POV-Ray : Newsgroups : povray.binaries.images : WIP: "Plasma Machine" [1 image, ~ 500KB] Server Time
4 Jun 2026 17:46:04 EDT (-0400)
  WIP: "Plasma Machine" [1 image, ~ 500KB] (Message 11 to 19 of 19)
Subject: Re: "Plasma Machine" [1 image, ~ 100KB]
Date: 24 Oct 2002 06:14:57
Message: <3db7c821@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3db7aecc@news.povray.org...
> Marc-Hendrik
Subject: Re: "Plasma Machine" [1 image, ~ 500KB]
Date: 24 Oct 2002 06:18:48
Message: <3db7c908@news.povray.org>
"Andrew Coppin" <orp### [at] btinternetcom> wrote in message
news:3db7ae64@news.povray.org...
> Sorry sorry sorry...
   No need to apologise, **** happens...  ;)
> Well, at least someone likes the image...
      ANY feedback is good, but yes, I like it. I may have a go at my own 'Plasma
Machine' soon.
      ~Steve~
> Andrew.
Date: 24 Oct 2002 07:38:23
Message: <3db7dbaf@news.povray.org>
Just making it clear that I realise my error, and I'm not doing this stuff
just to **** people off ;-)
'Plasma
> Machine' soon.
Cool luck.
Andrew.
Date: 24 Oct 2002 07:40:47
Message: <3db7dc3f@news.povray.org>
Mmm... Interesting...
(Of course - *real* plasma is supposed to be ionised gas at heigh
temparature and low pressume, isn't it?... Or that watery bit in people's
blood, depending on which kind of plasma you mean ;-)
Me I just like an excuse to make interesting images. Oh, and I got one of
those plasma ball thingies at home. (Never did work out why the streamers
are blue, but the terminals are pink...)
Andrew.
Date: 24 Oct 2002 11:30:00
Message: <chrishuff-D15CDA.11231624102002@netplex.aussie.org>
In article <3db7dc3f@news.povray.org>,
Pressure doesn't really matter. The ionized gas a lightning bolt passes
through is at quite a high pressure for a short period of time. And the
sun is just a big ball of plasma with portions at an extremely high
pressure.
Different temperatures and voltage potentials. The ball contains a
mixture of gasses, some only ionize and glow at the central electrode.
http://tag.povray.org/
Date: 24 Oct 2002 15:27:27
Message: <3db8499f@news.povray.org>
of
streamers
I always wondered about that... And about how you can touch the thing
without frying yourself to a crisp ;-)
(Actually, I find that if I balance a metal object on top of the glass, I
can get little sparks to fly off it onto anything that's earthed... Burned
my finger doing that!)
Andrew.
[has too much free time]
Date: 29 Oct 2002 16:34:04
Message: <slrnartvmc.3gc.y7pt9001@safari.homelinux.net>
On Wed, 23 Oct 2002 22:05:35 +0200, Ive <ive### [at] lilysoftcom> wrote:
> "St." <dot### [at] dotcom> schrieb im Newsbeitrag news:3db6eeb3@news.povray.org...
>>      Andrew, please see your image in attached .jpg format. The filesize for this
>> image is ok for this group, 600+ isn't. Why is it that you can't produce your
>> images in the .jpg format? Many people, (including myself), still have dial-up and
>> it takes some time to download, so consequently, some won't even try to download
>> it.
> Also try testing different programs and compression settings. The attached JPEG
> uses progressive encoding, is more than 25KB smaller than Steves but shows a
> better quality with less artefacts.
> And BTW most programs are also able to get a higher compression ratio for
> PNG images as POV does, and almost every program can produce smaller
> PNG files than Photoshop.
and with pngcrush you can recompress png files to get the smallest
possible file size
http://belnet.dl.sourceforge.net/sourceforge/pmt/
-brute (Use brute-force, try 114 different methods [11-124])
but usually brute-force is not needed ;)
Safari - y7p### [at] sneakemailcom
"Talk is cheap. Show me the code." - Linus Torvalds
Date: 29 Oct 2002 16:39:14
Message: <slrnaru002.3gc.y7pt9001@safari.homelinux.net>
On Thu, 24 Oct 2002 10:27:01 +0200,
Marc-Hendrik Bremer <Mar### [at] t-onlinede> wrote:
> "St." <dot### [at] dotcom> schrieb im Newsbeitrag news:3db71dd9@news.povray.org...
>>        Oh, so you downloaded the same file-name 3 times then? Silly.
> Oh, and how should I know that it's the same file and not something
> earth-shattering new? As your subject-line does not implement that it's the
> same file, I thought you might have some "Plasma machine" yourself to show.
> Besides, OE does not allow me to download just your text and not the
> attachment. That might be OE fault, but that's another story. So I had the
no, NNTP protocol just does not have such a feature.
either you download the whole article or drop the connection to the
server and reconnect AND don't download the big article the next time.
> choice to ignore your post (I don't think that would have been good), or to
> take it the way it is.
> Why don't you post URL's to those "teaching examples"? Silly.
> Marc-Hendrik
Date: 29 Oct 2002 17:40:51
Message: <chrishuff-3940A2.17335129102002@netplex.aussie.org>
In article <slr### [at] safarihomelinuxnet>,
Actually, it must be OE. All the other newsreaders I've seen display the
text and then the image as it downloads. I thought OE did this too, but
I haven't really used it much.
