POV-Ray : Newsgroups : povray.binaries.images : Capriccio 16B Server Time
19 Mar 2026 07:01:25 EDT (-0400)
  Capriccio 16B (Message 11 to 20 of 35)
Subject: Re: Capriccio 16B
Date: 27 May 2003 02:45:48
Message: <4126dvguirml7mn1a1deoddoorlnt9cmob@4ax.com>
On Mon, 26 May 2003 23:24:08 -0700, Gena Obukhov <obu### [at] mailcom> wrote:
> Thanks a lot! That's exactly what I need.
Good. So I finally contributed Capriccio. I'm happy about that :-)
> Does POV-Ray take memory only
> for one map in this case ?:
AFAIK yes, but if you unsure you can verify it with "Memory used" section in
povray messages.
> #local DomeMap = pigment{
>  image_map{jpeg "cathedral/dome1.jpg" once}
>  scale<1/4, 1/2, 1/4>
>  translate y*0.5
>  warp{spherical}
BTW: After looking into your code I know more what you do - do you know instead
using layared texture you can use repeating warp? This should be fastest
solution.
ABX
Date: 27 May 2003 02:52:43
Message: <5n26dvk6g5adqas7gpmmi9av5qe2udnvi2@4ax.com>
On Tue, 27 May 2003 07:39:04 +0200, ABX <abx### [at] abxartpl> wrote:
>You can use image with 'once', scale it down to fit your section unrolled into
><0,0,0>-<1,1,0> area, and then use spherical warp. Then you can duplicate
>sections with layered textures.
Wouldn't it be faster if Gena didn't use 'once' but rather scale
<1/32,1,1> and then use the spherical warp? This would spare the
layered texture overhead (which is quite major with radiosity).
Peter Popov ICQ : 15002700
Subject: Re: Capriccio 17
Date: 27 May 2003 02:54:43
Message: <sq26dvgjqfdrm3oknsuj469ive9cams0dv@4ax.com>
On Mon, 26 May 2003 21:32:26 -0700, Gena Obukhov <obu### [at] mailcom>
wrote:
>New version with some details.
>Added wooden posts and changed light source position.
I think the figures in the boats are not up to the same level of
detail as the other parts of the picture, even as compared to the
figures on the stairs. No offense to the contributor, just some
constructive criticism :)
Date: 27 May 2003 02:58:25
Message: <jt26dvgt4nj4q1dkrkgbtc6v824ilvhh5p@4ax.com>
If you would foollow link I posted you could read that spherical warp is
mentioned there :-). And I proposed layers since I was somehow sure he need
partial transparency for other texture under.
ABX
Date: 27 May 2003 10:42:14
Message: <3ED37945.E815152A@gmx.de>
> The source is in p.b.s.-f.
Nice posts.  I did not yet study the code but i suppose it won't be that
easy to make their cylindrical shape a bit less uniform.
Ib's work on the building is impressive as well.  The texture should
probably be somewhat patina-like - somethinbg quite difficult to achieve
without being too slow.
I'm not sure about the change of the light position.  The left side
buildings are different from the original now but of course we have to
find a compromise because the lighting in the painting is not consistent.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 27 May 2003 13:08:48
Message: <3ED39B9F.8056E77D@mail.com>
Welcome to the club :)
> solution.
Thanks again! I'm not so familiar with 'warp'. Now I have to learn it in details :)
Gena.
Date: 27 May 2003 13:23:53
Message: <3ED39F27.AD6130C1@mail.com>
Christoph Hormann wrote:
> Nice posts.
Thanks!
This is intersection between isosurface and heightfield (based
on function). I tried to make difference between isosurfaces
but I couldn't avoid holes in the result object even changing
max_gradient and accuracy.
I can add spline to the posts. But that will just curve it. Anyway
feel free to change it.
Yep. I think image map won't be so slow here :) I would also prefer to use
procedural texture here but I know how difficult is to make such kind of
texture.
I also think that those buildings are too bright now and I'm going to
change their saturation in the future.
As for light source position, I tried to make cathedral and boat in the
center more illuminated.
Gena.
Date: 27 May 2003 13:34:04
Message: <3ED3A18B.A8B2A76B@gmx.de>
See the documentation for 'max_trace' and 'all_intersections'.  Of course
you can also intersect in the isosurface function and just use one
isosurface.
I think they look a bit like they have bark on the outer surface, a rough
and weathered but mainly plain wood surface would probably be better.  I
will see if i can work on that.
Date: 27 May 2003 13:37:12
Message: <3ED3A242.C1820EF1@mail.com>
I think evrybody agrees that human figures are always one of the
most difficult part of any image, especially when you model it
yourself from the scratch. Jim created already exceptional models
for this image. Maybe it would be also a good idea to share
Wings3D source files (if Jim don't mind of course) so that anybody
who feels that he/she can improve it could change it and show us
the result.
Regarding level of details, maybe playing with image/bump maps
will help here. Also in a high resolution image will be visible a lack
of hair in some figures. Again maybe image/bump maps could
help here or any other technique.
Anyway, I think before making the final rendering we will make
fine tuning of many objects :)
Gena.
Date: 27 May 2003 13:51:51
Message: <3ED3A5B6.E43246E9@gmx.de>
I agree on that.  In the larger renders i did i can hardly find mesh
artefacts so the geometric detail is fairly good.  Of course some parts
like the hands are not perfect but this is not a big problem IMO and maybe
it can even be improved.  The textures are an important thing to work on.
It would also be good if the boats could get some uv-coordinates so they
can be covered with a wood texture without looking carved from a large
block of wood.
