POV-Ray : Newsgroups : povray.binaries.images : Capriccio - stairs (73+135k) Server Time
30 Mar 2026 20:12:02 EDT (-0400)
  Capriccio - stairs (73+135k) (Message 21 to 30 of 44)
Subject: Re: Capriccio - stairs (73+135k)
Date: 8 May 2003 15:06:27
Message: <3ebaaab3@news.povray.org>
> Darren Hewson wrote:
> > Found a nice close up...
So that's what it looks like! :) Thanks a bunch!
> My newsreader broke the first link between "top." and "half.jpg" but
> strangely enough, I got the image anyway, just in even higher
> resolution. The same works for the other image: drop the "half." and
you
> get the image in double res.
Ain't you a tricky one ;) Tak!
If the final resolution are to be 6000x8000 the triangle will then be
about 1050pixels wide, or? I just need a feeling of how detailed it has
to be.
I've attatched my first test render, and looking at the new reference
pictures I think I can get away with it if I do some helmets in Wings.
And perhaps a sword, and some nice outfits and armor and.. :) Hmm.. The
casual Poser 3 man might look better because he has a t-shirt on.. This
is fun! *running away playing more*
-Peter
Download 'test01.jpg' (16 KB)
Preview of image 'test01.jpg'
Date: 8 May 2003 15:48:36
Message: <3EBAB4FA.7060205@ibras.dk>
> to be.
I get the triangle to be close to 25% of the image width, at its widest,
which is 1500 pixel. I don't have the exact size of the triangle, as it
is going to be the last part, that I model, unfortunately, due to the
way I'm working through the building. The acute angles a going to be
close to 27 deg, though.
Looking very promising.
/Ib
Date: 8 May 2003 15:48:44
Message: <3ebab49c@news.povray.org>
Gena Obukhov wrote:
> Here is the technique which I meant. First image is my original model
> created in sPatch. Second image is the same model but with gradient
> -z color_map from black to white. The third image is the heightfield
> relief created from the second image.
Gena, exactly how did you generate that second image?
Date: 8 May 2003 16:17:38
Message: <3ebabb62@news.povray.org>
Never mind, I see now.
Date: 8 May 2003 16:44:03
Message: <3EBAC193.936E4848@mail.com>
Just a clarification for the other people :) The texture should look
smth. like:
    gradient -z
    color_map {
        [0 1 color rgb 0 color rgb 1]
    scale ...
    translate ...
finish{ambient 1}
The main problem is  that scale... translate ... block. You have either
to know minimum and maximum Z coordinate of your object or just
play with it.
Gena.
Date: 8 May 2003 18:44:15
Message: <3ebaddbf@news.povray.org>
widest,
it
Ok, I'll do some dummy boxes to test with.
Here is another test with the reference picture embedded for comparsion.
Is there need for much more detail? I need to postion the bodies so that
they give more depth. And by the way, you can't open the mouth of the
horse in Poser 3.
If anyone is interested, I did it like this:
Posed a horse and a casual male in Poser.
Exportet to obj, then to pov via PoseRay, fixed the textures.
Used a texture similar to Gena's and rendered a orthographic view or the
model which I saved in resolution 1000x1000 (png).
When I had two such greyscale maps, I used them as height_fields and
positioned them together with the temporary csg sun, then I did another
orthographic shot and saved the last heightfield.
But now a question, what is the man to the far left doing? ("O" marks
him ;-)
Is he bending his hip in some insane position, or is there two people on
the horse? Is he strangeling himself or covering his eyes?
Perhaps I'm too tired..
-Peter
Download 'test03.jpg' (75 KB)
Preview of image 'test03.jpg'
Date: 8 May 2003 19:22:21
Message: <3ebae6ad@news.povray.org>
And if, like me, you happen to be using a mesh2 object that you converted
using 3dwin, you must remember to remove the uv_mapping keyword from the
object declaration. ;)
Gena, I know I read somewhere that you published a somehow faster
version of Tomtree or something to that effect.  But I can no longer
find where you referred to it or where it is.  Could you remind me where
you put it?
Thanks, Jim
PS. your -z gradient pigment thingy has given me an idea for the next
IRTC round.
Date: 8 May 2003 19:50:36
Message: <3EBAED4C.C1D2C892@mail.com>
> you put it?
See the post in p.b.s.-f. group with subject 'Tree + Snow' posted on 1/29/03
and example image in this group (p.b.i) with the same subject.
In the future I'm going to bundle TOMTREEm.inc with POV-Tree
together with leaf and seamless bark image maps for UV-mapping.
Gena.
Date: 9 May 2003 02:17:33
Message: <3EBB4862.2040508@ibras.dk>
> him ;-)
He is coverings his eyes. As for the leg, it may be distorted a bit, to
avoid having it stick out of the relief.
/Ib
Date: 9 May 2003 02:51:42
Message: <6mjmbvg8i9b0h2lg3r8cpvoffiejdka798@4ax.com>
> play with it.
http://www.povray.org/search/?s=min_extent
http://www.povray.org/search/?s=max_extent
ABX
