POV-Ray : Newsgroups : povray.binaries.images : Cracks Server Time
1 Aug 2024 08:15:27 EDT (-0400)
  Cracks (Message 1 to 9 of 9)
Subject: Cracks
Date: 24 Oct 2008 17:05:01
Message: <web.490238313d121d3bea3236f00@news.povray.org>
In keeping with my usual pursuit of weathering and erosion, I'm trying to
develop a way of putting cracks into objects. Of course one can always be
cunning with imagemaps and pigments/functions, but sometimes a closeup is
required!
To this end, here's my results so far using (tada!) CSG. I'm still playing with
it, so I'll post more pics as and when.
Bill
Download 'crack.jpg' (25 KB)
Preview of image 'crack.jpg'
Subject: Re: Cracks
Date: 24 Oct 2008 18:30:01
Message: <web.49024b741fff3059ea3236f00@news.povray.org>
Looks better with a distressed block.
Mind you, I'd be pretty distressed if I had gouges like that in me.
Download 'crack.jpg' (45 KB)
Subject: Re: Cracks
Date: 24 Oct 2008 21:15:01
Message: <web.490271ff1fff305929925c870@news.povray.org>
Man, your rocks rock! :)
Subject: Re: Cracks
Date: 27 Oct 2008 19:09:29
Message: <49064a29$1@news.povray.org>
beautiful.  really got no clue how you did it.  supposing you are
differencing meshs
Subject: Re: Cracks
Date: 27 Oct 2008 19:45:01
Message: <web.490651d21fff3059ea3236f00@news.povray.org>
> differencing meshs
Correct! I'm using a wedge-sectioned disc perturbed like a heightfield to make
the cuts. It parses and renders very quickly. I'm sure it's also possible with
isosurfaces but I can't immediately see how without vast cunning and
max_gradients. Once I've put it to use and polished it a little I'll probably
upload the macro to the object collection.
Subject: Re: Cracks
Date: 28 Oct 2008 19:07:56
Message: <49079b4c$1@news.povray.org>
Bill Pragnell nous illumina en ce 2008-10-27 19:42 -->
>> differencing meshs
if you want tu use some isosurfaces, it may better to use CSG differences rather
than try to use a single isosurface.
Like substracting the cracks from the isosurface.
difference{
	isosurface{.....}//main object
	object{Crack1}
	object{Crack2}
Database administrators do it with their relations
Subject: Re: Cracks
Date: 29 Oct 2008 05:10:00
Message: <web.490827601fff3059d5b77e4a0@news.povray.org>
> rather than try to use a single isosurface.
> difference{
>  object{Crack1}
>  object{Crack2}
Yes, that's exactly how I'm already doing it, but with meshes. I meant I
couldn't see how to make the crack shape with an isosurface, since my cracks
thin to nothing at the edges (I suppose it wouldn't be too difficult to make a
continuous crack).
OTOH, if I used a difference of isosurfaces it wouldn't parse and render in 15
seconds! :)
Subject: Re: Cracks
Date: 3 Nov 2008 04:00:15
Message: <490ebd9f$1@news.povray.org>
If your interesting cracks can work with unions and other of such
combinations of shapes, then it would be even better than it is already
now...
Subject: Re: Cracks
Date: 3 Nov 2008 05:55:01
Message: <web.490ed79c1fff3059d5b77e4a0@news.povray.org>
> now...
The crack is differenced from the block in the above example. It will work for
any valid parent object, including unions and properly-defined meshes.
(For complex, multitextured unions there will be coincident surface issues, but
this is a problem for any difference{} object - one just has to be careful when
designing unions!)
Bill
