Subject: Re: A quick povr branch micro normal image.
Date: 17 Mar 2022 06:54:22
Message: <6233135e$1@news.povray.org>
On 3/17/22 02:04, jr wrote:
>> Is the fail easily repeatable?
> not sure, happened late in the animation[*], had no stomach to try + repeat,
> sorry. the code in question is the 'usaf' animation posted same time (March
> 13th).
No problem. The flaky issues / bugs are always the hard ones to run down.
Did you continue the animation successfully starting from frame 3048?
Or, is it an animation where each frame depends on information from
previous frames(s) such that starting at frame 3048 not possible?
I might try running valgrind looking for memory leaks with your
particular animation as a shot in the dark. But, that's not something
I'll get to for a while.
Wondering too if the regular animation mechanisms can develop the memory
bubbles seen with RTR. My guess is the frame rates with regular
animation always too slow for it to happen - and as a light user of
regular animation I've never noticed a (povms) memory bubble effect but,
never gone looking for it, so who knows.
Bill P.
hi,
> > not sure, ...
took copy of code posted + tried again, several times, every time the run (now)
crashes at frame 2800; have tried to remember which if any changes I made, but
can only think of quality + dimensions in ini file. attached excerpt from
'povr' build-log, libraries in use, and the animation state at the time.
no, did not. simply switched to POV-Ray proper, wanted "it" (the anim) out of
my hair :-).
running with 480x360 and aa threshold .3 should do.
sorry, no ideas at all. (it's as if the 'tmp_' dictionary is not updated in
time for next access)
regards, jr.
Download 'frame_2800.txt' (4 KB)
Date: 17 Mar 2022 17:41:22
Message: <6233ab02$1@news.povray.org>
On 3/17/22 11:19, jr wrote:
> Degenerate cylinder, base point = apex point.
> Fatal error in parser: Uncategorized error.
> Render failed
The three lines above come from a test during parsing while additional
internal data for the cone/cylinder is being done using a function
within cone.cpp. The tests is finding that the base and apex are <1e-10
(a) apart - and throwing an error rather than issuing a parse error via
message(b). The same code exists in POV-Ray proper v3.7 onward and povr
(c).
(a) - The cone code hasn't been reworked as yet in povr to remove
'EPSILON' use. The test value there should be ~4.4e-8 or povr's
gkMinIsectDepthReturned. FWIW.
(b) - The particular test could be done completely inside the parser I
think. Not sure why it's done in the cone/cylinder shape code.
(c) - There has long been a TODO note in the code suggesting that
particular throw should be a 'possible error' instead - with execution
continuing. I don't agree with the TODO note. Where base and apex are
too close, it's an error in cone/cylinder specification.
The puzzle for me at the moment is I have no idea why those parsed base
and apex vectors would be different between any versions of POV-Ray.
Best guess. It's due some indirect difference where I've moved to
'double' from 'float' in povr and the previous 'snap' of the vector
components to floats rounded length 'up' in a way not tripping the
throw. In other words, values previously rounded such that the base to
apex length is 'long enough'.
Bill P.
hi,
> > Render failed
> (c).
thank you v much. the thing I don't understand is why, when every increment is
a whole unit, we'd get into a situation where (the value of) Epsilon would
matter. and while the above reasoning does make sense, I can't shake the
feeling that, underneath, it's a dictionary "thing"/problem.
regards, jr.
(correction)
sorry, meant to write that the actual error is, I feel, misleading, and perhaps
is a dictionary/macro "thing".
<https://en.wikipedia.org/wiki/Allegory_of_the_cave>
regards, jr.
Date: 18 Mar 2022 05:39:34
Message: <62345356$1@news.povray.org>
On 3/18/22 03:32, jr wrote:
> (correction)
Played a little with your animation this morning and see similar parse
time fails. Continuing from the failing frame (ignoring whether this
correct for the scene for now) always seems to work. So, it's not the
particular frame calculations as you suggested.
The fails after re-starts from previous failing frames come faster and
faster the larger the size of the usaf_items.csv file. This hints at a
race condition where we are, perhaps, picking up base or apex twice as
base and apex.
Debugging will take time I don't have at the moment. I'll capture the
current work in a debug directory with the intent to come back to it later.
The good news is the fails are somewhat reproducible - though it's a bit
of a pain to reach the 'fail more frequently' state.
Bill P.
hi,
> time fails.
glad it reproduces, and not result of compile-time choices/optimisation.
sorry for late-ish reply, re-ran the anim a number of times last night + this
morning.
> base and apex.
thanks. adding some "data points" which, hopefully, will be of use then.
started with clean copy as posted, and in ini dialled down AA threshold (.3) and
commented out the 'all_file' line. rendering then fails, with error, after
image 2799, repeatable[*] (take "similar" to mean you see different frame#?
anyway, expect it to stay the same). I then switched verbose + logging off in
the scene, same error but after image 2876, also repeatable. next tried with
verbose true but no logging, same error, this time after frame 2895. then it
got .. tasty :-). ran with verbose false and logging enabled, and got (out of
five runs) two successes and three segfaults (all past frame 3500, but different
#s).
povray2[664477]: segfault at 25 ip 00000000004c733
[*] each test done twice or more.
I'd be interested to know whether your's too crashes.
not done it, but if state{curr} and items{point} agree, you should be able to
restart with '+kfi' etc.
regards, jr.
another of-interest-perhaps point. added a '#debug concat()' as first line of
the '__mkItems()' macro, outputting the macro arguments (of which index is not
o/wise used in the code). now get a different error, at frame 2735: "Expected
'numeric expression', 'string identifier' found". hypothesis - macro gets
wrong/corrupted set of args, the first of which (i_) happens to look like a
string? anyway, intriguing (and annoying :-)).
regards, jr.
Date: 24 Mar 2023 11:40:02
Message: <641dc452$1@news.povray.org>
On 3/19/22 09:41, jr wrote:
> then it got .. tasty 😄. ran with verbose false and logging enabled, and got (out
of
> #s).
Looking at this issue again after a year! (Sorry)
I can now see the exact re-producible fails you'd mentioned. I changed
the cylinder source code so it simply writes the duplicate apex base
vectors rather than issue a throw(a). Starting always from a saved case
which reached frame 3000. I run repeatedly and it is always the same
three fails!
I, like you, have had other fail signatures, but it looks like if we
start with certain fixed conditions the fail points are indeed the same.
This perhaps enough information for me to insert a break point.
I've tried a few other things shooting in the dark and like you get as
often as not 'other' odd results.
At the moment I am trying to get your seg fault signature above using a
debug compile having symbols - where the core file generated should be
useful.
You didn't get this fail every time, and so far I've not gotten a
segfault. I'm just running it and running it again for a while with
verbose false and logging enabled. We'll see.
Bill P.
Date: 24 Mar 2023 21:46:46
Message: <641e5286$1@news.povray.org>
> useful.
No segfaults of the differing type you saw.
I did get two different Parse Error signatures early. One for an array
subscript out of range and another via the include of parse_fore.tmp
attempting to access an uninitialized array element. Neither made sense
to me.
Then the blasted povr code proceeded to run cleanly both partial runs
and full ones for 6 passes.
I went back to the original failing set up starting at frame 3000 with
both verbose and log frames on - which had been failing at the same
'spots' for me - and at least the most recent pass decided other spots /
cylinders should now fail.
Only thing that's clear is what was clear before - we have no problems
until the frame counts are 2500, 3000 or more.
Anyhow. Answering the question you asked a year ago. I don't see the
segfaults you saw with verbose off and logging on. Mostly things worked
in this configuration...
Future posts on this povr only problem, I'll put in a new thread
somewhere. Probably user.patches. This thread got really long and became
'twelve ways' unrelated to the original topic!
Bill P.
