POV-Ray : Newsgroups : povray.binaries.images : Testing realism again Server Time
6 Jun 2026 00:21:52 EDT (-0400)
  Testing realism again (Message 17 to 26 of 26)
Subject: Re: Testing realism again
Date: 10 Apr 2002 11:28:44
Message: <3cb45a2c$1@news.povray.org>
Since the object is white, I wonder if using the metallic keyword in the
reflection block would help. Increasing the diffuse would lighten the
reflection, but perhaps cause worse problems.
 -Shay
Hugo <hua### [at] post3teledk> wrote in message
news:3cb452c8$1@news.povray.org...
Date: 10 Apr 2002 14:55:52
Message: <3cb48ab8$1@news.povray.org>
>    Very good! The red color seems "tood red", and a bit more reflectant.
Yes, if you want realistic colours do not use full rgb values.  A while back
when I was looking at information about light and colour, it mentions that
we do not actually experience colours represented by these rgb values.  Have
a read here http://www.fourmilab.ch/documents/specrend/
-tgq
Date: 10 Apr 2002 18:53:06
Message: <3CB4C251.45B9782C@iki.fi>
Hugo wrote:
> I just didn't use subsurface scattering because this kind of plastic
> is "hard" and does not seem to produce any visible scattering...
You should have used :-). At least I see subsurface scattering on the
photo.
          /"\                           |    iki.
          \ /     ASCII Ribbon Campaign |    fi/
           X      Against HTML Mail     |    zds
Date: 10 Apr 2002 19:32:48
Message: <3cb4cba0@news.povray.org>
Me too.
Date: 10 Apr 2002 19:41:54
Message: <3CB4CE49.2040304@ignorancia.org>
  He he... :) This is one of my many bookmarks about color and light. I
have read a lot of stuff like this when creating my light macro. Not
that I understood much of it, but I at least extracted some asumptions
for personal use. POV-Ray, as the vast majority of renderers, cant' use
directly spectral data, but we can at least use an aproximation for
"proportionality" purposes. My method is really a bad and weird
aproximation, but it is surprisingly realistic in my own tests against
real photos, in terms of color proportions.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 11 Apr 2002 05:15:58
Message: <3cb5544e$1@news.povray.org>
Me neither, not even the benefit of understanding this. It seems to me just
like another way to think about surface colors, but an input for POV-Ray
will still have to be RGB, so what I did here, was to guess the color based
on the photo, so would there be any difference?
> real photos
Yesterday evening I tried my setup on a more complex object (my computer
keyboard that I made earlier) but the result was disappointing.. I don't
understand why it didn't look realistic and render time was WAY too high!!
I broke it after 4 hours.
Hugo
Date: 11 Apr 2002 05:20:20
Message: <3cb55554$1@news.povray.org>
> At least I see subsurface scattering on the photo.
You're kidding..? Okay if I take the objects in my hand and hold them
against the sun, I see the inside light up.. This means they ARE transparant
a little, but on the photo this seems invisible to me.. And because of that,
I see no reason to slow down my render even more.. A higher quality of
radiosity on the other hand, could improve the blocky shadows.
Hugo
Date: 11 Apr 2002 11:26:07
Message: <3cb5ab0f@news.povray.org>
The biggest difference between the photo and the render, is the
subsurfacescattering imho...
But nice job anyway :)
cu!
Date: 12 Apr 2002 10:31:16
Message: <3CB6EFBF.AACE8D3E@luxlab.com>
Some suggestions.
Paint the inside of the white cap black and compare the
effect on the outside surface to unpainted one. That's
sub-surface scattering.
Figure out the tonal mapping or ICC profile of your camera.
POV-Ray output is gamma corrected linear. I bet the camera
output is something different.
Do the out of frame scene geometry and colors match the
real scene?
_____________
Kari Kivisalo
Date: 12 Apr 2002 11:44:48
Message: <3cb700f0$1@news.povray.org>
> real scene?
Yes, the most important parts does. It misses a brighter left side (outside
camera view) however.
> I bet the camera output is something different.
Yes I thought about this too. My cameras response to light may not be
linear, and this might cause the reflection on the photo to be dimmer.. But,
on the other hand it looks too strong on my render.
:o)
Hugo
