POV-Ray : Newsgroups : povray.binaries.animations : Rather Elementary UJoint 508KB Server Time
16 Oct 2025 15:58:14 EDT (-0400)
  Rather Elementary UJoint 508KB (Message 1 to 8 of 8)
Subject: Rather Elementary UJoint 508KB
Date: 17 Dec 2001 16:50:49
Message: <3c1e68b9@news.povray.org>
Here is my first ever articulated joint.  I don't know if it qualifies as
inverse kinematics - I use a vector to define the orientation of the moving
axle.  Toughts?
Michael
Download 'UJoint.MPG' (509 KB)
Subject: Re: Rather Elementary UJoint 508KB
Date: 18 Dec 2001 08:00:38
Message: <3C1F3DF6.12EEB70A@gmx.de>
> axle.  Toughts?
I think this is a very good demonstration for the fact that this kind of
joint does not lead to constant angular velocities on both sides.
Date: 18 Dec 2001 12:22:15
Message: <3c1f7b47@news.povray.org>
> Christoph
You know, that's interesting - when i was testing the animation, i had
accidentally rotated the axle the wrong way, and when it hit about 90
degrees relative to the other, it pretty much stopped.  Looking at the one i
posted,  i can see how the angular velocity becomes more erratic as the
angle between the two axles gets farther away from 180 degrees.  This is
really interesting because the front wheels on my old jeep are connected to
the font axle by U joints, and it's an all wheel drive.  Maybe that explains
the funny wobbling motion it makes on really tight turns.  I wonder if CV
joints would have constant angular velocities on both sides, and that's why
they are used now?
michael
Date: 18 Dec 2001 17:02:33
Message: <3C1FBCF3.EBB1FB5F@gmx.de>
> they are used now?
I don't know what 'CV joints' are, but these days you mostly use what is
called 'Gleichlaufgelenkwelle' in German.  The single joints look somewhat
similar to a ball bearing.
Date: 19 Dec 2001 12:57:22
Message: <3c20d502$1@news.povray.org>
I used to have a CJ-7, pretty old and beat up.
The reason your jeep wobbles is because it doesn't have a differential in
the front.  The inside wheel should be moving less than the outside, but it
doesn't, so they fight.  When one tire slips a bit the jeep 'wobbles'.  It's
not the CV joint per se, it's the lack of the differential.  A CV joint
would have the same problem.  All wheel drive units have three
differentials.
For Christoph, 'CV' joint means "Constant Velocity Joint".
== John ==
"Michael McKnight" <nes### [at] hotmailcom> wrote in message
news:3c1f7b47@news.povray.org...
> > Christoph
i
to
explains
why
> they are used now?
> michael
Date: 19 Dec 2001 17:39:06
Message: <3c21170a@news.povray.org>
I have an old  and beat up jeep wagoneer...my insurance company thinks it's
a sport wagon, whatever that means :)  i'm pretty sure it's got a
differential on the front too...anywho, i think my next anim's going to have
to be a cv joint.  i found some good pictures on the net.  thanks for the
heads up on the definition.
Michael
"John D. Gwinner" <jgw### [at] dazsicom> wrote in message
news:3c20d502$1@news.povray.org...
it
It's
> differentials.
> == John ==
Date: 21 Dec 2001 18:44:47
Message: <3c23c96f@news.povray.org>
What a peculiar joint. I've never seen one like that. It's pretty cool. :)
Date: 21 Dec 2001 23:45:40
Message: <3c240ff4@news.povray.org>
Why thank you!
"Tony[B]" <ben### [at] catholicorg> wrote in message
news:3c23c96f@news.povray.org...
