POV-Ray : Newsgroups : povray.binaries.animations : And my Earth, day/night :-) [~403K Mpg] Server Time
20 Jul 2024 13:14:10 EDT (-0400)
  And my Earth, day/night :-) [~403K Mpg] (Message 1 to 8 of 8)
Subject: And my Earth, day/night :-) [~403K Mpg]
Date: 5 Dec 2000 00:55:10
Message: <3a2c833e@news.povray.org>
My rendition, following Matt Giwer.
This is what I mentioned before that I had done a while back.  By using a
gradient pigment pattern for masking, in order to block the underlying overly
luminous night-lights map (this has that JPL one replacing the other wrongly
scaled map I had used before), placed under a slightly transparent surface
image map which in this animation is the darkened oceans by someone around
here.  Sorry, I forget the name and I don't want to guess wrong.
Not any easier to explain than that.
I was adjusting some on this while I had it out of mothballs anyhow and I
didn't get the shadow line exactly as I wanted but I had to give up and get
this over with for now.
Added note:  this might be difficult to discern well unless you either turn off
the room lights (at night anyway) or play full screen, or both.  Fast and
small.
omniVerse http://users.aol.com/persistenceofv/all.htm
Download 'e@dn.mpg' (297 KB)
Subject: Re: And my Earth, day/night :-) [~403K Mpg]
Date: 5 Dec 2000 07:25:22
Message: <3a2cdeb2$1@news.povray.org>
Another winner.
I notice a tendency for folks to model both the earth and the terminator
line as vertical.  While it is an accurate representation twice a year
(spring and fall equinox?) I think it might be more interesting to look at
the earth in mid-summer.  Try tipping the earth's main axis by 23 degrees or
so (hope I got that angle right) to illustrate things like why the sun
doesn't set above the arctic circle in the summer.  Just a thought.
Nice movie.
"Bob H."
<per### [at] aolcom?subject=PoV-News:%20&body=Relating%20to%20POV-Ray:>
wrote in message news:3a2c833e@news.povray.org...
overly
wrongly
get
turn off
> small.
> Bob
Date: 5 Dec 2000 11:27:27
Message: <3A2D1770.61C24939@ij.net>
Spock wrote:
> Another winner.
	Well taken.
1998: Archaeologist identifies Wailing Wall as the wall of
a 17th century cemetery.
1998 + 2 seconds:  his permit is pulled. So sacred the myth.
	-- The Iron Webmaster, 182
Date: 5 Dec 2000 16:47:23
Message: <3a2d626b$1@news.povray.org>
"Matt Giwer" <jul### [at] ijnet> wrote in message news:3A2D1770.61C24939@ij.net...
or
> Well taken.
It would have been :-) were it not for this being the result of aligning (no
pun intended) the two image maps and two gradient masking textures.  I realize
you can't see Europe much at all because of this vantage point.  Luckily there
isn't anything near the South Pole so a view from over the Tropic of Cancer
demarcation line at 23.5 degrees north of the equator would be better.
Bob H.
Date: 5 Dec 2000 18:45:52
Message: <3A2D7E2D.681409EB@ij.net>
> or
> > Well taken.
	That sounds a bit like what I did in my animation above. I can give
them both a tilt after rotating. I'll give it a try. should work.
	BTW: Mine started as three separate lays for the lit side. I overlayed
then and flattened them. They render much faster that way and nothing is
lost as you still have your original layers.
If drugs are as bad as they say there is nothing
the law can do to a user that is worse.
	-- The Iron Webmaster, 97
Date: 6 Dec 2000 23:24:18
Message: <3a2f10f2@news.povray.org>
I put the latest version of mine at:
http://members.aol.com/persistenceofv/Earth_Day-Night.mpg
Hope you will like it, tilt and all.  I could adjust on it forever as with
everything else so I stopped at a point.
Bob H.
Date: 7 Dec 2000 10:46:09
Message: <3a2fb0c1@news.povray.org>
Looks good to me, but I'm not 100% sure about the whole tilt thing.
Its been a long time since I looked into this, but I think it goes something
like this:
- The earth goes around the sun on the "solar plane".  Most illustrations
show the camera on this solar plane so the light strikes the earth at 90
degrees and the terminator is vertical.
- The earth rotates about its axis (north pole to south pole), but this axis
is about 23.5 degrees off vertical.
- The earth's rotational axis always points in the same direction (i.e.
towards the north star) so the earth does not wobble as it goes around the
sun.
- If you combine all of these you get seasons.  I have attached a bitmap
illustrating summer in the northern hemisphere.  Six months later the light
would be coming from the other side and you would have summer in Australia.
I hope this makes sense and that I got my facts generally correct.
BTW, nice image... don't give up yet :-)
"Bob H."
wrote in message news:3a2f10f2@news.povray.org...
> Bob H.
Download 'earth.bmp.dat' (9 KB)
Date: 8 Dec 2000 21:03:00
Message: <3a3192d4@news.povray.org>
"Spock" <spo### [at] nospamcom> wrote in message news:3a2fb0c1@news.povray.org...
Thanks, but it's only for show :-) not meant to be "100%" astronomically
correct.  I put the Sun at -23.5 and the camera at +23.5 degrees.  The
rotations are: once for the camera, twice for the Earth.  That way it shows a
lot of the surface at both night and day.  The gradient masking textures are
stationary, as is the Sun.
Bob H.
