Andy
That makes sense, and particularly if it's bundled with the next
or even the current official distribution of POV.
Steve
Andrew Cocker wrote:
> I'd like to see all these tree and grass macros in one "vegetation.inc"
> Andy
> --The Home Of Lunaland--
> --visit my POV-Ray gallery--
> --listen to my music--
> www.acocker.freeserve.co.uk
> Lewis <ble### [at] netvisionnetil> wrote in message
> news:37163924.6C8A93DD@netvision.net.il...
> > I had another weird idea:
> > Let's compile a library of trees, made with Giles macro. Using a macro
> > to generate random trees, each one starts it with a different seed and
> > sends in the results (the include files). It could be very useful. Maybe
> > someone will need a couple of trees sometime. Instead of parsing, say,
> > 100ds of them, he will just download them.
> > Anyone with me? If there will be enough enthusiasm I'll set up a web
> > site or somethin'.
Steve <sjl### [at] ndirectcouk> wrote in message news:37167060.9D062CFD@ndirect.co.uk...
> Andy
> Steve
Agreed. Someone mentioned recently that POV should be bundled with Colefax's includes
for
example. They're all tiny files, and would save a lot of searching for the newcomer.
In my
case, I had no idea that the lens flare includes were available until recently, and
since
then I have put his AutoClck.mcr file to much use.
Where are you Steve?
Andy
povray.binaries.utilities
Well, this isn't what I thought it was going to be after all.
I've only messed with Sonya Roberts plant includes before. I've been
meaning to get back to some trees. Good luck with this idea, and yeah,
who *doesn't* think a lot of the wellknown and useful includes, macros,
etc, shouldn't be included. No one probably, so it must be a secret
password needed to add to the "official" distribution eh? :)
> site or somethin'.
mailto:inv### [at] aolcom?Subject=PoV-News
Don't even get me started...
Ken Tyler
mailto://tylereng@pacbell.net
hmm, this probably doesn't fit in this group, but should be in a separate mail
to Giles. but then, hehe.
To ease it all up with object placing and scalability, can you make the trees
all downscaled(upscaled) to a bounding_box{<0,0,0>,<10,10,10>}. This would help
a lot, and would also remove the need to recalculate the tree to fit.
I have an automated rescaler #macro here somewhere, if you are interested...
> site or somethin'.
//Spider
[ spi### [at] bahnhofse ]-[ http://www.bahnhof.se/~spider/ ]
"Marian"
By: "Sisters Of Mercy"
Hmm. It could be useful in some cases, and a little cumbersome in others.
Personnally I prefer having the trees not scaled and adjust the size using the
dummy bounding box: for instance, if you generate several trees just but changing
the random seed or the recursion level, you'll get trees of different sizes but
with a similar scale. If the trees were post-scaled, you'd get even-sized trees but
with actually different scales, so you would have to make trial-and-error scaling
to have trees consistent with each other. There's also the fact that the trees
don't exactly fit in a box. Some of them crawl, some shoot up, so there's no ideal
unit-size bounding box. In fact people who provide really good 3D trees also
provide the "real life" bounding box : see http://iris8.cirad.fr/index.htm and look
at the plant catalogue.
Now if you really want it, I can add it as an option.
Gilles
> > site or somethin'.
> //Spider
> What I can do and what I could do, I just don't know anymore
> "Marian"
Sorry to disagree again, but no, It can be done with a good uniform scaling of
the object so it keeps the curent scale of the objects. This should be quite
easy to implement.
something like this is in my mind..
translate -1*MinExtent
//that should center the object with one corner on <0,0,0>
Then there should be a scaling, something like:
scale 1/(MaxExtent-MinExtent)
in my mind the tree will keep it's scale in sizes, but be downscaled to fit...
perhaps I'm to tired to think straight, but then, what good is straight?
(Go chaos, go)
> Gilles
> > > site or somethin'.
> > //Spider
> > "Marian"
//Spider
"Marian"
Speaking for Gilles (I must be mad these clothes are too big for me, they
don't fit, and I can't find a good scaling macro...)
Well, I really don't believe Gilles doesn't know how to scale a tree, but he
says that you can have the need for two trees of different heigh but with
the same leaves, if they are both scaled down to the unit box, you'll spend
you life trying to find the good scaling factor to get them having the same
leaves (same problem with the texture... ) the different trees *needs* to be
consistent, the don't need to be the same size)
Philippe
of
quite
>easy to implement.
fit...
>(Go chaos, go)
using the
changing
sizes but
trees but
scaling
trees
no ideal
also
>> Gilles
separate mail
trees
would help
interested...
macro
and
Maybe
say,
>> > > site or somethin'.
>> > //Spider
>> > "Marian"
>//Spider
> "Marian"
Ok, then I understand :-)
I must say I was a bit slow when reading Gilles mail.(A bit, I had a pice
of
coded that by "acccident" looped n^3*6 times while parse instead of n^3..
*humming*
I must say that I didn't get the referring until you explained. I'm _real
ly_
slow.. *duh*
ey
ut he
th
pend
same
to be
> Philippe
aling
> of
> quite
> >easy to implement.
o
> fit...
t?
> >(Go chaos, go)
hers.
> using the
but
> changing
t
> sizes but
sized
> trees but
error
> scaling
the
> trees
ere's
> no ideal
ees
> also
> >> Gilles
> separate mail
e the
> trees
is
> would help
it.
> interested...
> macro
ed
> and
l.
> Maybe
> say,
web
> >> > > site or somethin'.
> >> > //Spider
> >> > "Marian"
> >//Spider
> > "Marian"
//Spider
"Marian"
