POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
28 Jul 2026 03:23:32 EDT (-0400)
  LanuHum Global Test image (Message 61 to 70 of 126)
Subject: Re: LanuHum Global Test image - wip 3
Date: 11 Jan 2014 10:31:15
Message: <52d163c3@news.povray.org>
On 11-1-2014 14:20, LanuHum wrote:
>> - in the POV scene: replace the mesh{} objects by the mesh2{} ones;
> Povray slows down the miscalculation if matrix is used
> I didn't find the solution to calculate normal*matrix for mesh2
> Maurice Raybaud it is possible will make
not essential presently, I used mesh2{} because Poseray does not export
to mesh{} (well, an older version does, but I prefer mesh2 anyway). The
result should be the same. One of the advantages of mesh2{} is that
/materials/ are given to the objects, so there are more possibilities
especially for translucent objects).
Date: 11 Jan 2014 10:34:59
Message: <52d164a3@news.povray.org>
On 11-1-2014 16:14, Thomas de Groot wrote:
> On 11-1-2014 15:41, Ive wrote:
>> BTW before you start a final render: your aspect ratio for the image is
>> wrong!
> hmm... 1000x800 and using all camera parameters as given by the original
> scene file. I shall change the right to -x*image_width/image_height and
> see if that makes any difference.
Hmmm, yes, that makes indeed a difference.
Download 'test.png' (133 KB)
Preview of image 'test.png'
Date: 11 Jan 2014 10:54:35
Message: <52d1693b@news.povray.org>
Am 11.01.2014 16:14, schrieb Thomas de Groot:
well, 1000 / 800 makes 1.25 and I bet 100 PovCoins this is not what you
have. The squeezed chairs do give it away.
> Presently, I have difficulties with photons/caustics. THey do not show
> on the ceiling...
I cannot add anything that's not already in the docs: you need a photon
block within global_settings, make the main light source emit them, make
the water (and Suzanne) a target and shoot a few millions of them... and
do not forget to turn collect off for objects where it is not important
to speed up the render.
> Ultimately, I shall add a media to the scene to show some dust in the
> atmosphere, but not too much.
Thomas, you are a patient one ;)
But what *I* really would like to see is Suzanne made of tinted glass.
-Ive
Subject: Re: LanuHum Global Test image - wip 3 photons?
Date: 11 Jan 2014 10:55:47
Message: <52d16983$1@news.povray.org>
I have difficulties with photons/caustics. If you compare with
Christoph's image of the scene, you will see there how the water plays
on the ceiling. I cannot reproduce this.
I am using the following settings:
global_settings:
   photons {
     spacing 0.01
     gather 20, 100
     autostop 0
     jitter 0.5
     max_trace_level 15
     adc_bailout 1/10e5
objects:
object {suzanne_ob
   interior {
     ior 1.5
     dispersion 1.05
     dispersion_samples 10
     caustics 1.0
     //fade_distance 5
     //fade_power 2
   photons {
     target
     refraction on
     reflection on
     collect off
object {water_ob
   interior {
     ior 1.3
     dispersion 1.05
     caustics 1.0
     //fade_distance 5
     //fade_power 2
   photons {
     target
     refraction on
     reflection on
     collect off
light_source:
     photons { refraction on reflection on }
glass surfaces:
photons {pass_through}
How can I tweak these parameters?
Date: 11 Jan 2014 11:02:29
Message: <52d16b15$1@news.povray.org>
Yes, the difference comes from:
original right: <-1.0799999982118607, 0, 0> results in squeezed chairs
my (new) right: -x*image_width/image_height gives the chairs correctly
I suppose passing from Blender to POV introduces differences.
>> on the ceiling...
See my post below.
I am, if the render time remains manageable. Somehow, presently I am at
about 1 hour.
yes, that is still something I need to tweak.
Date: 11 Jan 2014 14:00:37
Message: <52d194d5$1@news.povray.org>
Am 11.01.2014 16:55, schrieb Thomas de Groot:
Don't forget to make the ceiling windows pass_through.
Date: 11 Jan 2014 16:26:40
Message: <52d1b710$1@news.povray.org>
> Just for a quick test I switched off the normals here. I doubled again
> the luminosity and now the shadowy parts come out better.
> I wonder if the leaking along the edges cannot be remedied by better
> meshes. The present ones are of very low resolution (a pillar face is
> just two triangles for instance). That might give problems. I am going
> to have the walls through Silo and process them a bit.
> Thomas
A pilar face using only 2 triangles don't mean low quality as those two
are realy all that is needed.
Some slight beveling of the edges /may/ help some.
Another solution is to add something behind the mesh, or give it some
actual thickness, especialy near the corners where some radiosity
samples can sample areas of the bright sky or that receive direct
illumination.
Date: 12 Jan 2014 03:06:59
Message: <52d24d23$1@news.povray.org>
Yes, I thought so too after I posted :-)
Editing the object, it appears that there /is/ some bevelling present on
the arches and pillars.
> illumination.
Has been done since.
Date: 12 Jan 2014 03:12:04
Message: <52d24e54@news.povray.org>
They are.
Subject: Re: LanuHum Global Test image - wip 4
Date: 12 Jan 2014 07:14:01
Message: <52d28709@news.povray.org>
After improving suzanne's and the water's finish, and adding a light
scattering media to the air, this is what I get.
I think I need to move the light_source a bit again. Moving the
skylights increased the shadows on the water surface.
Over all, I am well satisfied but before going for the final render I
would like your opinions.
Download 'test.png' (427 KB)
