POV-Ray : Newsgroups : povray.binaries.images : Icy coast 2 (101 k) Server Time
24 Mar 2026 03:28:00 EDT (-0400)
  Icy coast 2 (101 k) (Message 20 to 29 of 29)
Subject: Re: Icy coast 3 (radiosity)
Date: 26 Jul 2000 06:44:33
Message: <397ec111@news.povray.org>
Christoph Hormann wrote in message
<397EBE9B.CF6DDBCA@schunter.etc.tu-bs.de>...
>Thanks,
>most of the features are quite conventional, no media, no isosurfaces.  I'm
not
>going to publish the whole scene, but if you are interested in a specific
>element, that should not be the problem.
>Christoph
I'd be very interested to see the texture for the distant mountains. I
haven't
had much success with slope dependent textures.
Thanks
Gail
* gsh### [at] monotixcoza              * Reality.dat not found         *
* http://www.rucus.ru.ac.za/~gail/ * Attempting to reboot universe *
* The best way to accelerate Windows NT is at 9.8 m/s^2      *
Date: 26 Jul 2000 07:04:38
Message: <397EC5D5.230A2180@schunter.etc.tu-bs.de>
> haven't
Oh, that's really simple:
#declare T_ARCTIC_01 =
texture{
    slope -z
    texture_map{
      [0.1 T_SnowA ] //flatter
      [0.1 T_Rock ]  //steeper
in left handed system, you would use slope y.
I use different settings for  T_SnowA and T_Rock for w/o radiosity and changing
the values quite often, good values are also dependant on the lighting
situation.
one example (i think i used this for the radiosity version):
#declare T_SnowA =
   pigment { rgb 1 }
   finish {
      ambient 0.0
      diffuse 0.6
      specular 0.3
      roughness 0.6
      brilliance 0.4
Date: 26 Jul 2000 14:06:18
Message: <397F283D.17081943@pecos.no-spa-m.de>
Hi Christoph, great scene!
Christoph Hormann wrote:
> Marc-Hendrik Bremer wrote:
> > Wow, I really like this one! Any change to see some code? I never tried most
> > of the features you used here and I would be glad to see them in action.
> > I really, really like it ....
> > Marc-Hendrik
> Thanks,
> most of the features are quite conventional, no media, no isosurfaces.  I'm not
Ha, if this is so then let me ask for the most secret part
of the scene ;-)
Any chance to get the parameters of the RMFs? (I guess it's
a superposition of more than one RMF, right?)
Two other things that come to mind: Scaling down the ice floes
by say 0.5 or 0.3 would make the mountains look more majestic.
And then: Wouldn't the moving water leave dark areas on the snow
near the water line?
Well, I'm nitpicking, I know ...
-Hans-
Date: 26 Jul 2000 14:57:01
Message: <397F3485.E61F8C40@schunter.etc.tu-bs.de>
Thanks.
> of the scene ;-)
No, it's one simple RMF:
H: 0.1
lacunarity: 3.1
octaves: 8
offset: 0.7
gain: 0.8
But it's generated with a seperate program using a different random number
generator, so results will not be the same in POV :-)
maybe, i will think about it...
I'm already working on that.
Date: 26 Jul 2000 18:36:42
Message: <slrn8nupf0.bnc.steve@zero-pps.localdomain>
On Wed, 26 Jul 2000 11:06:40 +0200, Christoph Hormann wrote:
>last night i rendered a version with radiosity, took about 6 hours, here is the
>result, it's much more blueish, but i somehow like it too.
>http://www.schunter.etc.tu-bs.de/~chris/arctic_a03.jpg
Probably won't get to see this as I'll have to dial in
especially to see it.
 10:36pm  up 11 days, 21:02,  2 users,  load average: 1.00, 1.00, 1.00
Date: 27 Jul 2000 03:24:31
Message: <397FE3B9.51D1700C@schunter.etc.tu-bs.de>
Oh i'm sorry, but are you not curious enough to do that ?
I just did not want to occupy space with so many versions of the same scene.  If
you really have problems, I can send it via email :-)
Date: 27 Jul 2000 04:11:08
Message: <397FEE44.D1AEB0D4@pecos.no-spa-m.de>
Thanks for the parms, Christoph!
This is interesting. Just out of curiosity: Why do you use
an external program? Speed?
And how does this prog interface to pov? Do you import the
result as a height-field?
I found that iso's get _very_ slow when superposing eg 3 or
more RMFs, so using an external prog might speed it up a lot.
Eagerly waiting for Icy Coast 4 ...
-Hans-
> Thanks.
> > of the scene ;-)
> H: 0.1
> lacunarity: 3.1
> octaves: 8
> offset: 0.7
> gain: 0.8
> Christoph
> Homepage: http://www.schunter.etc.tu-bs.de/~chris/
Date: 27 Jul 2000 10:22:08
Message: <3980459B.2CA32EAD@schunter.etc.tu-bs.de>
It's faster to try different parameters and also easier.
In povray you have to render the scene to see the result.  Furthermore, if you
do not like a particular arrangement, you have to do some translate stuff to get
something different, I only have to take a different random seed.
Yes.
As i already said, i currently only use one RMF.  In my program, superposing 3
calculations would require 3x the time.  I expect, it's the same with an
isosurface.
It will probably come... sometime
Subject: Re: Icy coast 2 (101 k)
Date: 27 Jul 2000 19:03:13
Message: <3980BDDB.EE664846@faricy.net>
Iceberg Lake, Glacier-Waterton...
Looks like a HF?
Date: 27 Jul 2000 19:03:54
Message: <3980BE05.A37FCC63@faricy.net>
> Looks like a HF?
Of course, I missed that in the original
