POV-Ray : Newsgroups : povray.binaries.images : Upgrading POV-Ray's include files #1: granites.inc --> granites21.inc Server Time
18 Mar 2026 07:21:33 EDT (-0400)
  Upgrading POV-Ray's include files #1: granites.inc --> granites21.inc (Message 39 to 48 of 123)
Subject: Re: Upgrading POV-Ray's include files #1: granites.inc-->granites21.inc
Date: 15 Apr 2021 02:56:29
Message: <6077e39d$1@news.povray.org>
Op 14/04/2021 om 18:00 schreef Alain Martel:
>> Op 14-4-2021 om 12:22 schreef Bald Eagle:
>>> Thomas de Groot <tho### [at] degrootorg> wrote:
>>>> So, to be correct, I should also change all the single 0.000 components
>>>> of colour triplets to 0.004.
>>> And for realism, always some small amount of reflection in every
>>> finish (but
>>> maybe our radiosity covers that already)
>>> I usually use an E = 0.000001 to avoid coincident surface type stuff
>>> For the granites I used #declare _not0 = 1/256; // a small non-zero
>>> value since
>>> it was the same character length as 0.000 and fit nicely into the
>> Smart! ;-)
>>> With regard to the duplicate finish blocks, there was certainly a
>>> difference
>>> when I rendered the base texture vs the full layered texture.
>> Yes, there is a difference. I need to test this more thoroughly though
>> to see what the different finishes do to the final render because I am
>> not entirely sure about the transparant parts of the second layer.
>> Shall report back later.
> One thing that can be done with layered textures with a finish in more
> than one is to simulate varnished metals.
> Have the base texture with metallic highlights and reflection, while the
> top texture is transparent with fresnel highlights and reflection. Just
> need to add an interior for the ior.
> The rendered image is quite similar to actual varnished metal.
Ah! That is an idea! Thank you Alain; I certainly want to play with this.
Subject: Re: Upgrading POV-Ray's include files #1: granites.inc --> granites21.inc
Date: 15 Apr 2021 10:27:28
Message: <60784d50@news.povray.org>
Am 4/11/2021 um 14:06 schrieb Thomas de Groot:
> granites.inc from 1996 is not officially part of the POV-Ray set of
> include files but I believe it should be part of a larger collection of
> essential include files developed over the years by the users community.
> The original code, which I have been able to trace back to 1996, I have
> upgraded to version 3.7+ standards. The result is made available in
> p.b.s-f. The collection set contains:
> 1. the original granites.inc file (comments included);
> 2. the upgraded granites21.inc file which provides three versions for
> each granite type (comments included);
> 3. example scene files for each granite type;
> 4. a set of rendered images of each granite type. Two of those are shown
> here.
> Comments welcome of course.
Comments, well, truth is my first reaction was just to demand that you
remove my nom du guerre from this include file as I consider it an
personal insult to appear within some context that is not even wrong.
To quote W. Pauli in his native language "Das ist noch nicht einmal
falsch."  Pronounced in his dialect from Vienna.
I also need to step in for Daniel Meklenburg (aka Code Warrior) the
original author of the granites who's intention was to provide some
realistic colored granites for POV-Ray. And he did it very well for the
time, and yes I did check it out by installing POV-Ray version 3.0 and
did render it there.
None of your 3 versions does even remotely look like the original granites.
And no, providing 3 versions has nothing to do with artistic freedem
or freedom of choice when all 3 versions look completely dull compared
to the original.
Well, for old times sake, I did create a scene file that shows a
framework how this has to be done, added numerous notes and comments as
to how and why.
And for artistic freedom, I'm all for it and might add a small addition
to this framework that will allow you to change a dark green granite to
some bright pink marble - and in addition will do some *really* useful
thing called blackpoint compensation, addressing the issue that (most)
contemporary monitors are unable to display *black* while good old CRT's
had no problem with this.
Attached is the scene file and two example render showing Code Warrior's
North American Pink granite polished and frozen.
Download 'nap.pov.txt' (20 KB) Download 'nap_frozen.png' (446 KB) Download 'nap_polished.png' (448 KB)
Preview of image 'nap_frozen.png'
Preview of image 'nap_polished.png'
Subject: Re: Upgrading POV-Ray's include files #1: granites.inc -->granites21.inc
Date: 15 Apr 2021 11:05:58
Message: <60785656@news.povray.org>
Op 15-4-2021 om 16:27 schreef Ive:
[snip]
Thanks Ive. I shall comment on your mail more in detail later. Just one
remark: The "original" granites (and your images are examples) do /not/
show granites in their /original/ scaling! I should know, as I am a
geologist. Which is why I changed the scaling to - at least - something
representing a granite as seen in nature. I have a couple of examples in
my backyard, graciously transported here by the penultimate ice age. :-)
Date: 15 Apr 2021 11:53:41
Message: <60786185$1@news.povray.org>
Just some general comments at this stage.
I would sincerely regret such a move. I do not really understand a rigid
orthodox stand about this matter, from a user's point of view. I have
always assumed that providing some liberty of choice should be given;
what does it matter which version a user chooses for his scene because
he/she finds it more appealing or "correct" for his/her personal context?
However, these are my personal views, whatever they are worth. I am also
interested in the comments on this by others beside myself.
See my rapid comment in my earlier post.
> to the original.
Dull... in what manner? I fail to understand.
> to how and why.
My sincere thanks for providing the scene file in particular. I have not
looked at it in detail yet, but I shall return to it and comment where
necessary later on.
All right.
Thank you indeed! Much appreciated. I am all for a good discussion even
if we do not necessarily agree on all points.
Cheers!
Date: 15 Apr 2021 16:05:00
Message: <web.60789bff2b09e497d98418916e066e29@news.povray.org>
The radical visual differences between the granites of Thomas vs. Ive reminded
me of something I used to do years ago in older versions of POV-ray: running my
scenes in a gamma 2.2 environment (instead of the always-recommended 1.0)--
simply as a way to get 'rgb colors' to appear the way that I thought they
should. This was before I understood the technical details of 'linear' lighting
and rendering (which is another topic, of course.)
So, using the two *original* 1996 Daniel Mecklenburg textures from the
"granites_original.inc" file that Thomas included in his zip files, I decided to
run  them in v3.7-- while *switching* between assumed_gamma 1.0 and
assumed_gamma 2.2. [To be specific, I'm running a v3.8xx 'experimental build' in
Windows, that piggybacks on v3.7, but  using "#version 3.7" in my test scene.]
Disregarding my own scene's lack of radiosity and a different light_source
setup... not to mention the vast differences that have accrued in POV-ray itself
since 1996...the respective gamma results are quite interesting!
At the time of Daniel's code creation, there was no 'assumed_gamma' keyword,
AFAIU-- just something like Display_Gamma or File_Gamma in an .INI file. (That's
probably what I used-- and with a 2.2 value instead of 1.0.)
The results of my test here indicate that the Thomas/Ive visual differences
might simply be the result of the gamma environment Daniel M was using at the
time.  If it was indeed a 2.2-gamma environment-- possibly like my own old way
of doing things-- then Ive's version would seem to be more 'correct' (as regards
Daniel's original intent?); if Daniel used a gamma of 1.0 instead, then Thomas's
looks correct.
Just some food for thought.
I make no judgement as to which of the versions of 'North American Pink granite'
has the correct 'visual' look-- I'll leave that to the granite experts ;-)
-------- Kenneth test code ------
global_settings{assumed_gamma 1.0} // change to 2.2
#default{finish{ambient .07 emission 0 diffuse .8}}
  perspective
  location  <0, 2.1, -6.9>
  look_at   <0, 1,  0>
   angle 58
light_source {
  0*x
  color rgb .3
  translate <-20, 40, -20>
light_source {
  0*x
  color rgb .7
// NAPPol : North American Pink polished
// NAPFro : North American Pink frosted
//----ORIGINAL texture code from Daniel Mecklenberg, used below
#declare PolishFinish =
finish { ambient 0.5 phong 0.9 phong_size 80 brilliance 1.5 }
//----ORIGINAL texture code from Daniel Mecklenberg ----
// [KENNETH note: a material wrapper is apparently not
// needed for this 2-part texture]
#declare NAPPol =
granite
turbulence 0.8
color_map {
[ 0.000, 0.500 color rgb < 97/255, 51/255, 63/255 >
color rgb < 178/255, 118/255, 86/255 > ]
[ 0.500, 1.000 color rgb < 172/255, 129/255, 116/255 >
color rgb < 235/255, 215/255, 205/255 > ]
finish { PolishFinish }
granite
turbulence 0.8
color_map {
[ 0.000, 0.600 color rgbf < 1.00, 1.00, 1.00, 1.00 >
color rgbf < 1.00, 1.00, 1.00, 1.00 > ]
[ 0.600, 1.000 color rgbf < 0.10, 0.08, 0.08, 0.50 >
color rgbf < 0.05, 0.04, 0.04, 0.00 > ]
scale 0.5
translate < 20, 20, 20 >
rotate < 30, 30, 30 >
#declare NAPFro =
granite
turbulence 0.8
color_map {
[ 0.000, 0.500 color rgb < 147/255, 111/255, 123/255 >
color rgb < 162/255, 129/255, 116/255 > ]
[ 0.500, 0.720 color rgb < 172/255, 129/255, 116/255 >
color rgb < 245/255, 220/255, 215/255 > ]
[ 0.720, 1.000 color rgb < 70/255, 70/255, 70/255 >
color rgb < 50/255, 50/255, 50/255 > ]
finish { diffuse 1.0 crand 0.25 ambient 0.5 }
normal { bumps 0.1 scale 0.2 }
background{srgb .7}
union{
superellipsoid{<.1,.1> rotate 35*y}
sphere{0,1 scale <1,1.3,1> translate 2.2*y}
texture{NAPPol scale .3} //---  OR use NapFro ---
Download 'granite gamma comparisons.jpg' (144 KB)
Preview of image 'granite gamma comparisons.jpg'
Date: 15 Apr 2021 16:15:00
Message: <web.60789e1f2b09e497d98418916e066e29@news.povray.org>
> decided to run  them in v3.7 ...
I forgot to mention that the *only* minor change I made to those original
textures was to scale them smaller-- to look more like Thomas's granite.
Date: 15 Apr 2021 18:50:00
Message: <web.6078c2632b09e4971f9dae3025979125@news.povray.org>
Maybe we should implement the Cornell Box as a standard way of posting images
for comparison - to remove all of the other variables that affect the look of an
object and texture.
http://news.povray.org/povray.unofficial.patches/thread/%3C39380E82.5F30%40wanadoo.fr%3E/
(Isn't there an include file for this?)
Date: 16 Apr 2021 02:25:00
Message: <web.60792d862b09e497d98418916e066e29@news.povray.org>
> object and texture.
Yes, the 'Cornell box' scene is in SCENES/RADIOSITY (I had to hunt for it.)
I think its particular box environment might not be the best for showing the
true colors of a textured object placed inside it, only because it has
red/green/yellow walls (and the only lighting comes from the small ceiling
'radiosity' panel.) But your idea sounds useful-- perhaps a gray sphere for the
environment? Plus at least one white light_source for phong/specular highlights?
Date: 16 Apr 2021 02:45:00
Message: <web.607931dd2b09e497d98418916e066e29@news.povray.org>
Just noticed that my test scene code's two light_sources are in identical
positions-- they should be...
light_source {
  0*x
  color rgb .3
  translate <20, 40, -20>
light_source {
  0*x
  color rgb .7
My apologies for the error. I don't think it affects the results of the overall
experiment though. (I was curious as to why my renders showed only ONE highlight
on the objects.)
Date: 16 Apr 2021 02:46:39
Message: <607932cf@news.povray.org>
Op 15/04/2021 om 22:03 schreef Kenneth:
[snip]>
It the case of the granites I sincerely wonder if the gamma issue is an
issue at all (not to be discarded like that of course but...).
Attached is a Real World photograph of North American Pink. No scale is
provided but, in general, the largest grains in granites do not exceed
10-15mm [Bates & Jackson (1987): Glossary of Geology, 3rd Ed.].
Imo, this granite hue closely resembles the assume_gamma 1.0 render and
much less the assumed_gamma 2.2 one. However, there are innumerable
variations in hue and sizes, so who can say he is in the right and who
in the wrong? It becomes almost trivial. Except for the /scale/ of the
texture, where I strongly feel that a 'Real World correct' render should
be provided to the users.
I have come to the conclusion that granites21.inc is /based on/
granites.inc by Daniel Mecklenberg and not an exact reproduction of his
code. If we want those, we need to render the original file separately,
  with the initial conditions like Ive and you have done.
Download 'north american pink.jpg' (49 KB)
Preview of image 'north american pink.jpg'
