POV-Ray : Newsgroups : povray.binaries.images : Rerender of previous post (for Simon and Steve) Server Time
3 Oct 2024 02:22:46 EDT (-0400)
  Rerender of previous post (for Simon and Steve) (Message 1 to 10 of 12)
Subject: Rerender of previous post (for Simon and Steve)
Date: 4 Mar 2000 05:30:30
Message: <38C0E61A.B47E1D5D@t-online.de>
Hi !
This is a rerendered version of my previous post. I hope it's not so
bright now and better readable.
Still no photons because it seems useless for this image.
I tweaked the area_lights and reflection. Render Time now: little more
than two hrs.
Karl
Download 'futurglasslogo.jpg' (21 KB)
Preview of image 'futurglasslogo.jpg'
Subject: Re: Rerender of previous post (for Simon and Steve)
Date: 4 Mar 2000 07:29:33
Message: <slrn8c1s95.2om.sjlen@zero-pps.localdomain>
On Sat, 04 Mar 2000 11:31:54 +0100, Karl Pelzer wrote:
>Dies ist eine mehrteilige Nachricht im MIME-Format.
>--------------8E0A7C43AA9DA0B3BFD6D1E5
>Content-Type: text/plain; charset=us-ascii
>Content-Transfer-Encoding: 7bit
>Hi !
>than two hrs.
That's really nice colouring on the wall there.  You might try faking it
a bit with some small green spotlights, if you look at the titles of
the pages on my website, I havn't used any lense flare, I've used coloured
spotlights normally at about say Green*0.1 and very close to the object.
Those lense flares remind me a bit of the cover of the Best of Blondie album,
they still look too bright to me, but if you like them, keep them they way
they are.
I'd be interested to know from one of the photographers out there if you can
actually get two different shaped lense flares in the same image.
 10:42am  up 1 day, 10:55,  3 users,  load average: 1.65, 1.27, 1.12
Date: 4 Mar 2000 09:39:35
Message: <38C11FD7.6EEB56D9@stud.ntnu.no>
This is not lens flare. You can get this effect with a filter, but the stars
will then have equal number of arms.
sig.
Date: 4 Mar 2000 10:36:00
Message: <38C12DB7.AEBDEDEB@t-online.de>
The different stars were not intended. Just a mistake :-)
When I found out myself, I didn't want to stop rendering.
BTW, I took a look at your web-site logos. Nice effect. I never thought
of using additional light sources because rendertime will increase. In
my special case rendertime would higly(!) increase. So faking with Chris
Colefax' LensFX is allright.
Karl
Date: 4 Mar 2000 12:56:08
Message: <38c14e38$1@news.povray.org>
Hello Karl,
Seeing that I come from a typograpoher's family, I cannot help remarking
that the text is not very well readable. The type is not balanced: I had
really great difficulty in getting the word at all! Especially the top
stroke of the "T" is much too short compared with the layout of the other
characters. The flare on the first "U" prevents you to easily see whether
this is a single char or two chars. In general the flares make reading
difficult...
I hope you are not mad at me now!?! :) :) :) :)
Sander
Karl Pelzer <Kar### [at] t-onlinede> schreef in berichtnieuws
38C0E61A.B47E1D5D@t-online.de...
> Hi !
> than two hrs.
Date: 5 Mar 2000 06:29:12
Message: <38C24560.CA3EFEC3@t-online.de>
No way ;-)
Karl
Date: 5 Mar 2000 15:02:54
Message: <1rrCOPwiu5BzDoFg2ELPRlkAumd3@4ax.com>
Yes... but it would almost certainly involve multiple exposures, and
in this case, moving the lighting between exposures or multiple lights
that are individually switchable.
First, take one exposure with a light arranged to give you the
highlight on the left. Use a 6-point star filter for this exposure.
Second, move the light to a new position to give the highlight on the
right. Use a 4-point star filter to photograph the same scene with the
new lighting. This second exposure is done on the same frame of film
as the first.
Individual exposure times will need to be cut in half, in relation to
a normal single exposure of the scene, to restore a proper over-all
brightness for the frame.
So yes, it can be done.
Later,
Glen Berry
Date: 5 Mar 2000 15:08:50
Message: <8LzCOLRJq3SOIp9NVjU30EOq2bzc@4ax.com>
On Sat, 04 Mar 2000 15:38:15 +0100, Sigmund Kyrre Aas
Why do you say this is not lens flare? One doesn't always need to use
a filter to create star patterns from bright highlights. Sometimes the
iris inside the lens itself will create such a pattern. The shape of
the iris will control the number of "arms" in the star pattern.
Are you reserving the term "lens flare" only for those "colored disks"
of light that sometimes appear in photos? Just for the record, what
*do* you mean when *you* refer to lens flare?
Later,
Glen Berry
Date: 5 Mar 2000 17:02:27
Message: <38C2D7B3.B9DD7E15@stud.ntnu.no>
Guess I should have elaborated on that. Sometimes subtlety gets lost on it's
way from my Norwegian speaking brain to the keyboard.
When a photographer sees this image, he thinks star filter, not lens flare.
I consider lens flare a flaw in the lens producing light of any shape that's
not really there. I just don't believe that the stars in Karl's image could be
generated by a lens. I know flare shapes and sizes depend on the lens, but
these are way too big. Okay, I guess you might argue that foo still is foo even
if it's out of scale, but not if it has a much stronger resemblance to bar.
Me sig, you Jane.
Date: 5 Mar 2000 22:51:37
Message: <38C32992.601EA36B@pacbell.net>
> as the first.
> Later,
> Glen Berry
I am not altogether convinced that multiple exposures are necessary. For
example I was watching a PBS program the other day that talked about the
formation of new stars. One thing that I noticed in the actual star images
they were showing was that perhaps one in one thousand stars shown were
bright enough that they had star shaped flares coming off of them. These
were present not only in the center of the image but reaching out to the
edges as well.
