POV-Ray : Newsgroups : povray.binaries.images : IsoWood 0.2 Preview (87k) Server Time
30 Mar 2026 13:21:55 EDT (-0400)
  IsoWood 0.2 Preview (87k) (Message 1 to 10 of 14)
Subject: IsoWood 0.2 Preview (87k)
Date: 7 Nov 2000 10:15:32
Message: <3A081C93.3985D66B@schunter.etc.tu-bs.de>
I'm working on the second version of the IsoWood include, here is a preview
scene with some of the things i added.
There is still a lot to do, especially the documentation, so i don't know when
it will be finished.
Comments and suggestions for further additions welcome.
Download 'iw_04.jpg' (88 KB)
Preview of image 'iw_04.jpg'
Subject: Re: IsoWood 0.2 Preview (87k)
Date: 7 Nov 2000 11:12:31
Message: <3a0829ef@news.povray.org>
Hmm, where are the knotholes?
Grim
Date: 8 Nov 2000 16:30:50
Message: <3A09C60A.E9CAEBFC@schunter.etc.tu-bs.de>
> Grim
I already made some experiments concerning that problem, but it's difficult,
because the 'classical' inverse black_hole warp technique does not work that
well. The color of the knotholes usually differs from the wood and black_hole
warps are spherical while realistic knotholes should have a more cylindrical
shape pointing away from the center of the wood pattern.
Date: 8 Nov 2000 22:43:29
Message: <3a0a1d61@news.povray.org>
Aye. I've been looking at the new turbulence vector. That, and I believe
something like a spotted map, would get results. In otherwords, a complex
texture would most certainly be required. I have no doubt that warps,
blackholes, (whatever) could benefit diversity in the pattern, but not the
answer in getting the overall effect.
I started off iso woods by trying to recreate the T_Wood series, which I
then proceeded to 'dirty down' with knotholes. I still haven't gotten the
results I want, but I have a ton of projects going too. :)
Attached are 25 T_Woods less the knotholes.
Good luck!
Grim
Download 'TWood_Iso.jpg' (44 KB)
Preview of image 'TWood_Iso.jpg'
Date: 9 Nov 2000 19:13:06
Message: <chrishuff-7FD121.19131109112000@news.povray.org>
In article <3A09C60A.E9CAEBFC@schunter.etc.tu-bs.de>,
> difficult, because the 'classical' inverse black_hole warp technique
> does not work that well. The color of the knotholes usually differs
> from the wood and black_hole warps are spherical while realistic
> knotholes should have a more cylindrical shape pointing away from the
The displace warp could be of use here...or someone could patch the
black hole warp so the "type" keyword actually does something...
Christopher James Huff
Date: 10 Nov 2000 02:38:51
Message: <3A0BA60B.7D837F0C@schunter.etc.tu-bs.de>
I already thought of displace warps, although it would not be usable in Povray
3.5.
With a 'type 1' displace warp i could also use the same pattern for the warp and
the different coloring of wood and knothole.
Date: 10 Nov 2000 02:59:37
Message: <3A0BAAE9.B339E6A5@schunter.etc.tu-bs.de>
I'm not sure if i understood that right, could you explain it a bit more
detailed ?
I think displace warps are quite a good idea, i also try the black_hole warps
placed at the surface of the wood objects.
You should remember that layered textures can't be used in the IsoWood include.
BTW I already have quite a lot of color_maps and some pigments to be included
with IsoWood 0.2
Date: 10 Nov 2000 07:42:59
Message: <3a0bed53@news.povray.org>
> detailed ?
> with IsoWood 0.2
Yeah, I ran into this when I was trying to get a good oak texture, including
grains.  I ended up doing a pigment map with the same coordinants as the
texture map, then added a texture field to the iso-wood includes.  It's not
very general, though, since when tweaking one, you have to tweak the other,
by hand, but the increased effectiveness is worth it.  I can now do things
like grains, having the dark wood rougher, while the light wood is smooth
and shiny (this is what the oak in my house is like) rather than just having
the depth be uniform.
If you want to see my tweaks, I can send them to you.  I can also post a
picture if what I'm talking about isn't clear.
Geoff
Date: 10 Nov 2000 09:40:59
Message: <3A0C08F8.946A8003@schunter.etc.tu-bs.de>
> Geoff
That sounds interesting, i already made some tries with pigment_maps and would
be really interested to see your efforts.
Specifying the function pigment and texture separately is a bit problematic for
some additions i made like the distorted plank in the picture, but i think i
could find a solution.
Date: 10 Nov 2000 11:07:08
Message: <3a0c1d2c$1@news.povray.org>
The main point of my post? I have come to the conclusion that layered
textures are a requisite of wood. It is my observation that some of the new
additions to MegaPov will help us achieve realistic wooden textures and
surfaces. My work continues (very slowly) and I hope you clear away a few of
the problems I ran into initially.
Good luck!
Grim
