings the
objects' colors and finishes are tweaked for. NTL, could you point me to
some pictures using brightness 2?
In article <3AC### [at] inapg inra fr>, tra### [at] inapg inra fr says...
Yes, I switched the lamps off.
Only the sunlight remains (arealight, 7x7)
Done that.
Wel... hmmm... the floor, the sculptures, the window-glass and the water
are reflective.
The windows glass...
All the white objects have colors of 1.5-2. Does that slow down
rendering? With brightness 0.3 the scene look Ok.
In article <3AC4C65C.5F516FD9@gmx.de>, chr### [at] gmx de says...
> component.
Does the brightness have an influence on rendering speed?
> light).
Of course i've done that. But still 0 PPS
Lutz-Peter
Probably. There's always a lot of tweaking involved in radiosity anyway.
> NTL, could you point me to some pictures using brightness 2?
One at least, uploaded there on a temporary basis (others will come... someday
http://www.oyonale.com/temp/classroom.jpg
G.
Graphic experiments
Pov-ray gallery
This could be the main culprit. I have found that a few (and even small)
objects with ior used with radiosity could make a computer weep. I don't
know about a whole pane...
Lots of reflective objects don't help either, but to a lesser extent. The
other problem with using reflective objects with radiosity is the apparition
of ugly black spots. The spot remover is a higher max_trace_level (not the
MTL of 15), which in turns causer slower rendering.
> rendering?
Not that I know.
Personally, I prefer harsh lights with "normal" colors than the other way
round. More a habit than something rational though and I use higher than 1
colors when needed.
G.
Graphic experiments
Pov-ray gallery
"*** note *** the MTL of 15", silly me.
G.
Graphic experiments
Pov-ray gallery
