POV-Ray : Newsgroups : povray.binaries.animations : first tests with 4th order RK (clothing) Server Time
27 Nov 2026 16:56:34 EST (-0500)
  first tests with 4th order RK (clothing) (Message 1 to 17 of 17)
Subject: first tests with 4th order RK (clothing)
Date: 25 Feb 2002 19:28:13
Message: <3c7ad69d$1@news.povray.org>
Finally managed to get some time to implement 4th order Runge-Kutta for an
improved clothing animation program. I started all over again, from scratch.
No cloth-cloth or cloth-solid collission testing yet. That will come later.
This message includes one of the test animations. The higher quality
animation is available at
http://geitenkaas.dns2go.com/experiments/cloth07test3_640x480.divx412.avi
(787,532 bytes)or
http://geitenkaas.dns2go.com/experiments/cloth07test3_640x480.mpg (1,282,052
bytes).
Check http://geitenkaas.dns2go.com/experiments/ for more animations. The
cloth07 series is the latest series, created using the Runge-Kutta method I
mentioned above.
And please don't ask me why I positioned that piece of sheet nearby the top
edge of the screen   ;-)
Subject: Re: first tests with 4th order RK (clothing)
Date: 25 Feb 2002 19:31:10
Message: <3c7ad74e@news.povray.org>
Download 'cloth07test3_320x240.mpg' (473 KB)
Date: 26 Feb 2002 02:40:52
Message: <8jem7uc4pijagb188l4kjl0v8miv4ech3r@4ax.com>
Looks pretty fast to me (how much iterations per frame?), and of
course really stable. Kudos.
Next thing you'll want to do: Xavier Provot's hybrid cloth technique
:) And of course the famous "Large Steps in Cloth Simulation" paper
(Pixar! Pixar!)
Never mind me, I haven't had my morning coffee yet.
Peter Popov ICQ : 15002700
Date: 26 Feb 2002 03:34:04
Message: <3c7b487c@news.povray.org>
It's obviously made of gum this time, not fibre... :o)
Does your collision detection work with any shape?
Hugo
Date: 26 Feb 2002 08:40:41
Message: <3c7b9059@news.povray.org>
Wow! It actually stabilizes! Amazing. Very nice. Keep it up! :)
Date: 26 Feb 2002 14:23:35
Message: <3c7be0b7@news.povray.org>
It looks great how if converges to a quiet state, even though it still looks
a little bit rubbery at first.
I'm glad you've got some excellents results in so few days!
Keep up the good work.
Fernando.
Date: 26 Feb 2002 16:37:29
Message: <3C7BFF84.43394BD8@yahoo.com.au>
Looks good. The rippling movement is nice. How many points define this cloth?
The corners of the cloth look like they are under alot of tension. Have you tried
fixing more points around the corners (3 or 4, or more points)? It might help to
get rid of the "about to break" look that most cloth sims with fixed points seem
to display.
MJL
prism{0,.1,30#local I=1;#while(I<30)#local B=asc(substr(// Mark James Lewin
"#K?U_u`V[RG>3<9DGPL.0EObkcPF'",I,1))-33;<div(B,10)-4mod(B,10)+5*div(I,21)-
6>#local I=I+1;#end,-4pigment{rgb 9}rotate-x*90translate 15*z}//POV-Ray 3.5
Date: 26 Feb 2002 19:12:06
Message: <3c7c2456@news.povray.org>
This is just a first test. In more 'serious' scenes I won't fix cloth at
just a few single nodes. But still I want to get rid of that 'about to
break' problem. The first solution I can think of is decreasing the step
size and increasing the stiffness of the springs.
The animation I submitted before used timesteps of 0.04 and 20 steps per
frame. The animation with this message uses timesteps of 0.08 and 10 steps
per frame.
Both sheets are 50x50 nodes (or atoms).
As you can see the sheet of the new animation (cloth07test4, the one
attached to this message) needs more time to settle down and the sheet is
more flexible. That's caused by the larger time step. Maybe using 5th or 6th
order Runge-Kutta would even improve the thing more? So my next question
would be: I would like to know HOW them people (mister Runge and mister
Kutta?) got to that Runge-Kutta algorithm.
A part of the R-K algorithm: Vnew = Vold + (K1+ 2*K2 + 2*K3 + K4) / 6
Why oh why wouldn't it be Vnew = Vold +(K1 + 3*K2 + 2*K3 + K4) / 8 or
something else? Maybe someone told/taught it me some time ago when I wasn't
paying attention. If I know how them people got that formula, I would be
able to get higher order algorithms by myself.
Apache
Download 'cloth07test4_320x240.mpg' (547 KB)
Date: 26 Feb 2002 19:28:16
Message: <3c7c2820@news.povray.org>
Aha! I know now why the latest rubber sheet needs more time to stop moving.
The program dampes only once per time step. So with 10 time steps per
animation frame there's less damping than with 20 time steps per animation
frame.
I should fix this bug...
Date: 26 Feb 2002 19:35:56
Message: <3C7C293E.B76C729B@yahoo.com.au>
That came to my mind too. I'm sure you also know how much that will slow the
simulation down by too :-)
Does this cloth have the same number (and strength) springs too? I would not have
expected this large a change in flexibility by changing the time step (and
consequently the number of steps) alone.
I confess to know little of these methods. These links explain 2nd and 4th order
RK. They may be of some use.
http://nacphy.physics.orst.edu/ComPhys/DIFFEQ/mydif2/node5.html
http://nacphy.physics.orst.edu/ComPhys/DIFFEQ/mydif2/node6.html
Math has never been a strong point for me.
Date: 26 Feb 2002 19:44:55
Message: <3C7C2B57.6C74F34F@yahoo.com.au>
> frame.
How much damping do you use? I woudn't have expected it to have such an effect on
the flexibility.
MJL
Date: 26 Feb 2002 20:12:14
Message: <3c7c326e$1@news.povray.org>
The damping factor I used: 0.997 per time step.
Date: 26 Feb 2002 20:39:07
Message: <3c7c38bb@news.povray.org>
What kind of damping are you using?
velocity = velocity * damping_factor?
I've read that that kind of damping is not very good.
Baraff et al, in "Large-steps in cloth animation" recommend a more
complicated dampening system which depend in some condition functions (which
are related to the energy of the cloth), but I found it a bit complicated
and tried to look for something similar but simpler. I implemented the
following dampening process (and I think I got good results):
Add another modification to the force vector which is proportional to the
velocity (but in opposite direction):
f = -k * v (for some dampening constant k)
This serves as some kind of friction. However Baraff et al, strongly
emphasize that any dampening process must be relative to "in-cloth"
movements and not because of other external forces (did I explain
myself????)
So, I implemented
f = -k*w
where w is the projection of the velocity vector in the plane tangent to the
cloth's surface. Later I tried with a intermediate mix, and it also worked
well.
If you implement this, I hope you can tell me if it works or not.
Anyway, congratulations on your advances.
Fernando.
Date: 26 Feb 2002 20:53:12
Message: <3c7c3c08$1@news.povray.org>
Yes.
I did these test just to make sure that R-K actually worked in my
implementation. Any damping, cloth-solid / cloth-cloth / cloth-fur
collission detection will be implemented by me in the next few
years...ehhh... weeks.  ;-)
Date: 27 Feb 2002 01:19:43
Message: <66uo7ugd3nouircifsuoabb8u2ls6j0ptv@4ax.com>
On Tue, 26 Feb 2002 19:39:03 -0600, "Fernando González del Cueto"
>myself????)
LOL, I remember making this mistake in my early dynamic body
simulations. I would have the velocity damped alright, but that
velocity was the result of integrating an acceleration which was
proportional to the net force acting on a node,  both internal and
external forces... As a result, as I was using viscuous damping
(velocity-based), it looked as if the body was submerged in a liquid,
slowing down for no apparent reason etc. Took me some time to redesign
it, I ended up splitting up velocity in two components (internal and
external) and storing both of them to the next iteration, only adding
them at the end to find displacement.
Date: 27 Feb 2002 14:02:04
Message: <137q7ust01pph2ubhs5k61ajh4jvqi7tn3@4ax.com>
This routine is called RK45 or Runge-Kutta-Fehlberg. It involves a
fifth order RK method where the difference between the fourth- and
fifth order evaluations is an estimate of the truncation error for the
classical rk4 procedure. The error estimate is used to change the
increment size. I've programmed it in Matlab that involves some
obscure matrix expressions, so I've converted it to pseudo pov.
This routine seems to perform just as well as Matlab's own ode45,
which I've used in many fluid and thermodynamics problems whitout
problems. Problems can arise with stiff, coupled systems but I don't
think cloths can be characterized as such.
It takes the function f(t,x) for the differential equation and finds
the value of x at t=t+h Input: t (current time), h (step size), x
(current variable value). At the end, t and x are updated to the next
time step.
#macro rk45(t,x,h)
c20=.25
c21=.25
c30=.375
c31=.09375
c32=.28125
c40=12/13
c41=1932/2197
c42=-7200/2197
c43=7296/2197
c51=439/216
c52=-8
c53=439/216
c54=-845/4104
c60=.5
c61=-8/27
c62=2
c63=-3544/2565
c64=1859/4104
c65=-.275
a1=25/216
a3=1408/2565
a4=2197/4104
a5=-.2
b1=16/135
b3=6656/12825
b4=28561/56430
b5=-.18
b6=2/55
k1=h*f(t,x)
k2=h*f(t+c20*h,x+c21*K1)
k3=h*f(t+c30*h,x+c31*k1+c32*k2)
k4=h*f(t+c40*h,x+c41*k1+c42*k2+c43*k3)
k5=h*f(t+h,x+c51*k1+c52*k2+c53*k3+c54*k4)
k6=h*f(t+c60*h,x+c61*k1+c62*k2+c63*k3+c64*k4+c65*k5)
x4=x+a1*k1+a3*k3+a4*k4+a5*k5
x=x+b1*k1+b3*k3+b4*k4+b5*k5+b6*k6
t=t+h
error=abs(x-x4)
#end rk45
The next routine uses rk45 and it's error output to increase or
decrease the time increment if the error goes beyond error_max or
below error_min. If its between the increment is kept unchanged.
sign(h) returns the sign of h. The following macro would do the trick:
#macro sign(a) a^2/(abs(a)*a) #end
I'm not sure how to code the exit_while_loop, but I'm sure it's
possible.
h is the initial time step size, tb is stop time, hmax and hmin are
upper and lower bounds on the  step size and errormin and errormax are
the error bounds. iflag has value 0 or 1: iflag=0 means successful
integration from ta-tb, iflag=1 means maximum number of iterations
reached.
#macro rk45Adaptive(t,x,h)
tb=2
itmax=1e4
errormax=1e-3
errormin=1e-4
hmin=1e-3
hmax=5
delta=1e-5
iflag=1
k=0
while k <= itmax
 k=k+1
 if (abs(h)<hmin) h=sign(h)*hmin end
 if (abs(h)>hmax) h=sign(h)*hmax end
 d=abs(tb-t)
 if (d<=abs(h))
  iflag=0
  if (d<=delta*max(abs(tb),abs(t)) exit_while_loop
  h=sign(h)*d
 end
 xsave=x
 tsave=t
 rk45(t,x,h)
 if (iflag=0) then exit_while_loop
 if (error<error_min) h=2*h end
 if (error>error_max)
  h=h/2
  x=xsave
  t=tsave
  k=k-1
 end
end
#end rk45Adaptive
ICQ 74734588
Date: 27 Feb 2002 18:51:55
Message: <3c7d711b$1@news.povray.org>
My goal is to get rid of as much elastic behaviour as possible. Very
difficult thing to do if I want to maintain big step sizes. The cloth
'explodes' or I'm getting some very weird overflow problems all the time
trying to get rid of all that elasticity.     Terrible  :-(
I'm surprised that I managed to get RK4 working after all. And sometimes I'm
wondering if/when I'll get the system working the way I want it to: (very)
fast, stable and (more or less) realistic.
I think that using variable step sizes would be a good thing.
