ingo wrote:
> how does the combination object_pattern + blurr_pattern compare to the
> proximity_pattern? Speedwise and for turning an object into pattern
> usable for an isosurface.
That's one of the things i was going to check, but i did not yet have time
to do so. Anyway right now there are only non adaptive blurring methods
implemented and therefore it is quite slow when using a lot of samples.
I already started to write a recursive algorithm only taking additional
samples if the values differ, but i did not yet finish it.
Christoph Hormann <chr### [at] gmx de>
In article <3AA291F9.3E734EF6@gmx.de>, Christoph Hormann
I had done a pattern blurring patch before, but got stuck trying to
figure out a good way to get smooth blurring without a huge number of
samples. I don't know how suitable it is for isosurfaces, there are
still areas with infinite gradient. I think I can figure out a way to
get smooth blurring, though...
My patch worked differently, it was a pattern modifier, like the
waveform modifiers. I never thought of implementing it as another
pattern...seems like a good idea, especially in the case of block
patterns, which wouldn't be block patterns any more after being blurred.
I would suggest a different keyword, though..."blur_pattern", for
example.
One question: why do you still have the "grad" pattern, which should be
possible with the "warp_pattern" pattern?
Also, I would suggest that "visibility" be a separate pattern...it
doesn't seem to fit in with the object pattern, and would be better off
not being a block pattern. Incorporating distance would be a useful
feature.
Christopher James Huff
Personal: chr### [at] mac com, http://homepage.mac.com/chrishuff/
TAG: chr### [at] tag povray org, http://tag.povray.org/
That would be interesting, i can't imagine a method right now that would
do this without a lot of samples. Adaptive sampling would help a lot IMO,
esp. woth block patterns, but it's quite difficult to implement.
> example.
I don't like too much typing :-)
Seriously, i think the '_pattern' stuff started with pigment_pattern where
it's a good idea, like for warp_pattern too, but i'm not sure if that
should be continued with all patterns.
It was written before :-)
i will probably check if there is a difference in speed and take it out if
it's negligible.
> feature.
There is already a seperate visibility pattern, but i did not yet include
it in the documentation, because it's quite preliminary.
try:
visibility {
object { test_Obj }
direction z
Right now the effect of the object pattern with visibility can not be
identically achieved with the seperate visibility pattern.
In article <3AA2A38A.28F03C1C@gmx.de>, Christoph Hormann
I'll take a look at your source code, and see if I can make it use my
method...and if my method will work. With luck, you will see some sample
images from me soon (and a description of the algorithm, of course). :-)
I think it makes sense in this case...actually, "blurred_pattern" seems
even better. Just plain "blur" seems kind of ambiguous...it doesn't seem
as apparent that the *pattern* is what is being blurred.
Alright...I just downloaded the source code, and will probably integrate
your stuff into MegaPOV+. (it will be the last thing added, though, in
case you release a new version before I complete MP+)
Now *that* has some potential for confusion...
All right, since English is not my native language i will not argue that.
Will that be based on Megapov 0.7 ?
Integrating your particle system patch I also saw that some other things
were not yet included in Megapov like the curvature pattern. What's the
reason?
Yeah :-)
While the 'shadows' in the object pattern with visibility are infinitely
long, the value raises to 1 at the length of the distance vector in the
visibility pattern.
>> seems even better. Just plain "blur" seems kind of ambiguous...it
>> doesn't seem as apparent that the *pattern* is what is being
>> blurred.
>that.
Should it be a pattern at all? Why not as a method of 'transformation'
like turbulence, maybe even within a warp statement.
pigment{
wood
warp{ blurr .... }
Ingo
Pov-Ray : http://members.home.nl/seed7/
In article <3AA2B1D7.1530E613@gmx.de>, Christoph Hormann
> > blurred.
I just added it to my code, and realized it takes a pigment, not a
pattern...why is that? It kind of messes up my logic for the name...it
should be "blurred_pigment_pattern". ;-)
I think my first modification will be to change it to use a
pattern...that might speed it up slightly. I can't think of any benefit
to using a pigment...
> > integrate your stuff into MegaPOV+. (it will be the last thing
> > added, though, in case you release a new version before I complete
> > MP+)
Yes.
> reason?
They aren't finished, some of them just don't work.
> Yeah :-)
> visibility pattern.
So the value tends toward 0 as the object gets nearer, and the effect of
an object gets stronger with distance? That doesn't seem right...an
object should have less influence with distance.
It can be declared, furthermore: just laziness.
Probably better the other way round, in both patterns. The idea in the
object pattern was shadow -> 0, but that's not that important.
> pigment{
> wood
> warp{ blurr .... }
Since it is no transformation in fact, i'm not sure if that's possible.
Values get changed, in block patterns like checker even totally new values
occur.
In article <Xns### [at] povray org>, ing### [at] home nl (ingo)
This is how my patch worked...however, block patterns, which have a
fixed number of flat areas, might not work as expected when the blurring
returns "in-between" values.
