POV-Ray : Newsgroups : povray.binaries.images : LOTW 040704 (159K) Server Time
4 Aug 2026 14:17:19 EDT (-0400)
  LOTW 040704 (159K) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: LOTW 040704 (159K)
Date: 4 Jul 2004 17:03:19
Message: <40e87097@news.povray.org>
Hi
Great work Jaime.
Only one comment, the trees seem too similar both in shape, variety of
species and distribution. But hell that's just nit picking, it's superb :-)
Mick
Date: 5 Jul 2004 04:44:09
Message: <40e914d9$1@news.povray.org>
de news: 40e7d173@news.povray.org...
Wow
now I know where I'll spend my trekking holydays.
I love the stone structure showing tilted sedimentary rocks layers and
vertically bound erosion.
Just my piece of nitpick: you have (at least) two cloud types: cumulus and
altostratus.
Altostrati should be way higher than cumuli and faded by atmospheric haze
down to horizon.
But it is just in a realistic aiming view, your clouds look as on a
classical painting :-)
Marc
Date: 5 Jul 2004 06:36:04
Message: <40e92f14$1@news.povray.org>
Christoph Hormann wrote:
> Nice, how does the render speed of the sky part compare to the terrain?
>  I assume the sky is quite a bit slower?
   Yes... although not much more. A solution I figured out for quick
skies is to choose a fixed sun placement and render a spherical map of
the media clouds to use it later on the scene with the same sun
position, but it needs very high resolution images. Rendering a decent
skymap can take several weeks... and it only serves for a concrete sun
placement.
   BTW, I used 3 intervals, not 2 as I said before.
> Is this randomly set up or did you select the composition manually?
   Almost totally random, as I added an optional main seed to generate
individual seeds for each feature. In this one I've manually selected
the terrain and fog colors, the sun placement, and the diameter and
center of the vegetation area (based on the camera placement, which is
random, as it should be!;)
   There is something very addictive in trying seed after seed until you
find a nice setup... I'm using the animation features to get a different
landscape on each frame, so I can let it automatically render many low
res tests, to latter chose the best ones and tweak them manually.
Jaime
Date: 5 Jul 2004 07:10:01
Message: <ccbcp4$9oc$1@chho.imagico.de>
> placement.
But when you have one sky map you can rotate it arbitrarily around the
vertical axis to get different sun positions in azimuth.  The height of
the sun is of course fixed, as well as the position of the clouds
relative to the sun.  And for good results you would of course need a
high dynamic range map.
This is exactly what i meant.  In fact it does not matter much if you
manually tweak the settings or if you try random scenes until you find
one that looks good.  The thing i am having trouble with is to get the
random parameter selection to *always* produce a scene that looks
reasonable.
Last updated 01 May. 2004 _____./\/^>_*_<^\/\.______
Date: 5 Jul 2004 07:10:42
Message: <40e93732$1@news.povray.org>
Jim Charter wrote:
> Words will surely fail...
   Specially due to my poor english skills...
> But among other things, I love the complexity, but with variation, that
>  you get in the vegetated, eroded slope descending on the left,...I can
> see getting one or the other, but both? And then you add the further
> element of exposed rock structure on the vertical face!
   Multiplying two pigment functions gives fantastic complexity with
great variation, specially if the two pigments are at different scales.
> ...ability with complexity to produce the look of landscape.  And
> contemplating the look of a landscape is exactly what we do when we
> climb to a vantage and gaze out.
   Yes, I was going for a sort of impressionism, giving just enough
detail to let the brain do the rest. It requires a proper resolution,
not too low to avoid losing details, but also not high enough to show
the real CG nature.
> ...  But the variation you produce looks truly various not
> simulated, and just in the way a landscape does. How do you achieve
> that, one wonders. To automate you must establish parameters, and
> general structures, to direct random events. The additions of scene
> elements can never rise above a manual checklist. So landscape is not
> infinitely various? Yet it is this sense of unlimited variation that
> gives so much pleasure.
   It is infinitely various in the sense that you must provide the
isosurface function. This function is later used with a random color map
and translated and turbulated randomly, so the variation you can get is
really high.
 > Is your guide post creation itself, or the look of creation?
   I'm not sure to understand correctly the question... if you ask for
my motivation, it is always to be surprised by the results, and this is
greatly accomplished with highly random scenes like this one. I even use
randomly guided cameras and lights placement on my "usual" scenes, as my
composition abilities are not well developed (but I can recognize a good
composition when I see it, which is enough with trial&error techniques).
Jaime
Date: 5 Jul 2004 07:19:12
Message: <40e93930$1@news.povray.org>
Mick Hazelgrove wrote:
> Great work Jaime.
   Thanks!
   Yes, there is only one object, scaled and rotated randomly. Next step
with vegetation will be to add support for user-supplied objects, as
well as giving some predefined ones. Hmmm... I'm thinking now I can use
eval_pigment for the distribution/mix of the species too. Thanks!
Jaime
Date: 5 Jul 2004 07:23:58
Message: <40e93a4e$1@news.povray.org>
> altostratus.
   Yes, I basically tried two types of clouds: cumulus and high altitude
clouds.
> down to horizon.
  In fact the high layer is really much higher than the cumulus, but it
seems not very noticeable. Perhaps the scale of the pattern has
something to do with it...
   Thanks!
Jaime
Date: 5 Jul 2004 07:35:07
Message: <40e93ceb@news.povray.org>
   Yes, I did not think on it, but you are as usual right.
   Not necessarily, I think, only if you want very accurate radiosity.
For me the biggest problem is the rendering time required to create an
extensive collection of cloudscapes.
> reasonable.
   I think you are way too exigent... but I do not doubt you will figure
out a solution. :)
Jaime
Date: 5 Jul 2004 08:00:02
Message: <ccbfkp$be7$1@chho.imagico.de>
>> And for good results you would of course need a high dynamic range map.
For reflections (water) this can be important as well although you can
trick quite a lot with reflection exponent.
I think for high resolution renders (which your recent scenes seem very
suited for) this is probably not a solution anyway.
>> The thing i am having trouble with is to get the random parameter
>> selection to *always* produce a scene that looks reasonable.
> out a solution. :)
I am quite near to start my new LOTW-2 but i simply still get quite a
lot of 'boring' scenes.  Since i plan to do 20 tests for every
generation of which only 4 get selected this is not such a big problem
though.
Date: 5 Jul 2004 14:03:46
Message: <40e99802$1@news.povray.org>
>   I'm not sure to understand correctly the question... if you ask for my
I'm not sure I understand the question either.  But you turned it into
an understandable and interesting answer.  I think that what I was
reaching for was somewhat rhetorical.  To wonder about what it really is
that we find so pleasurable about landscape, and how that relates to
your process.
