POV-Ray : Newsgroups : povray.binaries.images : MSOCP Server Time
30 Jul 2024 00:21:05 EDT (-0400)
  MSOCP (Message 1 to 8 of 8)
Subject: MSOCP
Date: 8 Jul 2013 09:40:01
Message: <web.51dabfc874004c66c2d178100@news.povray.org>
You guessed it, melting sphere on a checkered plane..
Just trying out an SSLT render, and I thought isosurfaces/media were slow! It
is not too bad if I just use AA as in this sample but if I throw in a bit
of focal blur the render times skyrocket when it hits the SSLT object. However,
I do like this feature so now need to think of a good scene to use it in.
Sean
Download 'b.png' (360 KB)
Preview of image 'b.png'
Subject: Re: MSOCP
Date: 8 Jul 2013 10:15:05
Message: <51dac969$1@news.povray.org>
The snowball looks perfect.
I know what you mean. It is the reason why I generally stay away from
those combinations. I just am not patient enough to wait, especially
during the try-out phase where you need to fine-tune the settings.
Subject: Re: MSOCP
Date: 15 Jul 2013 07:15:01
Message: <web.51e3d8a09b3b97d0ed29e82f0@news.povray.org>
> Sean
Wow! indeed, would you by any chance agree to share the code for this material?
If it still looks good on our test objects, I would love to include it with our
sample materials here:
http://wiki.blender.org/index.php/Extensions:2.6/Py/Scripts/Render/POV-Ray#Sample_Materials
my idea would be to switch the current snow material I made with this one and
rebrand the former one as "iceberg" after a few tweaks. Or maybe keep both snows
as one for close up and the other for backgrounds, depending on tests.
In any case, feel free to use/modify the materials already there,they only need
a few changes of size and coordinate system to be used outside of Blender's
povray exporter.
Download 'snowmaterialsample.png' (236 KB)
Preview of image 'snowmaterialsample.png'
Subject: Re: MSOCP
Date: 15 Jul 2013 19:20:01
Message: <web.51e482779b3b97d05bfe13270@news.povray.org>
The texture is really simple, it only looks any good due to the SSLT settings
which are fairly standard but take a long time to render (several hours with
radiosity and SSLT enabled).. Also the lighting for this render was a mix of a
HDR probe and lightsource (to get the small specular highlights).
The texture and isosurface snowball are below.
#declare useRad=2; // 1=load 2=save
#declare radQuality=5; // 1-10 1=low 10=high
#declare useSubSurface=1;
global_settings {
#if(useSubSurface)
  mm_per_unit 15
  subsurface { samples 100, 20 radiosity on }
#if(useRad)
ambient_light 0
  radiosity {
#if(useRad = 2)
    pretrace_start 0.08           // start pretrace at this size
    pretrace_end   0.001           // end pretrace at this size
#if(useRad = 1)
    pretrace_start 1           // start pretrace at this size
    pretrace_end   1           // end pretrace at this size
    always_sample off  //
    count 20*radQuality 50*radQuality
    nearest_count 10+(radQuality) 10+(radQuality/2)               /
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    adc_bailout 0.01/2
    error_bound 1.5-(radQuality/10)
    recursion_limit 2
    brightness 1
    normal on
#declare snowTex = texture {
pigment { rgb <1, 1, 1> }
finish { diffuse albedo 0.7 specular albedo 0.2 roughness 0.0002 brilliance 0.9
reflection { 0.005, 0.05 fresnel on } conserve_energy
#if(useSubSurface)
      subsurface { translucency <2.95,3.0,3.1> }
normal { granite 0.2 scale 0.005 }
// iceTex
#declare iceTex1 = texture {
pigment { rgbf <1, 1, 1, 0.3> }
finish { diffuse albedo 0.1 specular albedo 0.1 roughness 0.05 brilliance 2.5
reflection { 0.005, 0.01 fresnel on } conserve_energy
#if(useSubSurface)
subsurface { translucency <29.5,30,31> }
normal { granite 0.1 scale 0.01 }
#declare iceTex2 = texture {
pigment { rgbf <1, 1, 1, 0.1> }
finish { diffuse albedo 0.5 specular albedo 0.15 roughness 0.02 brilliance 1.2
reflection { 0.005, 0.03 fresnel on } conserve_energy
#if(useSubSurface)
normal { granite 0.15 scale 0.008 }
#declare Snowball=function {
      wrinkles
      scale 0.25
      turbulence 0.2
      lambda 0.5
      omega 0.75
      color_map {
          [0, rgb 0]
          [1, rgb 1]
isosurface {
    function{
       f_sphere(x,y,z,1)-(Snowball(x,y,z).gray)*0.075
    contained_by {sphere {0,2.5}}
    max_gradient 2.07
    hollow
    gradient x
    texture_map { [ 0.0 iceTex1 scale 0.33 ] [ 0.45 iceTex2 scale 0.33 ] [0.75
snowTex scale 0.33] } scale 3 turbulence 0.275  translate <-1.7, 0, 0>  }
  interior { ior 1.31 }//fade_distance 1 fade_power 1001
    scale 3
    rotate <0,0,50> rotate <0, -30, 0>
    translate <-0.5, 3.4, -16>
Sean
Subject: Re: MSOCP
Date: 17 Jul 2013 14:12:01
Message: <51e6de71$1@news.povray.org>
> <Snip >
As you need to use version 3.7 or above, you no longer need to use some
old tricks.
You can remove this:
ambient_light 0
as the ambient component of finishes are now totaly turned off in any
radiosity scene.
To me, this:
looks mostly overkill.
You probably can use this instead and get faster renders:
nearest_count 10+(radQuality) 5
Snow is more translucent in the red than in the blue.
Subject: Re: MSOCP
Date: 17 Jul 2013 15:25:01
Message: <web.51e6ef7d9b3b97d05bfe13270@news.povray.org>
> old tricks.
> ambient_light 0
> radiosity scene.
Thanks, was not aware of this.
> To me, this:
Thanks again, any ideas on the correct ratio/values for this?
Sean
Subject: Re: MSOCP
Date: 18 Jul 2013 14:40:33
Message: <51e836a1@news.povray.org>
>> old tricks.
>> ambient_light 0
>> radiosity scene.
>> To me, this:
> Sean
Not sure, but light transmited through snow tend to take a pinkish tint.
Your value is: translucency <2.95,3.0,3.1>
I think that something like <2.98, 2.97, 2.94> may be more correct.
Subject: Re: MSOCP
Date: 24 Jul 2013 07:55:01
Message: <web.51efc0039b3b97d0ed29e82f0@news.povray.org>
> >> old tricks.
> >> ambient_light 0
> >> radiosity scene.
> >> To me, this:
> > Sean
Thanks to both of you Sean and Alain, I just launched a render with settings
adapted for Blender (for using with mesh intead of isosurface and under any view
angle, I used the texturemap inside an aoi pattern rather than gradient). I'll
probably have to change the scales as well after this first attempt completes.
