![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Peter Hertel wrote:
> Here is another test with the reference picture embedded for comparsion.
Good start.
> Is there need for much more detail?
Usually more details - better ;)
> When I had two such greyscale maps, I used them as height_fields and
> positioned them together with the temporary csg sun, then I did another
> orthographic shot and saved the last heightfield.
Maybe it's better to have the whole scene and apply that gradient texture
to all objects (?) This way you don't loose heightfield quality. The only
problem can arise here - a lack of memory for the herd of horses :)
Gena.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah, I'll work on that. It looks a bit flat, if I manage to get better
depth in the image it might help as well. Perhaps doing some manual painting
on the image_map will make it look better too.
As I'm only in the early tests I did it this way because it was much
quicker. It's also much easier to tweak the gradient texture when you know
the exact size of the object. But if I save the first height_fields in
resolution 3000x3000, it should be enough, no? That'll take a lot of memory
too, though..
-Peter
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Gena wrote:
> See the post in p.b.s.-f. group with subject 'Tree + Snow' posted on 1/29/03
> and example image in this group (p.b.i) with the same subject.
> In the future I'm going to bundle TOMTREEm.inc with POV-Tree
> together with leaf and seamless bark image maps for UV-mapping.
> Gena.
Thanks!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
The tympanum is now ready for your heightfield. The angles endedup being
only 26 deg, I hope that does not affect your work too much.
/Ib
Download 'teststpaul05.jpg' (67 KB)
Preview of image 'teststpaul05.jpg'
![teststpaul05.jpg](/povray.binaries.images/attachment/%3C3EC15C3D.4050302%40ibras.dk%3E/teststpaul05.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wow! Very impressive!
I think it's the best architectual CG object I've ever seen.
Are you still working on it? I'd like to add it to my changes and
render the scene (hopefully this week).
Gena.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Well, thank you, but I hope not. I have done at least two other churches
with a lot more precision and detail :)
I have some minor adjustments to do, and I would like to try and fit it
into the scene as closely to the painting as possible. Have you done any
changes to the camera since your last posted version?
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Ib:
It really is incredible. I admire you patience and good eye
for proportion and detail.
Aaron
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeh, I know. But I like this one more, I don't know why :)
What do you think about textures? I could suggest you some
image maps for dome and walls. I know that you are POV-Ray
purist and don't like any image maps :) but I think image maps
will look more real-life than procedural textures.
> Have you done any
No.
Gena.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I was hoping I could leave the texturing to you, because I can't get
anything to look right with assumed_gamma 1. I'm going to clean up my
texture use to as few as possible, and declare them all at the beginning
of the file, so it should be easy to change them.
>>Have you done any
> No.
Good, the I will take the latest version and try and fit the model to
the painting, before I post it.
/Ib
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
being
Not at all, and that's an incredible model you've created!
Sadly I've not been able to do much work on my part lately, been a busy
week in RL(TM). What I've done is created some objects (helmet, sword,
some cloth) in Wings3D and added them to the figures in Poser, in
addition to repose the things. I've also done what Gena suggested and
included all the figures in the scene, thus only produsing one
height_field. I think I'm also going to do some manual editing to the
image to increase the details in some places.
Download 'hf_final.jpg' (11 KB)
Preview of image 'hf_final.jpg'
![hf_final.jpg](/povray.binaries.images/attachment/%3C3ec3d109%40news.povray.org%3E/hf_final.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
