POV-Ray : Newsgroups : povray.binaries.images : Late Friday Night Abstract (81kb jpg) Server Time
5 Jun 2026 11:28:50 EDT (-0400)
  Late Friday Night Abstract (81kb jpg) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Late Friday Night Abstract (81kb jpg)
Date: 13 Jul 2002 09:30:02
Message: <3d302b5a$1@news.povray.org>
"Samuel Benge" <sbe### [at] caltelcom> wrote :
> Looks kind of like architecture in some way, terrestrial or not...
    Clearly it's the entrance to a Dyson Sphere. I've seen dozens just like
it while Astral Traveling.
Date: 13 Jul 2002 09:31:17
Message: <3d302ba5$1@news.povray.org>
now that is good!
PGP Public Key
Version: 6.0.373 / Virus Database: 208 - Release Date: 01/07/2002
Date: 13 Jul 2002 13:35:57
Message: <3D3064FA.7040304@caltel.com>
Okay, did a search on 'Dyson Sphere'. If my image were the entrance to
one, that means the engineers used copper, because it's green.
Somebody does need to render a Dyson Sphere, though. Maybe a type 1
(non-rigid), since that is the most likely kind to be created, although
creating many different orbiting/static habitats can be a little
difficult. Need to build a good macro for that....
Samuel Benge
Date: 13 Jul 2002 14:19:22
Message: <chrishuff-65C495.13163713072002@netplex.aussie.org>
In article <3D3### [at] caltelcom>,
If it was the entrance, it would be in vacuum, so the copper wouldn't
oxidize. It could be they just painted it or used some exotic alloy or
composite.
How about a criswell instead? Much more room, and you could lengthen the
life of the sun by a few million years while you are at it.
A ringworld or a lot of ring orbitals seems more plausible though...
Actually, I was just recently thinking of doing a "hollow planet" type
image with an artificial sun in the center...not exactly a Dyson Sphere,
but close enough to make this surprising...
Date: 13 Jul 2002 14:29:21
Message: <3d307181$1@news.povray.org>
"Samuel Benge" <sbe### [at] caltelcom> wrote in message
news:3D3### [at] caltelcom...
    No, it has some of the properties of copper, but it's a non-atomic type
material, with string-like nucleus and predetermined linear electron paths.
    I've rendered several different forms, including an animation of the
construction phase of a rather simplistic one. Maybe after I finish the wall
paper sized version of your isosurface I'm doing, I will re-run one of
those. Because, of course, I just finished erasing most of my renders last
week to make room on my HD.
    The problem with rendering Dyson spheres is that at the distance needed
to see any significant fraction of the object, all detail is gone.
Date: 13 Jul 2002 18:42:52
Message: <3d30acec$1@news.povray.org>
BTW, this artifact was clearly made by humans. If you look closely you
can see several spots where the human face is represented in the sculpture.
Date: 13 Jul 2002 22:43:14
Message: <3D30E53D.3040609@caltel.com>
Do you have an mpeg for us to see? :)
Um, you did do a test render first, right? I noticed the code I posted
doesn't produce the exact same image.. but it's very close <shrug> You
might also want to take the functions through the loop a few more times
for extra detail.
That's when you focus on the foreground and let everything alse blur into the
distance. :)
Samuel Benge
Date: 13 Jul 2002 22:43:37
Message: <3D30E555.4030505@caltel.com>
I've see a few of those.....
Samuel Benge
Date: 14 Jul 2002 12:01:28
Message: <3d31a058@news.povray.org>
Samuel Benge wrote:
> Nobody else seems to be posting one, so here one is :) It's an
> isosurface plane with repeated cosine functions inside a #while loop.
Gigeresque :)
-Jide
Date: 14 Jul 2002 23:07:35
Message: <3D323DDA.6000901@faricy.net>
It's an underground dome, and the big encrustations are where minerals
have seeped through and been deposited by water...
___     ______________________________________________
  | \     |_         website: http://davidf.faricy.net/
  |_/avid |ontaine           email: <dav### [at] faricynet>
