POV-Ray : Newsgroups : povray.binaries.images : LanuHum Global Test image Server Time
15 Oct 2026 06:48:43 EDT (-0400)
  LanuHum Global Test image (Message 51 to 100 of 126)
<<< Previous 50 Messages Goto Latest 50 Messages Next 26 Messages >>>
Subject: Re: LanuHum Global Test image
Date: 10 Jan 2014 04:11:53
Message: <52cfb959$1@news.povray.org>
On 10-1-2014 9:59, Ive wrote:
> Am 10.01.2014 09:21, schrieb Thomas de Groot:
>> The bright dots are still a problem indeed. They are also present in
>> Christoph's image. I wonder if this is not light leaking along mesh
>> edges....
> It is light leaking and it gets even worse when using higher quality
> (i.e. lower error_bound) settings. I guess the only solution is to
> remodel the room and give the walls and the ceiling some real thickness,
> thats what I did. As with CSG where it is a good idea to let walls and
> ceiling overlap.
You confirm my own guess. I am going to process the walls and pillars
objects in Silo.
>> presently, radiosity settings are:
>>    radiosity {
>>        pretrace_start   0.08
>>        pretrace_end     0.004
>>        count            500, 1000
>>        nearest_count    10, 5
>>        error_bound      1
>>        recursion_limit  4
>>        low_error_factor 0.3
>>        gray_threshold   0.0
>>        minimum_reuse    0.015
>>        maximum_reuse    0.1
>>        brightness       1
>>        adc_bailout      1/100000
>>        normal           on
>>        media            off
>>        always_sample    off
>>        //max_sample     1.0
> When you add no_radiosity to all window/door glasses you'll get away
> with 2 recursions and faster render speed - without any visual impact.
Good idea. I didn't think of that possibility.
> And I'm not sure about this low adc_bailout within the radiosity block,
> if such low value is needed shouldn't it go into the global settings
> block itself - to keep the photons visible?
> Maybe Christoph can shed some light on this.
I put in that low adc_bailout in preparation to the photons/caustics
generation, as Christoph suggested earlier in this thread. I am a newbie
as far as this is concerned.
Date: 10 Jan 2014 04:20:00
Message: <52cfbb40$1@news.povray.org>
Am 10.01.2014 10:11, schrieb Thomas de Groot:
Yes, thats what I'm saying too, but it seems you missed the "global
settings block itself" - and not the radiosity block within the global
settings.
-Ive
Date: 10 Jan 2014 06:44:12
Message: <52cfdd0c$1@news.povray.org>
> On 10-1-2014 1:13, Jörg 'Yadgar' Bleimann wrote:
>> Still, to me the overall light levels of the shadowed parts seems
>> somewhat too low (but this might be a question of my system's gamma -
>> currently 2.0)... and there are still some bright artifact dots along
>> the upper edges of the walls. What radiosity settings did you use?
> I agree about the light levels but I don't know how to compensate that
> other than by an additional light (I don't like) or by a stronger light
> maybe (I shall try). However, I personally like this and my impression
> is that this is a /natural/ situation. Comments welcome.
The proper approach to compensate would be to increase the walls'
brightness. /If/ you want to compensate at all. Looks natural enough to
me, too.
> edges.... Comments welcome.
It's not specifically leaking along mesh edges, but through /any/ edges.
Surprisingly, similar artifacts can be observed with CSG as well. Up to
this day I haven't really figured out what's causing this, but the
number of radiosity bounces (i.e. recursion_limit) does seem to play a
role (I think I've never seen these artifacts with recursion_limit 2 or
lower).
Date: 10 Jan 2014 06:47:28
Message: <52cfddd0$1@news.povray.org>
Am 10.01.2014 10:18, schrieb Ive:
> settings.
Actually I proposed to use such a low value in the global settings
/photons/ block.
The general global settings adc_bailout, as well as radiosity
adc_bailout, should both be ok with more conservative values.
Date: 10 Jan 2014 07:11:22
Message: <52cfe36a$1@news.povray.org>
>> settings.
> /photons/ block.
Right. I missed that, as I am now entering unknown territory ;-)
I have some read-up on the matter to do, and some testing.
Date: 10 Jan 2014 07:17:02
Message: <52cfe4be$1@news.povray.org>
> me, too.
I agree and, as far as I am concerned, I do not want to compensate.
Increasing luminosity helps too while keeping the balance between light
and dark within acceptable limits.
> lower).
Well, from my latest render (not included here) I must say that leaking
also appears with recursion_limit 2.
Iirc, Christoph Hormann treated this problem in Megapov with a radiosity
patch.
Subject: Re: LanuHum Global Test image - wip 3
Date: 11 Jan 2014 07:11:37
Message: <52d134f9@news.povray.org>
Does not seem much but I got rid of the light leaking. Following was done:
- meshes (walls, archs, windows) inc files through Poseray export as obj
files (weld vertices and recalculate normals);
- in Silo: giving thickness to the walls with the Shell utility (this
probably exists also in Blender?);
- in Silo: closing of the arch object and extending it a little bit
above the ceiling;
- in Silo: lowering the sky-windows which were /floating/ just above the
building letting light leak in-between;
- saving the different objects as obj files and through Poseray export
to POV as mesh2 files (recalculate normals);
- in the POV scene: replace the mesh{} objects by the mesh2{} ones;
Everything seems now to be in place to tackle the photons and caustics.
Download 'test.png' (558 KB)
Preview of image 'test.png'
Date: 11 Jan 2014 08:25:00
Message: <web.52d1453971949f9a7a3e03fe0@news.povray.org>
Povray slows down the miscalculation if matrix is used
I didn't find the solution to calculate normal*matrix for mesh2
Maurice Raybaud it is possible will make
Date: 11 Jan 2014 09:42:42
Message: <52d15862$1@news.povray.org>
Am 11.01.2014 13:11, schrieb Thomas de Groot:
Seems much to me.
BTW before you start a final render: your aspect ratio for the image is
wrong!
-Ive
Date: 11 Jan 2014 10:14:14
Message: <52d15fc6$1@news.povray.org>
>> done:
> Seems much to me.
I know ;-) it is a fair lot of work for only little specks of light, but
the result is essential of course.
> wrong!
hmm... 1000x800 and using all camera parameters as given by the original
scene file. I shall change the right to -x*image_width/image_height and
see if that makes any difference.
Presently, I have difficulties with photons/caustics. THey do not show
on the ceiling...
Ultimately, I shall add a media to the scene to show some dust in the
atmosphere, but not too much.
Date: 11 Jan 2014 10:31:15
Message: <52d163c3@news.povray.org>
not essential presently, I used mesh2{} because Poseray does not export
to mesh{} (well, an older version does, but I prefer mesh2 anyway). The
result should be the same. One of the advantages of mesh2{} is that
/materials/ are given to the objects, so there are more possibilities
especially for translucent objects).
Date: 11 Jan 2014 10:34:59
Message: <52d164a3@news.povray.org>
>> wrong!
Hmmm, yes, that makes indeed a difference.
Download 'test.png' (133 KB)
Date: 11 Jan 2014 10:54:35
Message: <52d1693b@news.povray.org>
Am 11.01.2014 16:14, schrieb Thomas de Groot:
well, 1000 / 800 makes 1.25 and I bet 100 PovCoins this is not what you
have. The squeezed chairs do give it away.
> on the ceiling...
I cannot add anything that's not already in the docs: you need a photon
block within global_settings, make the main light source emit them, make
the water (and Suzanne) a target and shoot a few millions of them... and
do not forget to turn collect off for objects where it is not important
to speed up the render.
Thomas, you are a patient one ;)
But what *I* really would like to see is Suzanne made of tinted glass.
-Ive
Subject: Re: LanuHum Global Test image - wip 3 photons?
Date: 11 Jan 2014 10:55:47
Message: <52d16983$1@news.povray.org>
I have difficulties with photons/caustics. If you compare with
Christoph's image of the scene, you will see there how the water plays
on the ceiling. I cannot reproduce this.
I am using the following settings:
global_settings:
   photons {
     spacing 0.01
     gather 20, 100
     autostop 0
     jitter 0.5
     max_trace_level 15
     adc_bailout 1/10e5
objects:
object {suzanne_ob
   interior {
     ior 1.5
     dispersion 1.05
     dispersion_samples 10
     caustics 1.0
     //fade_distance 5
     //fade_power 2
   photons {
     target
     refraction on
     reflection on
     collect off
object {water_ob
   interior {
     ior 1.3
     dispersion 1.05
     caustics 1.0
     //fade_distance 5
     //fade_power 2
   photons {
     target
     refraction on
     reflection on
     collect off
light_source:
     photons { refraction on reflection on }
glass surfaces:
photons {pass_through}
How can I tweak these parameters?
Date: 11 Jan 2014 11:02:29
Message: <52d16b15$1@news.povray.org>
Yes, the difference comes from:
original right: <-1.0799999982118607, 0, 0> results in squeezed chairs
my (new) right: -x*image_width/image_height gives the chairs correctly
I suppose passing from Blender to POV introduces differences.
>> on the ceiling...
See my post below.
I am, if the render time remains manageable. Somehow, presently I am at
about 1 hour.
yes, that is still something I need to tweak.
Date: 11 Jan 2014 14:00:37
Message: <52d194d5$1@news.povray.org>
Am 11.01.2014 16:55, schrieb Thomas de Groot:
Don't forget to make the ceiling windows pass_through.
Date: 11 Jan 2014 16:26:40
Message: <52d1b710$1@news.povray.org>
Le 14-01-10 04:06, Thomas de Groot a écrit :
> Just for a quick test I switched off the normals here. I doubled again
> the luminosity and now the shadowy parts come out better.
> I wonder if the leaking along the edges cannot be remedied by better
> meshes. The present ones are of very low resolution (a pillar face is
> just two triangles for instance). That might give problems. I am going
> to have the walls through Silo and process them a bit.
> Thomas
A pilar face using only 2 triangles don't mean low quality as those two
are realy all that is needed.
Some slight beveling of the edges /may/ help some.
Another solution is to add something behind the mesh, or give it some
actual thickness, especialy near the corners where some radiosity
samples can sample areas of the bright sky or that receive direct
illumination.
Date: 12 Jan 2014 03:06:59
Message: <52d24d23$1@news.povray.org>
Yes, I thought so too after I posted :-)
Editing the object, it appears that there /is/ some bevelling present on
the arches and pillars.
> illumination.
Has been done since.
Date: 12 Jan 2014 03:12:04
Message: <52d24e54@news.povray.org>
They are.
Subject: Re: LanuHum Global Test image - wip 4
Date: 12 Jan 2014 07:14:01
Message: <52d28709@news.povray.org>
After improving suzanne's and the water's finish, and adding a light
scattering media to the air, this is what I get.
I think I need to move the light_source a bit again. Moving the
skylights increased the shadows on the water surface.
Over all, I am well satisfied but before going for the final render I
would like your opinions.
Download 'test.png' (427 KB)
Date: 12 Jan 2014 11:15:01
Message: <web.52d2bea3eff00a397a3e03fe0@news.povray.org>
> Thomas
I don't understand, what is reflected in a mirror in a floor? From what there
the washed-away light spot?
Date: 12 Jan 2014 11:50:00
Message: <web.52d2c7a271949f9a91114470@news.povray.org>
> above the ceiling;
> Thomas
Looking really nice Thomas, I like the subtle media beams! Don't forget to add
pass_through to the photon blocks for the skylights and the water (to allow
reflected caustics on arch and ceiling).
I'm having a go at this myself and found that the walls had nearly 10,000 stray
verts in the mesh that needed merging; and letting PoseRay re-process those
Blender meshes makes the textures so much easier to manage! WIP currently
rendering...
Cheers,
Rob
Date: 12 Jan 2014 12:53:02
Message: <52d2d67e$1@news.povray.org>
Am 12.01.2014 17:11, schrieb LanuHum:
>> Thomas
 From what I understand, that's blurred reflections on the floor tiles,
using an approach dubbed "micronormals": You use standard specular
reflection on a texture, but also add some normal perturbation (using a
pattern with some randomness), scaled so small that the structure is
smaller than the image resolution; last not least you also make sure
there is sufficient oversampling (often via a bit of focal blur, or
plenty of anti-aliasing; sometimes it is also done by using an average
texture comprised of countless duplicates of the base texture with
random differences in the normal perturbation).
Date: 12 Jan 2014 14:14:07
Message: <52d2e97f$1@news.povray.org>
The image is good but shouldn't light source / skylights be in
the same place as the comparison renders for this test scene? It is
hard to compare the images otherwise, especially the water looks very
different with half the basin in shadow.
Date: 12 Jan 2014 15:07:34
Message: <52d2f606$1@news.povray.org>
Am 12.01.2014 13:13, schrieb Thomas de Groot:
Well, those light beams look always nice but I ask myself: do they
really add anything to *this* particular scene.
And where are the caustics on the ceiling, IMO for this scene a more
interesting effect - and your photon settings look fine to me, no idea
whats wrong there, I did get them immediately.
-Ive
Date: 12 Jan 2014 16:17:20
Message: <52d30660@news.povray.org>
Am 12.01.2014 09:12, schrieb Thomas de Groot:
> They are.
What's your adc_bailout setting in the global photons block?
Date: 12 Jan 2014 18:20:01
Message: <web.52d3226ceff00a3991114470@news.povray.org>
> -Ive
Thomas, if this helps, I have the objects setup like this to get the proper
caustics (and "collect off" increased render speed x4):
#include "frame_side_object.inc"
object {
   frame_side_ob
   photons {
      pass_through
      collect off
#include "frame_top_001_object.inc"
object {
   frame_top_001_ob
   photons {
      pass_through
      collect off
#include "frame_top_object.inc"
object {
   frame_top_ob
   photons {
      pass_through
      collect off
#include "water_object.inc"
object {
   water_ob
   photons {
      target
      reflection on
      refraction on
#include "pool_object.inc"
object {
   pool_ob
   photons { collect on }
#include "arc_object.inc"
object {
   arc_ob
#include "walls_object.inc"
object {
   walls_ob
www.McGregorFineArt.com
Date: 13 Jan 2014 03:01:26
Message: <52d39d56$1@news.povray.org>
They don't, I agree. What is more, with the light_source again in the
right place, there is a very distrubing shadow bar across the image
falling from the skylight.
There still are some things I am doing wrong. Robert's code (see his
post) shows me were I went wrong.
Date: 13 Jan 2014 03:04:39
Message: <52d39e17$1@news.povray.org>
Yes, I still have not fully understood the working of photons. Thanks
for the code you posted later, that is going to help.
> rendering...
Indeed. All vertices had to be merged in the objects. I only did that
for the relevant objects I needed to change however. I left the others
alone.
Looking forward to your version!
Date: 13 Jan 2014 03:07:48
Message: <52d39ed4$1@news.povray.org>
>> what there
That is right. I used micronormals here. Just a very small granite
normal. In a future version I intend to use UberPOV's blurred
reflections instead.
Date: 13 Jan 2014 03:09:57
Message: <52d39f55$1@news.povray.org>
Thanks a lot Robert! I can see were I go wrong in my code!
I am in the learning process as these are my first time ever photons :-)
Subject: Re: LanuHum Global Test image: wip 4b
Date: 13 Jan 2014 04:05:24
Message: <52d3ac54@news.povray.org>
Got them!
A crude render as test but I got the caustics right now. They show on
the ceiling.
Thanks to Robert showing me the way.
Comments?
Download 'test.png' (408 KB)
Subject: Re: LanuHum Global Test image - wip 4c
Date: 13 Jan 2014 04:19:35
Message: <52d3afa7@news.povray.org>
Adding some environment...
Download 'test.png' (417 KB)
Date: 13 Jan 2014 04:55:01
Message: <web.52d3b786eff00a3967c13c250@news.povray.org>
> object {
>    walls_ob
I thought all objects defaulted to "collect on" anyway? Could this be where I
have gone wrong with photons in the past?
Sean
Date: 13 Jan 2014 06:04:29
Message: <52d3c83d@news.povray.org>
"Thomas de Groot" <tho### [at] degrootorg> wrote in message
news:52cd5186@news.povray.org...
> With only a few necessary corrections (see p.general) this is a first
> brutish render of the test scene provided by LanuHum. Added basic
> radiosity too.
> Thomas
First attempt.
I am replacing some of the objects with ones more suitable for Pov.
 Sphere{}.
 Isosurface for water.
 Copies for Mesh2{}: chair, floor tiles.
Todo: CSG door, shelf, and pool.
Comments welcome:
Stephen S
Download 'New_test_pov_b.png' (361 KB)
Preview of image 'New_test_pov_b.png'
Date: 13 Jan 2014 07:10:44
Message: <52d3d7c4$1@news.povray.org>
>> object {
>>     walls_ob
I thought so too indeed. It looks like they do /not/ default to this. As
far as I know, this is not mentioned in the docs.
Date: 13 Jan 2014 07:11:27
Message: <52d3d7ef$1@news.povray.org>
> Thomas
Note that the use of fog{} is killing the caustics.
Date: 13 Jan 2014 07:41:46
Message: <52d3df0a$1@news.povray.org>
Am 13.01.2014 10:53, schrieb s.day:
>> object {
>>     walls_ob
Indeed. POV-Ray help in chapter 3.4.4.4.2 says so and therefor I didn't
see anything wrong with Thomas' code. And POV did behave like this back
in the past.
I was just a lucky to add collect on/off anyway anywhere.
-Ive
Date: 13 Jan 2014 07:46:08
Message: <52d3e010$1@news.povray.org>
> in the past.
Maybe the default has been broken then?
Date: 13 Jan 2014 08:04:20
Message: <52d3e454@news.povray.org>
>> radiosity too.
>> Thomas
> First attempt.
>   Sphere{}.
> Comments welcome:
Still too dark but that can be amended easily. All objects do not need
to be replaced by mesh2{}, only those which need proper tweaking for
photons and such but it is a rewarding exercise nonetheless.
a water isosurface might be a good move indeed...
Date: 13 Jan 2014 13:20:02
Message: <web.52d42db071949f9a91114470@news.povray.org>
Okay, here's an attempt I'm finally happy enough with to post.
I added a third chair after fixing the broken chair mesh, but then decided to
just keep the rest of the meshes in the original versions for better comparison
with the other render engines. I did instance the walls and scale up 1.001 to
eliminate the light-leaking.
Thanks to Christoph and Thomas for the proper light position and tips about
wonky materials and radiosity settings.
Download 'rwm_lanuhum_wip3.png' (2531 KB)
Preview of image 'rwm_lanuhum_wip3.png'
Date: 13 Jan 2014 13:55:52
Message: <52d436b8@news.povray.org>
Am 13.01.2014 13:10, schrieb Thomas de Groot:
>>> object {
>>>     walls_ob
>> where I
Yet they do.
Date: 13 Jan 2014 16:00:00
Message: <web.52d452f7eff00a3991114470@news.povray.org>
> > in the past.
> Thomas
collect on /is/ supposed to be the default, and Christoph says it still is.
Regardless, I too have had many weird photon issues in the past, so when using
multiple transparent/reflecting/refracting surfaces I typically specify on or
off in each photon block just for my own sanity in optimizing render times.
Date: 14 Jan 2014 03:07:52
Message: <52d4f058$1@news.povray.org>
I find it interesting how each individual interprets the scene
differently. Good work indeed.
One comment I could make perhaps is that the sky seems to be all around
the building with no ground plane present. I think this influences the
lighting of the interior.
Date: 14 Jan 2014 04:06:24
Message: <52d4fe10$1@news.povray.org>
Another comment (on the geometry): You can see light leaking around the
skylights. This is due to their position /above/ the building, leaving a
thin space in between.
Date: 14 Jan 2014 05:55:00
Message: <web.52d516a720fca3a570319e940@news.povray.org>
> Thomas
The Mesh2{} comment was more for the use of copies.
Stephen S
Date: 14 Jan 2014 05:55:01
Message: <web.52d5173820fca3a570319e940@news.povray.org>
"StephenS" <stephen@nospam> wrote:
> First attempt.
>  Sphere{}.
Door and pool have now been replaced.
Second try.
Comments welcome:
Stephen S
Download 'new_test_pov_c.png' (456 KB)
Preview of image 'new_test_pov_c.png'
Subject: Re: LanuHum Global Test image - my final render
Date: 14 Jan 2014 07:12:38
Message: <52d529b6@news.povray.org>
I can continue tweaking parameters, but I think this is about the best I
can produce. So here is my final image.
Render time: 1h 8', using 6 threads and +a0.01, version 3.7.
Download 'test.png' (588 KB)
Date: 14 Jan 2014 09:10:03
Message: <web.52d5440c20fca3a591114470@news.povray.org>
Yes, I didn't really think about that, my building is just floating in space;
I'll add a ground plane/fog and see how that works out.
I'm not sure why this scene is so compelling - I can't stop playing with it...
here's a detail render of the caustics in and around the tub.
Now, maybe a better texture and some SSLT on that tub....
Download 'rwm_lanuhum_wip3_detail.png' (2593 KB)
Preview of image 'rwm_lanuhum_wip3_detail.png'
Date: 14 Jan 2014 10:13:52
Message: <52d55430$1@news.povray.org>
True. There are a lot of possibilities with this scene. It is an
excellent test ground for different things: aa, photons, sslt indeed,
glass and metal, (blurred) reflections...
I stop now to do other interesting things but I may come back later at
least as a training ground.
