POV-Ray : Newsgroups : povray.binaries.images : Probably I'm just in fact too stupid... Server Time
29 Jul 2026 01:18:30 EDT (-0400)
  Probably I'm just in fact too stupid... (Message 13 to 22 of 22)
Subject: Re: Probably I'm just in fact too stupid...
Date: 26 Nov 2009 17:38:40
Message: <4b0f0370@news.povray.org>
High!
Alain wrote:
> You have TWO (2) medias. An emissive one and a scattering one.
Now I removed the emissive media...
> You did NOT reduce the density of your scattering media, and that is
> your problem.
After I adapted the scattering media density reciprocally to the scale
(i. e. 1/36800) I got extremely faint transparent rings - both with and
without absorption 1/36800, see first two images.
When I increased scattering density to 1/368, the rings became more
visible - but still almost black on the unlit side, with some bizarre
geometry showing up on the planet's night side (see third image)!
Could this be an effect of using filter in the color_map?
Here is the code for the last image:
global_settings
   max_trace_level 10
union
   sphere
     0, 1
     texture
       pigment { color rgb <0.6, 0.4, 0> }
       finish { ambient 0.02 diffuse 1 brilliance 0.8 }
   difference
     cylinder
       <0, -0.001, 0>, <0, 0.005, 0>, 3.68
     cylinder
       <0, -0.0011, 0>, <0, 0.0011, 0>, 1.75
     hollow
     pigment { rgbt 1 }
     interior
       media
         // emission 1/36800
         scattering
           5, 1/368
           // eccentricity -0.4
           // extinction 1
         // absorption 1/36800
         density
           cylindrical
           color_map
             [0 rgbf <1, 0.8, 0.7, 0.2> ]
             [0.1 rgbf <1, 0.8, 0.7, 0.2> ]
             [0.1 rgbf <0.1, 0.3, 0.1, 0.5>]
             [0.17 rgbf <0.1, 0.3, 0.1, 0.5>]
             [0.17 rgbf <0.85, 0.89, 0.94, 0.3>]
             [0.18 rgbf <0.85, 0.89, 0.94, 0.3>]
             [0.18 rgbf <0.99, 0.93, 0.45, 0.4>]
             [0.26 rgbf <0.99, 0.93, 0.45, 0.4>]
             [0.26 rgbf <0.5, 0.23, 0.61, 0.5, 0.4>]
             [0.36 rgbf <0.5, 0.23, 0.61, 0.5, 0.4>]
             [0.36 rgbf <1, 0.92, 0.93, 0.3>]
             [0.45 rgbf <1, 0.92, 0.93, 0.3>]
             [0.45 rgbf <0, 0, 0, 1>]
           scale 3.68
   rotate <2, 7, 0>
   scale 10000
   translate z*50000
light_source
   <500000, 2500, 5000>
   color rgb 1
camera
   location <1.5, 1.5, 0.12>
   look_at 1.5
   angle 60
See you in Khyberspace!
Yadgar
Download '2009-11-25 media test, take 44.jpg' (8 KB) Download '2009-11-25 media test, take 45.jpg' (8 KB) Download '2009-11-25 media test, take 46.jpg' (10 KB)
Preview of image '2009-11-25 media test, take 44.jpg'
Preview of image '2009-11-25 media test, take 45.jpg'
Preview of image '2009-11-25 media test, take 46.jpg'
Date: 26 Nov 2009 18:15:39
Message: <4b0f0c1b@news.povray.org>
> High!
> Jaime Vives Piqueres wrote:
>> If you scale UP the container, you have to scale DOWN the media
>> strength! Just try .05 instead 1338181 and you will see the effect...
>> I just tried it and works.
> With me, it didn't work at all... still the unlit side is completely
> dark! And when I tried the same combination of scattering and absorption
>  on the real Saturn scene, where the rings are about 11 units wide (then
>  respectively 1/11 for scattering and absorption strength), the entire
> ring (when viewed upon from the lit side) remains invisible, although
> its shadow is visible on the planet's body!
   Sorry, I did a poor reading, and for the images I assumed too quickly your
problem was just the ultra-bright media... trying with your code on the last
message, I see that using extinction 0 gives the effect you are looking for.
But I still don't know very well why it doesn't works with the default,
teorically realistic, value of 1.
> watching TV shows instead of overburdening my feeble chicken brain with
> such monstrous tasks like raytracing...
   I've a poor brain too, but I discovered it doesn't matters if you have the
power of unlimited "trial&error" at your disposal... ;)
P.S.: You still have the rgbf on the media, which doesn't works as you
think... and you even supplied some of the entries with 5 components colors!
(although it really doesn't matters for your problem).
http://www.ignorancia.org
Date: 26 Nov 2009 19:11:58
Message: <4b0f194e@news.povray.org>
High!
quickly your
the last
looking for.
Yes, that's quite logical... I tried it, and it at least yielded roughly
the result I want to achieve in the long run! Thank you for the tip...
perhaps I'll up the extinction value to, let's say, 0.1 or 0.15, as the
unlit side is of course somewhat darker than the lit side, irrespective
of light filtering through...
...but I also found out, that with an exactly reciprocal scattering
strength, the rings become too faint - so I instead made it ten times
stronger (i. e. 1/3680 rather than 1/36800) - see attached images (first
image: unlit side, second image: lit side)!
But, to bring my problem to a "meta level": although I now work more or
less frequently since early 1996 with POV-Ray, I never got much beyond
beginners' skills - since 2000 I keep track of this group, and I've seen
thousands of incredibly sophisticated works (@Jaime Vives Piqueres: for
example your autobahn scene!), and when I compare them to my puny
primitive scenes, I'm close to cry for an euthanasia injection, as I'm
obviously virtually unable to learn from my mistakes... and I HATE
myself for being so dysfunctional!
And I'm really not sure whether having more hobbies than just POV-Ray
(i. e. astronomy, electronic music, Afghanistan...) is the reason... to
me it appears that not so few people who regularly contribute pictures
here have access to, hmmm, time-compressing drugs which allow them to
learn and work 72 hours a day...
Yadgar
Download '2009-11-26 media test, take 47.jpg' (13 KB) Download '2009-11-26 media test, take 48.jpg' (13 KB)
Preview of image '2009-11-26 media test, take 47.jpg'
Preview of image '2009-11-26 media test, take 48.jpg'
Date: 26 Nov 2009 19:35:02
Message: <web.4b0f1e5d9422158050814e370@news.povray.org>
Some of the artifacts you are seeing is probably a result of self-shadowing.  To
test this, try varying the angle between the rings and sun a little bit, then
test a different extinction value, probably 0.5
 You should consider removing the filtering component also, as scattering media
is inherently filtering, and the thickness or brightness comes from the color's
distance from black.  Also note that close color control is more easily done by
splitting the single scattering media into a scattering media with no
extinction, and an absorption media that has a different color_map.
The reason for this is that the color scattered is also the color absorbed, and
it can be easier to control the color closely if you scatter the color you wish,
but absorb all colors equally.  This can also be done in reverse - scatter all
light (white), but absorb the color opposite of the color you want the media to
be (this may be closer to what happens in real life).
Anyway, here is some code I made from yours.  It uses a simple macro to createa
a more complex density that gives the rings from "grain" (that probably wouldn't
be visible from this distance, but looks neat IMHO).
//--------------- beginning of code
global_settings
   max_trace_level 10
#macro wrink(SomeColor, Thickness, ScaleV)
// SomeColor is the color scattered (and absorbed!)
// Thickness defines the ratio of the color supplied as compared to empty
(black)
// ScaleV determines the size of the wrinkle pattern, and therefore the grain
size.
wrinkles
scale ScaleV
color_map{
    [0.00 color rgb SomeColor ]
    [Thickness color rgb <0,0,0>   ]
    [1.00 color rgb <0,0,0>   ]
#declare ShowRings = on;
union
   sphere
     0, 1
     texture
       finish { ambient 0.00 diffuse 1 brilliance 1 }
#if( ShowRings )
   difference
     cylinder
     cylinder
     hollow
     pigment { rgbt 1 }
     interior
       media
         //emission 1/500
         scattering
           1, 1/200
           extinction 0.5 // 1.00 is also ok
         density
           cylindrical
           density_map
             [0.00 rgbf <1.00, 0.80, 0.70, 0.20> ]
             [0.10 rgbf <1.00, 0.80, 0.70, 0.20> ]
             [0.10 rgbf <0.10, 0.30, 0.10, 0.50> ]
             [0.17 rgbf <0.10, 0.30, 0.10, 0.50> ]
             [0.17 rgbf <0.85, 0.89, 0.94, 0.30> ]
             [0.18 rgbf <0.85, 0.89, 0.94, 0.30> ]
             [0.18 rgbf <0.99, 0.93, 0.45, 0.40> ]
             [0.26 rgbf <0.99, 0.93, 0.45, 0.40> ]
             [0.26 rgbf <0.50, 0.23, 0.61, 0.50> ]
             [0.36 rgbf <0.50, 0.23, 0.61, 0.50> ]
             [0.36 rgbf <1.00, 0.92, 0.93, 0.30> ]
             [0.45 rgbf <1.00, 0.92, 0.93, 0.30> ]
             [0.45 rgbf <0.00, 0.00, 0.00, 1.00> ]
                [0.00 wrink( <0.00, 0.00, 0.00> * 0.00, 0.5, 10/10000) ]
              #local I = 0;
              #local MaxI = 200;
              #local rs1 = seed(3240);
              #while( I < MaxI )
                // add bands of lighter and darker rings
                  #if( !mod(I,12) ) #local RandTrend = rand(rs1); #end
                [0.00 + 0.45*I/MaxI
                    wrink(
                        <1.00 - 0.20*rand(rs1), 1.00 - 0.10*rand(rs1), 1.00 -
0.05*rand(rs1)> * (0.5 * rand(rs1) + 0.5) * RandTrend,
                        (0.25 * rand(rs1) + 0.5),    (2+rand(rs1)*18)/10000
              #local I = I + 1;
                [0.45 wrink( <0.00, 0.00, 0.00> * 0.00, 0,  4/10000) ]
           scale 3.68
   rotate <15, 7, 1>
   scale 10000
   translate z*50000
   translate y*-2500
light_source
   color rgb 1
camera
   look_at 1.5
   angle 60
//--------------- end of code
    HTH
 -Reactor
P.S.  Please be aware that this was rendered using the default gamma settings
under 3.7, and the brightness may vary, necessitating different scattering
settings.
Download 'yagdar_news.bmp.dat' (2305 KB)
Date: 26 Nov 2009 19:45:01
Message: <web.4b0f20269422158050814e370@news.povray.org>
Oops!  I just realized I posted the bmp, not the png as I'd intended:
-Reactor
Download 'yagdar_news.png' (420 KB)
Preview of image 'yagdar_news.png'
Date: 26 Nov 2009 19:57:32
Message: <4b0f23fc$1@news.povray.org>
High!
Now as I got at least the planet's shadow on the unlit side of the rings
  correctly, I wonder how I could have different degrees of transparency
within the rings - like it is with the real Saturn. I tried adding a
second density, now with a density_map instead of a color_map - but the
only thing I observed were different colors, while the transparency
remained uniform across all ring bands.
What is the difference between a color_map and a density_map within a
density statement?
Could I achieve different transparencies by adding an absorption media
with its own density_map? What values of that density map would affect
transparency?
Yadgar
Date: 26 Nov 2009 20:30:01
Message: <web.4b0f2aae9422158050814e370@news.povray.org>
=?ISO-8859-1?Q?J=F6rg_=27Yadgar=27_Bleimann?= <yaz### [at] gmxde> wrote:
> High!
> density statement?
> transparency?
> Yadgar
The second density is very different from a second media - Read the
documentation section on multiple density V.S multiple media.
A density_map is comparable to a pigment_map - it allows density entries within
the map.
The level of transparency is more or less a combination between the distance
from black of the color vector and also the initial color vector for the media
type statement.
example:
emission color rgb <1,1,1>
density{ color rgb 0.01 }
is visually identical to this:
emission color rgb <1,1,1> * 0.01
density{ color rgb 1 }
    HTH
 -Reactor
Date: 26 Nov 2009 20:33:27
Message: <4b0f2c67$1@news.povray.org>
High!
> your
> last
> for.
Yes, it did - but only with the test scene, not with the Saturn scene!
With the latter, when using extinction 0, not even the ring shadow is
visible, let alone the rings, at extinction 0.1 I can at least see the
shadow, but still no rings...
The code? Too long and complicated to be posted here, I fear...
Yadgar
Date: 27 Nov 2009 08:50:25
Message: <4b0fd921@news.povray.org>
High!
(9 hours of sleep later)
O.k., I'll try it:
#include "starry_sky.inc" // self-programmed macro to generate a starry
sky sphere according to real astronomical data, 900 stars, configurable
according to camera angle and image resolution
#include "functions.inc" // for eval_pigment()
#declare sc=13347; // 1 POV unit = 13347 kilometres
#declare rs=0; // radiosity flag, 0 = radiosity off
#declare lores=0; // flag for low resolution Saturnian rings (dependent
on camera distance in the future)
#declare F_Standard_Planetary_Surface =
finish
   #if (!rs)
     ambient 0.0001
   diffuse 1
   brilliance 0.8
#declare F_Saturn_Rings =
finish
   #if (!rs)
     ambient 0.01
   diffuse 1
   brilliance 0.05
#declare F_Saturn_Rings_UnlitSide =
finish
   #if (!rs)
     ambient 0.3
   diffuse 5
   brilliance 0.05
#declare cam = 7; // camera mode
// CELESTIAL BODIES OF THE SOLAR SYSTEM DATA
// Column 0: orbital semi-major axis (to the Sun or the respective
planet) in kilometres
// Column 1: radius in x dimension, in kilometres
// Column 2: radius in y dimension, in kilometres (if oblateness is
given then stated as -1)
// Column 3: radius in z dimension, in kilometres (if oblateness is
// Column 4: axial tilt in degrees (planets: relative to orbit around
the Sun, moons: relative to planet's equatorial plane)
// Column 5: orbital inclination in degrees (planets: relative to
ecliptic, moons: relative to planet's equatorial plane)
// Column 6: orbital eccentricity
// Column 7: perihelion argument (degrees; if variable (Earth's Moon)
then stated als -1)
// Column 8: longitude of ascending node (degrees; if variable (Earth's
Moon) then stated als -1)
// Column 9: oblateness (not taken into account if different radii
explicitly stated)
// Column 10: declination of north pole (degrees)
// Column 11: right ascension of north pole (degrees!)
// Column 12: albedo (if irrelevant (Sun) stated as -1)
#declare bodies = array [74][12]
   {           0,     696000,       -1,      -1,	     7.25,     0,
  0,             0,         0,       0.000009,  63.87,   286.125   },
//   0 - Sun
{  1433449370,      60268,    54364,   60268,  26.73,        2.484,
0.055723219, 336.013862,113.642811,-1,       83.537,   40.589    } //
72 - Saturn
// PROVISIONAL PLANETARY POSITIONS (to be replaced later according to
astronomically accurate orbital data)
#declare Pos_Saturn = bodies[72][0]*<sin(radians(157.4)), 0,
cos(radians(157.4))>;
// CAMERA DATA
#switch(cam)
   #case (7) // centered on Saturn, rings oblique view
     #declare camPos = Pos_Saturn + 350000 * <sin(radians(64)), 0,
cos(radians(64))>;
     #declare camLook = Pos_Saturn;
     #declare camAng = 40;
   #break
   #case (7.01) // view through Saturn's D ring
cos(radians(64))>;
     #declare camLook = Pos_Saturn+<10000, -32000, 0>;
     #declare camAng = 5;
   #break
   #case (7.02) // centered on Saturn, view of unlit ring side
     #declare camPos = Pos_Saturn + 350000 * <sin(radians(244)), 0,
cos(radians(244))>;
   #break
// CELESTIAL SPHERE
Stars(6, image_width, camAng, 1.5) // invocation of starry sky sphere macro
#macro SetAxis(dec, ras) // macro for orienting planets
   rotate <bodies[3][4]-(90-dec), 0, 0>
   rotate <0, 90-ras, 0>
light_source // Sun
   0
   color rgb 1
   looks_like
     sphere
       0, 1
       texture
        pigment { color rgb <1, 1, 0.85> }
        finish { ambient 1 diffuse 0 }
       scale bodies[0][1]/sc
       SetAxis(bodies[0][10], bodies[0][11])
// the following three image files can be obtained at
http://www.mmedia.is/~bjj/data/s_rings/index.html
#declare Saturn_Rings_Colors =
pigment
   image_map
     png "solarsys/sat_ring_color_bjoernjonsson.png"
#declare Saturn_Rings_Transparency =
pigment
   image_map
     png "solarsys/transparency_bjoernjonsson.png"
#declare Saturn_Rings_UnlitSide =
pigment
   image_map
     png "solarsys/unlitside_bjoernjonsson.png"
currently not yet working with media! (but that would be another thread
here!)
#declare Ring_Color_Map_1_to_255 =
     color_map
       #declare a=0;
       #while (a<255)
         #declare c=eval_pigment(Saturn_Rings_Colors, <2999/3000-a/1500,
0.5, 0>);
         #declare f=eval_pigment(Saturn_Rings_Transparency,
<2999/3000-a/1500, 0.5, 0>);
         [a*(((140390-74510)/140390)/1500) rgb c filter f.gray]
         #declare a=a+1;
#declare Ring_Color_Map_256_to_510 =
texture
   pigment
     cylindrical
     color_map
       #declare a=255;
       #while (a<510)
0.5, 0>);
         #declare a=a+1;
   finish { F_Saturn_Rings }
#declare Ring_Color_Map_511_to_765 =
texture
   pigment
     cylindrical
     color_map
       #declare a=510;
       #while (a<765)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_766_to_1020 =
texture
   pigment
     cylindrical
     color_map
       #declare a=765;
       #while (a<1020)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_1021_to_1275 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1020;
       #while (a<1275)
0.5, 0>);
         #declare a=a+1;
#declare Ring_Color_Map_1276_to_1500 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1275;
       #while (a<1500)
0.5, 0>);
         #declare a=a+1;
#declare Ring_UnlitSide_Map_1_to_255 =
texture
   pigment
     cylindrical
     color_map
       #declare a=0;
       #while (a<255)
         #declare c=eval_pigment(Saturn_Rings_UnlitSide,
         #declare a=a+1;
   finish { F_Saturn_Rings_UnlitSide }
#declare Ring_UnlitSide_Map_256_to_510 =
texture
   pigment
     cylindrical
     color_map
       #declare a=255;
       #while (a<510)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_511_to_765 =
texture
   pigment
     cylindrical
     color_map
       #declare a=510;
       #while (a<765)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_766_to_1020 =
texture
   pigment
     cylindrical
     color_map
       #declare a=765;
       #while (a<1020)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_1021_to_1275 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1020;
       #while (a<1275)
         #declare a=a+1;
#declare Ring_UnlitSide_Map_1276_to_1500 =
texture
   pigment
     cylindrical
     color_map
       #declare a=1275;
       #while (a<1500)
         #declare a=a+1;
// the actual planet and rings objects
union
sphere // Saturn
   0, 1
   texture
     pigment
       image_map
         jpeg "solarsys/saturn_bjoernjonsson.jpg" // also from
http://www.mmedia.is/~bjj/data/saturn/index.html
         map_type 1
         interpolate 2
     finish { F_Standard_Planetary_Surface }
   scale <bodies[72][1], bodies[72][2], bodies[72][3]>/sc
difference // rings
   cylinder
     <0, -0.11, 0>/sc, <0, 0.1, 0>/sc, 140390/sc
   cylinder
     <0, -0.12, 0>/sc, <0, 0.11, 0>/sc, 74510/sc
   // originally used with the no-media hi-res version of the rings -
I'm currently not sure whether I will able to make use of it also with
media!
   /* cylinder // unlit side!
     <0, -0.15, 0>/sc, <0, -0.1, 0>/sc, 150000/sc
     texture
       cylindrical
       texture_map
         [0                                   Ring_UnlitSide_Map_1_to_255 ]
         [255*(((140390-74510)/140390)/1500)  Ring_UnlitSide_Map_256_to_510]
         [510*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_511_to_765]
         [765*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_766_to_1020]
         [1020*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_1021_to_1275]
         [1275*(((140390-74510)/140390)/1500)
Ring_UnlitSide_Map_1276_to_1500]
       scale 140390/sc
   // ultra-cheap no media version of the rings
   #if (lores)
     texture // low resolution texture: 255 entries in ring color map
       pigment
         cylindrical
         color_map
           #declare a=0;
           #while (a<255)
<509/510-a/255, 0.5, 0>);
             [a*(((140390-74510)/140390)/255) rgb c filter f.gray]
             #declare a=a+1;
         scale 140390/sc
   #else // current media problem!
     hollow
     pigment { rgbt 1 }
     interior
       media
         scattering
           1, 1
           extinction 0.1
         // absorption 0.095
         density
           cylindrical
           // hi-res version (1500 color and transparency levels),
currently not usable with media (but please let's discuss this later on!)
           /* density_map
             [0                                   Ring_Color_Map_1_to_255]
             [255*(((140390-74510)/140390)/1500)  Ring_Color_Map_256_to_510]
Ring_Color_Map_511_to_765]
Ring_Color_Map_766_to_1020]
Ring_Color_Map_1021_to_1275]
Ring_Color_Map_1276_to_1500]
           // current media version
           color_map // preliminary low-res version
             #declare a=0;
             #while (a<255)
               [a*(((140390-74510)/140390)/255) rgb c /* filter f.gray*/]
               #declare a=a+1;
            scale 11
   SetAxis(bodies[72][10], bodies[72][11])
   translate Pos_Saturn/sc
camera
   location camPos/sc
   look_at camLook/sc
   angle camAng
// end of code
Attached image shows current state!
Yadgar
Download 'povsolar.png' (60 KB)
Preview of image 'povsolar.png'
Date: 9 Feb 2010 11:22:37
Message: <4b718bcd$1@news.povray.org>
> quickly your
> the last
> looking for.
Just for completeness' sake: From a theoretical point of view, the
"extinction" parameter is no good for your application, as it only
accounts for light that fails to be transmitted due to being scattered
away. As a consequence, only the scattered colors are attenuated
accordingly.
This is good for modelling media in which the scattering is primarily
due to diffraction or other interference effects (i.e. very small
particles, like molecules or very fine dust), but does not properly
model media containing larger objects in which the scattering is
primarily due to reflection, as in that case all wavelengths will be
obstructed, whether they are reflected (and therefore scattered) or not.
I guess in the case of the Saturn rings, reflection will be the primary
scattering effect, so it should be modeled using...
- an absorbing media to account for the shadowing effect
- a scattering media to account for the reflected light
The scattering media, in this case, should indeed have "extinction 0",
as the extinction component is already accounted for by the absorbing media.
