POV-Ray : Newsgroups : povray.binaries.images : Unexpected Abstract (168k jpg) Server Time
30 Jul 2026 21:04:04 EDT (-0400)
  Unexpected Abstract (168k jpg) (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Dunes (64k jpg)
Date: 10 Aug 2008 12:40:44
Message: <489f1a0c$1@news.povray.org>
Thomas de Groot wrote:
> "stbenge" <THI### [at] hotmailcom> schreef in bericht
>> All I'm really doing is using trace() on a height_field and updating the
>> vectors to correspond with the surface normal. The objects are cylinders
>> which grow bigger the longer they are "alive."
> Very neat! Shouldn't cones not be more appropriate than cylinders in this
> context?
Yes, of course, but I wanted to test the proof-of-concept first, and
worry about cone-sphere connection issues later. As it is, this project
isn't working out too well...
Sam
Date: 10 Aug 2008 12:46:03
Message: <489f1b4b$1@news.povray.org>
Tek wrote:
> Ah of course! That's a really nice effect already but I look forward to
> seeing the "Alaska style" results :)
Well, you might be looking forward for a long time, because this
technique isn't working out! All I've managed to do is scratch the
surface down the sides of the height_field. Maybe I should post the
source so other people can look at it. A free, fully-automated erosion
setup producing 16-bit gray scale height maps... that would be nice.
Sam
Subject: Re: Unexpected Abstract (168k jpg)
Date: 10 Aug 2008 12:49:25
Message: <489f1c15@news.povray.org>
Christian Froeschlin wrote:
> stbenge wrote:
>> There seems to be a lack of good, free implementations of it
>> anywhere...
> The basic edition of World Machine is free, although the
> output resolution is then restricted to 512x512. Still, could
> be enough to get the basic erosion done and then add some
> finer details in POV using f_ridge.
That's a good idea, especially since it seems POV 3.7b handles 16-bit
gray scale images better. I discovered yesterday that you can
encapsulate them inside pigment statements without them turning back
into black-green green-red ramp wave nightmares. It makes the
possibilities open up ;)
Sam
Date: 10 Aug 2008 13:40:01
Message: <web.489f27704025b6eceba64d7d0@news.povray.org>
> Sam
Suddenly I am reminded of playing with the 'flow' command in hf_lab in an
attempt to build eroded height fields... I had limited success.  I am very
interested in your technique(s), though.  I've wondered whether a decent
erosion routine could be made into functions for use with isosurface based
landscapes.
-Reactor
Date: 10 Aug 2008 16:12:32
Message: <489f4bb0$1@news.povray.org>
That's been my experience with everything I've tried. World Machine has
good erosion, but the free version limits the size of the map :(
Christian Froeschlin has a good idea for making use of the limited
files. The way POV now handles 16-bit grayscale images makes his idea
even easier to implement, I think.
> I am very
> landscapes.
Anything can be done, but at what cost? Isosurfaces are already slow,
and to incorporate erosion... well, I hope you won't be using your
computer for a while :)
I'd rather make it work with height_fields, but in a more dynamic way
than it is now. I don't know how to do this yet, though.
Sam
Date: 11 Aug 2008 16:15:01
Message: <web.48a09d3e4025b6ec9bfe5600@news.povray.org>
> Sam
The reason why I am interested in isosurfaces as landscapes is their resolution
independence and the fact that they permit overhangs.  As fast and simple as
the heightfield is, certain landscapes cannot be done well with them.  I've
developed a fascination with canyon landscapes recently, and I'm always on the
lookout for alternate techniques.
Attached is a picture created using meshes (which does ok except getting the
texture to match the rock layers is very difficult.)
-Reactor
Download 'cliffscene6ft.jpg' (81 KB)
Preview of image 'cliffscene6ft.jpg'
Date: 12 Aug 2008 03:50:23
Message: <48a140bf$1@news.povray.org>
"Reactor" <rea### [at] hotmailcom> schreef in bericht
news:web.48a09d3e4025b6ec9bfe5600@news.povray.org...
> resolution
> as
> I've
> the
> the
Nice one indeed! Good work.
The texture is indeed not truly right here. UV mapping?
Date: 12 Aug 2008 15:25:00
Message: <web.48a1e2994025b6ec993f4ab30@news.povray.org>
> Thomas
No, unfortunately.  I was having trouble with the Wings uv mapping export at the
time.  I might revisit it at another point, but it was really an experiment into
finding a good way of making overhangs in landscapes.  The next thing I want to
try is something my brother described: a six-sided heightfield in which 6
images determine the shape of the landscape.  I am not sure how to implement
that yet, but that and another idea of blending heightfields and meshes are
things we want to test out and see if they would be feasible.
-Reactor
Date: 13 Aug 2008 04:13:15
Message: <48a2979b$1@news.povray.org>
news:web.48a1e2994025b6ec993f4ab30@news.povray.org...
> at the
> experiment into
> want to
> implement
> are
I see. I have not been overly enthousiastic about Wings uv mapping. Nowadays
I prefer Silo to it (not free, however).
In the past, I have made objects composed of different heightfields, unioned
and differenced together. In particular, a six-sided tower! That works very
well indeed. Overhangs can also be created by heightfields placed
vertically. Differenced with a horizontal heightfield on top, and you have a
(ragged)cliff.
I think that blending of heightfields together and/or with meshes is not
difficult in itself, the problem is the seam which will often show up as a
fairly straight line under some viewing angles. That can be hidden to some
degree by an appropriate global texture or by carefully placed objects in
the line of sight, but it is tricky.
Date: 31 Aug 2008 16:32:05
Message: <48baffc5@news.povray.org>
Some sort of trees seen from below, against the sunny sky..?
