POV-Ray : Newsgroups : povray.binaries.images : More again from the mesh relief macros Server Time
31 Jul 2026 01:48:47 EDT (-0400)
  More again from the mesh relief macros (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: More again from the mesh relief macros
Date: 10 Jun 2008 09:18:53
Message: <imvs44972qb75n462r206oukljgnnt6vtd@4ax.com>
On Tue, 10 Jun 2008 13:44:56 +0200, "Thomas de Groot"
<t.d### [at] internlDOTnet> wrote:
>About your second comment: It might depend on the type of space involved.
>The present setting would be rather claustrophobic, depending on the size
>relationship with human beings.
And the local gravity ;)
>I am not too concerned about this now,
I didn't think so :)
Regards
Date: 10 Jun 2008 10:48:02
Message: <484e9422$1@news.povray.org>
news:web.484e748d7b589d73731f01d10@news.povray.org...
> Not to blow my own trumpet too blatantly, but I think this looks much
> better!
> Although that's partly because you've also got the lichen texturing just
> right
> - it looks really realistic. How do the render times compare?
I am very satisfied with your macros, Bill. It does an excellent job where
my previous experiments with isosurfaces grinded to a halt because of
excessive render time. This scene parses and renders in about 20 minutes, of
which about 12 or 13 is parsing. But of course, the mesh objects are already
done. The parsing of the column segment takes about 3 to 4 minutes with a
resolution of 300.
> "Thomas de Groot" <t.d### [at] internlDOTnet> wrote:
>> took some experimenting until the shape came out right,
> I find this to be the case also.
Size and position of the inner shape are crucial in relation to displacement
depth. And the resolution of course :-)
>> Another difficulty is the base of the column which consists of a flat CSG
>> of
>> torus and cylinder. I have not (yet) been able to approximate that
>> correctly
>> with the macro.
> Don't forget, you can relocate the object to be eroded before calling the
> macro.
> If you move it upwards slightly it may improve things (the underside won't
> look
> nice, but obviously that's not visible!). Another thing to try is the
> inner
> shape - a wide rounded cylinder could well work better than the default
> squashed sphere.
Yes, I am aware of the relocation posibillities and have used those
extensively (min_extent and max_extent are pretty helpful here) and have
used also a cylinder as inner shape which works better for these column
segments.
My problem for the time being is with the column base which consists of a
complex CSG of toruses and cylinders. I probably have to think about a
complex inner shape too, especially as the object is very flat.
Date: 10 Jun 2008 11:55:00
Message: <web.484ea28a7b589d73731f01d10@news.povray.org>
> resolution of 300.
I'm very glad to hear it. Render speed was my primary motivation.
> segments.
Good, I was just checking!
I can't quite make out the cross-section in your image. You could try merging a
vertically-stretched torus with a flat cylinder, if that makes sense. I guess
you've probably thought of all this already... good luck with it, and I'd be
interested in your eventual solution!
Bill
Date: 10 Jun 2008 15:25:10
Message: <484ed516@news.povray.org>
Bill Pragnell napsal(a):
>> resolution of 300.
>> segments.
> Bill
You may try a vertically squashed superellipsoid (rounded cylinder)
the ultimate time-killer:
+a0.0 +am2 +r9
Johnny D
Date: 11 Jun 2008 03:46:23
Message: <484f82cf@news.povray.org>
news:web.484ea28a7b589d73731f01d10@news.povray.org...
> merging a
> guess
> be
I am sorry for the very bad composition of this image, but it is just a test
to show what I am talking about. The red object is the original column base,
the green object is obtained with a cylinder as inner shape. Not good yet,
as I more or less expected. I tried with a scaled down copy as inner shape,
but that was not satisfying either. Next, I want to try with an adapted copy
of the original.
If you want to experiment, I attached the original inc file to this message.
Download 'BP_meshdemo.jpg' (29 KB) Download 'IonianColumnBase.inc.txt' (2 KB)
Preview of image 'BP_meshdemo.jpg'
Date: 11 Jun 2008 06:50:01
Message: <web.484fad347b589d73731f01d10@news.povray.org>
It is not surprising that you're having trouble; there are too many gaps in the
base object. Look at the cross-section in the image below!
You need to close these gaps, especially the thin gap across the centre and the
concave underside. Unless the square peg-hole has some special purpose I'd plug
this too. And don't forget to make sure it's a merge, not a union, or the
internal surfaces get hit first!
A default flattened sphere as inner object should work OK once you've filled the
gaps.
Hope this helps!
Bill
Download 'coltest.jpg' (30 KB)
Preview of image 'coltest.jpg'
Date: 11 Jun 2008 07:31:40
Message: <484fb79c$1@news.povray.org>
news:web.484fad347b589d73731f01d10@news.povray.org...
> in the
Of course! You warned exactly against this, and I never thought to check the
internal aspect of the object! Thank you, Bill, I totally overlooked this
A clear case not only of RTFM, but also of : Apply TFM!
> and the
> plug
> filled the
> gaps.
Yes, I am going to do that...
Date: 11 Jun 2008 10:35:49
Message: <484fe2c5@news.povray.org>
> in the
> base object.
I closed the gaps, and this is the result (with rounded cylinder as inner
shape). The square hole (used for transport of stone blocks and/or anchoring
of column segments) does not really interfere, so I left it in place.
Download 'BP_meshdemo.jpg' (33 KB)
Date: 11 Jun 2008 11:10:01
Message: <web.484fe9dc7b589d73731f01d10@news.povray.org>
Much better :-)
Date: 11 Jun 2008 17:05:00
Message: <web.48503d787b589d7378dcad930@news.povray.org>
> I have also put my teeth into Bill Pragnell's Mesh Approximator macros,
> revisiting the ruined place I had been working on earlier.
I'm just now becoming aware of Bill's macro(s).  (Where have I been??) What an
extremely useful tool.  Nice work, Thomas! Can't wait to see more.
Ken W.
