POV-Ray : Newsgroups : povray.binaries.images : CDROM Case (png) Final Server Time
19 Sep 2025 20:10:34 EDT (-0400)
  CDROM Case (png) Final (Message 1 to 10 of 11)
Subject: CDROM Case (png) Final
Date: 19 Jul 2001 11:21:38
Message: <3b56fb02@news.povray.org>
This took 4days 19hours, and still didn't finish (hence its a bit cut off at
the end), but mega pov gradually snagged over 700mb and ground to a halt.
I know the green is to bright, I know its missing the side detail (but that
would have added at least another 2 days to the render)
its not finished, but I am not rendering it again till I have a faster pc :)
oh, 99% directional rad, and 2 very dim area lights to soften it up a touch.
PGP Public Key
Download 'cdrom.png' (160 KB)
Preview of image 'cdrom.png'
Subject: Re: CDROM Case (png) Final
Date: 19 Jul 2001 11:57:48
Message: <3B5703E1.80122C7E@gmx.de>
I must admit that i don't see a reason for it being that slow.  Radiosity
looks really smooth, but it seems like fairly high error_bound.  Geometry
does not look too complicated either.
How much time and memory does it take without radiosity?
Date: 19 Jul 2001 11:59:36
Message: <3b5703e8$1@news.povray.org>
btw - sorry about the file size, but jpg hates green and after waiting days
for this to render I wasnt going to have crappy compression spoil the image
PGP Public Key
Date: 19 Jul 2001 12:41:40
Message: <3b570dc4@news.povray.org>
its a very complex csg (the bright green hides the detail unfortunatly) -
takes a 6 hours with 1 point light, no aa (with case side detail its over a
day)
with aa, 2 5x5 area lights, and the rad lighting it crawls...
PGP Public Key
Date: 19 Jul 2001 12:48:41
Message: <3B570FCE.4DD4D018@gmx.de>
> day)
Hmm, if i have a look at a CD-Case it does not look that complicated to me
(apart from the Compact-disc logo, which could easily be done with a
heightfield)
It would probably be usefule to simplify it to some extend so it renders
faster, like you already said right now you don't see that much detail
anyway.
Date: 20 Jul 2001 06:22:11
Message: <3b580653@news.povray.org>
Rick [Kitty5] <ric### [at] kitty5com> wrote:
: This took 4days 19hours
  Radiosity is not the answer for everything. This image doesn't even look
like it benefits at all from radiosity. In fact, as you note as well, it
actually hides details, instead of enhancing them.
  With no radiosity and a proper area light this would probably render in
less than 10 minutes and could look at least as good, if not even better.
Date: 20 Jul 2001 11:38:02
Message: <3b58505a@news.povray.org>
as I stated - 6 hours with one point light.
area lights are crippling, and the rad makes a huge difference, the rad
hides some of the detail as the green texture is to bright.
PGP Public Key
Date: 20 Jul 2001 15:30:36
Message: <3B5886D0.AA74802E@ignorancia.org>
 Yes, I see it if I look closely.
  Not only this. You're using a damn slow combination: "area_light +
radiosity + transparency". Try a test with a opaque texture for the
plastic cover and you will see render time decrease. I've on my hands a
scene with radiosity and 3 huge arealights, and the it renders not too
bad until it reaches the first glass bottle. "Complicated CSG +
radiosity" seems to not have such a drastic effect on render times if
you don't make it transparent.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 21 Jul 2001 05:16:50
Message: <3B594922.113BCF5A@inapg.inra.fr>
I've noticed that too. Transparency is already very difficult to handle with
radiosity, but I've almost given up on using radiosity + transparency + ior. In
my IRTC "contrast" picture, I had to remove a few bottles because of that. In
another instance, 1 single bottle with ior made the render impossibly slow, and
not only when it reached the bottle. Just removing the ior made it...
acceptably slow.
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 21 Jul 2001 05:31:04
Message: <3B594C3E.C59A2E88@gmx.de>
> acceptably slow.
Maybe a 'no_radiosity' flag would be useful, just like 'no_reflection' or
'no_image'.  There is not much point in calculating radiosity on a
completely transparent object anyway.
