POV-Ray : Newsgroups : povray.binaries.animations : water waves simulation (349k) Server Time
16 Oct 2025 18:59:44 EDT (-0400)
  water waves simulation (349k) (Message 1 to 10 of 17)
Subject: water waves simulation (349k)
Date: 15 Nov 2001 12:01:14
Message: <3BF3F462.66F806EA@gmx.de>
The algorithm used for the waves is described in:
http://www.first.gmd.de/persons/bwalter/html/report/report.html
and in an article from the german computer magazine 'PC Magazin', issue
12/2001.
The main idea is to superpose several sine waves (160 in this case) with
different frequencies and directions according to a certain distribution
function.
It is right now implemented as a heightfield, i already thought about
generating an isosurface function instead, but i'm not sure how slow this
would be with 160 sine functions.
The main problem is of course that there is no interaction with the walls
of the pool and generating a sufficiently large water plane with a
heightfield is problematic.
Download 'waves5.mpg' (349 KB)
Subject: Re: water waves simulation (349k)
Date: 15 Nov 2001 12:38:31
Message: <3bf3fd97@news.povray.org>
Not too shabby! Would be nice to at least fake the interactions with the
environment...
Subject: water waves simulation 2 (348k)
Date: 15 Nov 2001 13:50:04
Message: <3BF40CFD.187F1131@gmx.de>
> environment...
Well, it's quite difficult to do this in a physically accurate way. Also
the technique in general is only meant to be realistic for deep ocean
water.
I have made another version with higher resolution, different scale and
viewpoint.  The single steps are a bit large, but otherwise i think it's
much better.
Download 'waves7.mpg' (348 KB)
Date: 16 Nov 2001 01:29:26
Message: <3bf4b246$1@news.povray.org>
I think it is very realistic!!! It is true that there is no interaction with
the walls, but I still think it looks very good!!!
Congratulations!
Fernando.
news:3BF3F462.66F806EA@gmx.de...
> 12/2001.
> function.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 17 Nov 2001 03:20:12
Message: <3BF61DBB.9DE383C5@gmx.de>
> Congratulations!
Thanks.
Date: 20 Nov 2001 17:50:49
Message: <3bfade49@news.povray.org>
The animations look really great.
> 12/2001.
I tried reading the article (after giving it a go with babelfish first) but
it's too
complicated for me. Would you mind sharing the .pov and possibly the .ini ?
> function.
I tried averaging 160 sine_wave gradients then rotating and scaling
semi-randomly
but the effect is nothing like with your approach. So how about atleast
giving the
rest of us atleast a clue
-Jide
Date: 21 Nov 2001 04:21:42
Message: <3BFB7218.72789514@gmx.de>
Thanks.
> it's too
The heightfield is not generated with Povray so the POV-code won't help
you much.  If i make a version using an isosurface i will post the code.
> > function.
> semi-randomly
> giving the
Simply random waves does not work, you have to use the correct
distribution functions for frequency and direction to get it right.
The formulas are given in:
http://www.first.gmd.de/persons/bwalter/html/report/node6.html
http://www.first.gmd.de/persons/bwalter/html/report/node7.html
Date: 21 Nov 2001 05:37:54
Message: <3bfb8402$1@news.povray.org>
It's propably better that way for speed. I generated my height_field with
function 1000, 1000
and parse time was about 2 minutes IIRC (Athlon 1,4Ghz). 1000,1000 doesn't
get you a lot of smooth water :)
with
distribution
> > > function.
> > semi-randomly
> > giving the
Yeah. I kind of suspected it from the result I got.
Anyway I'm eagerly waiting to see what you can do with this.
-Jide
Date: 21 Nov 2001 11:27:49
Message: <3BFBD605.EC38EA4@gmx.de>
Probably not, rendering the isosurface will be much slower than the
heightfield.
> function 1000, 1000
My animations used 256x256 and 512x512, generated with a separate program
that is faster than povray in this aspect (only a few seconds per frame)
The nice thing about an isosurface would only be that you don't need large
data files and it's possible to render arbitrarily sized water surfaces.
Date: 22 Nov 2001 06:05:48
Message: <3bfcdc0c@news.povray.org>
> heightfield.
Yeah. I meant generating a hf is good for speed but after looking at my
post I see I messed it up.
-Jide
