POV-Ray : Newsgroups : povray.binaries.animations : Re: Snake3, New and Improved! Server Time
23 Jan 2025 13:57:10 EST (-0500)
  Re: Snake3, New and Improved! (Message 1 to 5 of 5)
Subject: Re: Snake3, New and Improved!
Date: 2 Oct 2003 08:20:09
Message: <3F7C1772.33D9A576@onwijs.com>
Steve Shelby wrote:
> I solved the head-wagging problem by delaying the timing of the side-to-side
> movement of the spline by 0.04. It makes the unbending neck portion a little
> longer, but is that a problem?
> Steve Shelby
>    Snake3a.mpg    Type: WMPLAYER File (video/mpg)
>               Encoding: x-uuencode
Yes. 8)
Although I do think this looks excellent it does seem like he has a
stiff neck. Actually that isn't any different from the previous version,
so the problem may be something different.
I don't think the head should be totally motionless, it could wag a bit,
but not as fast as in v2.
This turns out to be more complicated then I'd have thought, having no
clear idea on how a snake actually moves forward...
Remco
Date: 2 Oct 2003 08:41:28
Message: <3F7C1C68.71878BD7@onwijs.com>
This is more or less what I was thinking about...
(old indeo codec)
Remco
Download 'snake.avi.dat' (78 KB)
Date: 2 Oct 2003 17:00:12
Message: <1vfu41-9r2.ln1@control-alt-del.ch>
> side-to-side movement of the spline by 0.04. It makes the
> unbending neck portion a little longer, but is that a problem?
> Steve Shelby
Looks much better now.. but for me it seems that the snake moves a
bit jerky. How did you connect the static part to the sine?
Greets
Dave
Dave "tPassive" Vogt| ruby -e "n=gets.to_i;a=(2..n).to_a;a.each{
Linux  user  #225040| |x|puts x;(x*2).step(n,x){|j|a.delete j}}"
____________________|_____________________________             |
PGP Key: http://control-alt-del.ch/public_key.asc \____________/
Date: 2 Oct 2003 22:24:33
Message: <3f7cdde1$1@news.povray.org>
I'm working on a way to shorten the neck while still having the head
pointing straight ahead. I'll post again when I get the right results.
Steve
"Remco de Korte" <rem### [at] onwijscom> wrote in message
news:3F7C1772.33D9A576@onwijs.com...
side-to-side
little
> > Steve Shelby
> Yes. 8)
> Remco
Date: 2 Oct 2003 22:39:59
Message: <3f7ce17f$1@news.povray.org>
"Dave Vogt" <dav### [at] control-alt-delch> wrote in message
news:1vf### [at] control-alt-delch...
It's all one spline, defined by an array of points, each of which has its
own time element. It starts out as a straight line, and each point is
translated to a + or - y value in progression along the x axis. See my
previous post, "Snake2 WIP".
Steve
