POV-Ray : Newsgroups : povray.binaries.images : Strange Attractors by Manuel Kasten Server Time
5 Aug 2026 04:01:28 EDT (-0400)
  Strange Attractors by Manuel Kasten (Message 10 to 19 of 39)
<<< Previous 9 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Strange Attractors by Manuel Kasten
Date: 15 Mar 2004 10:17:02
Message: <4055c8ee@news.povray.org>
"Timothy Cook" <z99### [at] bellsouthnet> schreef in bericht
news:40554725@news.povray.org...
> Dan P wrote:
> > AWESOME technique!!!
> Shouldn't that be 'AWESUM ROLEX'?  ;)
IIRC it was "AWSOME ROLEX" :)
btw, Rune, nice image as always, but I believe in this case raytracing isn't
the way to go.  Using scanline, you don't have to store all the points in
memory, only the one you're currently drawing, so it wouldn't be any problem
to draw millions or billions of points :)
(Unless there's something about this strange attractors that I don't know...
maybe you need every previous point to compute the next? :-/ :-))
cu!
ZK AKA Gaeriel
http://www.povplace.be.tf
"If we ain't outta here in ten minutes, we won't need no rocket to fly
through space."
Date: 15 Mar 2004 14:38:45
Message: <Xns94ADD20507BEDseed7@news.povray.org>
in news:40555055@news.povray.org Manuel Kasten wrote:
> but wanted to play with attractors more, I wrote a Java
> program [...]
Are these "attractors" 3-dimensional? If so, how about the idea to have
your program output 3df's, and render them in POV-Ray?
Ingo
Date: 15 Mar 2004 16:08:36
Message: <40561b54$1@news.povray.org>
No, the aren't. They are just millions of points on a 2-d coordinate system.
But it is possible to make 3-dimensional attractors.
Manuel
Date: 15 Mar 2004 19:30:23
Message: <40564a9f$1@news.povray.org>
How much memory are we talking about for
the all-pov-version ?
Steven Pigeon, Ph. D.
pig### [at] iroumontrealca
"Manuel Kasten" <kas### [at] gmxde> wrote in message
news:40555055@news.povray.org...
> > The code for this image is by Manuel Kasten, who posted it in
> > povray.general. The scene contains 2.000.000 little white spheres. He
> > couldn't render it himself though, because of heavy swapping.
> The code is based on Paul Bourkes scc3 entry.
> > Now, I don't have enough memory either, but what I did was to reduce the
> > memory usage by rendering the image over 20 passes each with 100.000
> > spheres, each time using the previous frame as a background image_map
> > for the current frame. The result looks nice. It's attached. Well, I
> > blurred it in Paint Shop Pro before posting in order to reduce
> > graininess and jpeg-artifacts. The original really isn't blurred at all
> > despite the multiple times applied antialiasing that is a side effect
> > from the multiple pass technique I used.
> Thank you! That's a great idea. Because I couldn't get around that problem
> for myself, but wanted to play with attractors more, I wrote a Java
program
> (so the following picture is _NOT POVRAY CREATED_). It consits of merely
> 50 mio. points and was created in less than 2 minutes with a memory usage
of
> approx. 4 MB.
> again: this is not povray generated, but related to the topic...
Subject: AWESOME ROLEX!!!!!
Date: 15 Mar 2004 20:18:41
Message: <405655E9.B26F9997@hotmail.com>
> (...the following picture is _NOT POVRAY CREATED_)
Date: 15 Mar 2004 20:20:51
Message: <4056566B.903BA65E@hotmail.com>
> the memory usage by rendering the image over 20 passes each with
> 100.000 spheres, each time using the previous frame as a background
> image_map for the current frame.
BRAIN:  "Pinky, are you pondering what I'm pondering?"
PINKY:  "I think so, Brain.  But what are we going to do with our
spare time if we can emulate a z-buffer in POV-Ray?"
Date: 15 Mar 2004 23:01:14
Message: <40567c0a@news.povray.org>
Does raytracing necessarily have to load all points into memory?
Tim Cook
Version: 3.12
Date: 15 Mar 2004 23:34:56
Message: <Xns94AE38C42B037raf256com@203.29.75.35>
ing### [at] tagpovrayorg news:Xns94ADD20507BEDseed7@news.povray.org
800x800x800 - its a lot of memory ;)
http://www.raf256.com/3d/
Computer Graphics
Date: 15 Mar 2004 23:35:31
Message: <Xns94AE38DDC335raf256com@203.29.75.35>
z99### [at] bellsouthnet news:40567c0a@news.povray.org
I think oct-tree would be best here
Computer Graphics
Date: 16 Mar 2004 01:49:25
Message: <4056a375@news.povray.org>
The original povray-version needed beetween 400 - 500 MB of RAM for
2 mio spheres. Runes version needs as low memory as you want, depending
on how much passes you do.
My Java version's memory consumption is independent from the number of
points, so I can easily go as high as say 350 mio. Thats why the Java version
looks that much smoother than the POV version. ( Memory usage can be
approximated by     image_size*image_size*3 byte  )
Manuel
