![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: A geographical question (in a broad sense)
Date: 12 Apr 2009 10:11:52
Message: <49e1f6a8$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
High!
While waiting for help with the rail segments connection problem, I
reactivated a very old project put to hibernation back in 1999: a
full-fledged POV Solar System, this time with astronomically correct
elliptical orbits of planets and moons and a procedural starry
sky_sphere gleaned from star data from a German astronomical atlas
("Karkoschka"), as I found a promising tutorial on computing planetary
positions on the website of a Swedish amateur astronomer
( http://www.stjarnhimlen.se/comp/tutorial.html )
I programmed several camera modes, one of them with the camera pointing
towards a customizable location stated in geographical coordinates on
Earth. As long I left my Earth sphere standing upright in space, this
works fine - but how do I correct the camera's orientation for Earth's
axial tilt (rotate <23.4333, 0, 0>?
I quickly understood that the tilt angle multiplied with the sine of the
longitude (with western longitudes being positive, eastern ones
negative) had to be added to/subtracted from the original latitude - but
how is the longitude adjusted afterwards?
See you in Khyberspace!
Yadgar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am Sun, 12 Apr 2009 16:12:33 +0200 schrieb Jörg 'Yadgar' Bleimann:
Why not do these calculations in cartesian coordinate space? I suppose
you already have a way of converting a point from earth's local
geographical coordinate system to earth's local cartesian coordinate
system. All you have to do with the resulting vector is to rotate it
around earths axis of tilt using vrotate(). Then translate and rotate it
according to earth's position in the solar system and you should arrive
at the point's world coordinates.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: A geographical question (in a broad sense)
Date: 12 Apr 2009 13:05:09
Message: <49e21f45$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
High!
suppose you already have a way of converting a point from earth's local
system.
No, I do not yet... how could I do this?
Yadgar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am Sun, 12 Apr 2009 19:05:55 +0200 schrieb Jörg 'Yadgar' Bleimann:
> High!
> system.
> Yadgar
So... wait, you have a "full-fledged POV solar system" and no way of
converting coordinates? How can you place _any_ object if you do not have
cartesian coordinates which POV uses everywhere?
Take a look at chapter 3 of the tutorial, there the author describes how
to convert geometric and cartesian coordinates.
The author of this tutorial calculates everything in respect of an
observer on the surface of the earth which I think is the traditional
astronomic approach but could pose some difficulties in POV. If you have
already followed this tutorial all along then it would be nonsense to
abandon this way of calculation.
So, how do you for example place the sun? Do you do something like...
object
sun
translate z*suns_distance_from_earth
rotate x*suns_latitude_viewed_from_earth
rotate y*suns_longitude_viewd_from_eart
I think the tutorial suggests doing that but it makes everything
extremely complicated. No wonder the geocentric model is no longer used...
Sorry, I can't come up with an answer to your original question without
knowing how you set up your coordinate system.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 12 Apr 2009 19:57:59
Message: <49e28007$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
High!
have cartesian coordinates which POV uses everywhere?
how to convert geometric and cartesian coordinates.
Which tutorial? I'm not sure whether you mean the official POV-Ray
tutorial coming with the Windows version...
> object
> sun
No, of course not... I use a heliocentric system with the Sun sitting at
the origin! But this doesn't tell me yet how to convert Earth surface
geographic coordinates to cartesian coordinates...
Yadgar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Jörg 'Yadgar' Bleimann nous illumina en ce 2009-04-12 10:12 -->
> High!
> Yadgar
If you start ON the ecliptic, or Earth's orbital plane, at a point based on the
Earth's position at the time of an equinox, you don't have to compensate. In
this case, the rotation is only around a single axis.
Another aproach:
Don't tilt the earth, DO tilt everything else! The end visual result will be
exactly the same.
As the camera is selected with a variable, you can use that same variable to
tilt, or not, your "universe".
I couldn't repair your brakes, so I made your horn louder.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am Mon, 13 Apr 2009 01:58:47 +0200 schrieb Jörg 'Yadgar' Bleimann:
I was referring to this astronomy turotial.
> > object
> > sun
> > rotate x*suns_latitude_viewed_from_earth rotate
Phew :)
Well, these are basically spherical coordinates, so you can use
position = <cos latitude * sin longitude, sin latitude, -sin latitude *
sin longitude> * r
With r being the radius of the earth and longitude and latitude being the
geographical coordinates of the point to look at. It should be enough to
approximate the shape of the earth as a sphere.
Now position is in a local point space with the centre of earth being
located at the origin and the geographical poles being located at <0, r,
0> and <0, -r, 0>. Now you can use POV's built-in vector functions to
tilt this point and translate it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
