POV-Ray : Newsgroups : povray.binaries.animations : Re: Animated paperplane v0.1 - paperplane2.avi (1/1) Server Time
4 Nov 2024 21:22:47 EST (-0500)
  Re: Animated paperplane v0.1 - paperplane2.avi (1/1) (Message 1 to 10 of 16)
Subject: Re: Animated paperplane v0.1 - paperplane2.avi (1/1)
Date: 26 Feb 2001 12:03:04
Message: <3A9A8AE3.5AC84AA8@my-dejanews.com>
The etiquette around here is to post in MPG-1.
I dl'ed your file but Quicktime only showed me white space.
Nikodemus Siivola wrote:
>    paperplane2.avi    Type: AVI (video/avi)
>                   Encoding: x-uuencode
Subject: Re: Animated paperplane v0.1 - paperplane2.avi (1/1) - folding.mpg (0/1)
Date: 26 Feb 2001 14:49:43
Message: <3a9ab231.15612347@news.povray.org>
"Greg M. Johnson" <gre### [at] my-dejanewscom>:
Ooops... here comes mpeg1 - actually a different, IMO better version.
(Cancelling the AVI.)
 -- Nikodemus
Subject: Re: Animated paperplane v0.1 - paperplane2.avi (1/1) - folding.mpg (1/1)
Date: 26 Feb 2001 14:49:59
Message: <3a9ab373.15933411@smtp.hut.fi>
Download 'folding.mpg' (233 KB)
Date: 26 Feb 2001 16:44:02
Message: <chrishuff-9082D7.16425026022001@news.povray.org>
In article <3a9ab231.15612347@news.povray.org>, tsi### [at] cchutfi
Ah, thanks!
I was also unable to view the previous version, but people didn't seem
to like it much when I said something about it before, so I didn't say
anything.
How did you do the folding? Nested unions of triangle objects, or a mesh?
The only practical way of managing mesh triangles that I can think of
would be to use declared transformations and the vtransform() function
in MegaPOV...is this what was done?
Christopher James Huff
Date: 26 Feb 2001 17:14:01
Message: <3a9ad1f8.23747989@news.povray.org>
On Mon, 26 Feb 2001 16:42:50 -0500, Chris Huff <chr### [at] maccom>
Basically,
1. Declare control points in plane
2. Manipulate control points (folding macros based on vaxis_rotate()
   and stuff.
3. Declare mesh with triangles composed of control points
The .inc file is in povray.text.scene-files, but I cannot wouch for
it's readability - did a little cleaning up before posting, though.
The folding macros do all the real work. Additionally, there is a
little cheat that applies to two control-points: if they have negative
x-coordinates, their x-coordinates are set to 0 - just to keep the
paper from "tearing".
However, for the past hour I have been thinking of another mehtod:
1. Declare folds (just degrees for each known fold).
2. Declare control points using folds as parameters.
3. Declare mesh with triangles composed of control points.
Kind of neater, I think. Maybe for the next paperfolding thing I
make... I'll have to look into it.
Yours,
 -- Nikodemus
Subject: Re: Animated paperplane v0.1 -- 3 attachments (65KBU)
Date: 26 Feb 2001 20:16:08
Message: <3A9AFF6D.BC7DD671@xs4all.nl>
I did a similar thing some time ago.
I've attached some small examples.
Apologies for the awful quality but
the first AVIs were a bit too large
for my taste and when I converted
those to MPEGs they were half the
size but had similar quality to
these AVIs which are in turn less
then half the size of the MPEGs.
If the codec is a problem I could
post the larger (file) versions .
Since I needed to have images on both
sides I couldn't use a mesh (or at
least I didn't know how), so I used a
thin box with imagemaps, cutting and
folding. This is a recursive process
(isn't it?) and it took ages to render.
Come to think of it, I believe I
posted a message about this before...
Remco
http://www.onwijs.com/
Download 'pplane1.avi.dat' (17 KB) Download 'pplane2.avi.dat' (26 KB) Download 'pplane3.avi.dat' (22 KB)
Date: 27 Feb 2001 13:47:39
Message: <3a9bf64b@news.povray.org>
Nice ...
A bit of a strange thing happened to my player though:
When I clicked the first AVI, my machine connected to microsoft, and after a
couple of minutes said:
"Cannot play back the video stream: no suitable decompressor could be
found."
I tried again, it did the same. I tried a third time, same response.
So I clicked on your second AVI. It connected to microsoft and installed me
a new Codec. The AVI played fine. I clicked on the third AVI ... Fine.
I clicked on the first again, it plays now.
?  Microsoft site busy ? or damaged codec name in PPLANE1.AVI ?
N.B. I didn't have to download a Codec for you previos post.
Clever animation though, and whatever the problem was, I appear to be able
to play them all now.
Duncan Gray
(warning: may contain traces of nut)
Date: 27 Feb 2001 15:27:44
Message: <chrishuff-4312DF.15263427022001@news.povray.org>
In article <3A9AFF6D.BC7DD671@xs4all.nl>, Remco de Korte
These are unviewable on my system, how big are the MPEGs? Are they
really 4 times as big? Maybe it's the software or settings you are using.
I haven't found any good software for creating MPEGs on a Mac, I'm stuck
with QuickTime MooV format (which is a good format, but only available
for Mac and Windows). I don't know anything about the Windows software
available...
Date: 27 Feb 2001 16:38:57
Message: <3A9C1E48.F3403C84@xs4all.nl>
> available...
Of course I exaggerated, the MPEGs aren't
really 4 times as big (more like 3 times).
There was also the point of the strange
formats. MPEG did some weird thing to the
edges which makes the result look even
worse.
I didn't want to post 3 200K AVIs which
looked very acceptable and DivX didn't
help much but this Intel Coded (263 I
believe) shrank the sizes so incredibly
I thought I'd give it a try.
Anyway, I've attached one MPEG.
Remco
Download 'pplane1.mpg' (46 KB)
Date: 27 Feb 2001 17:45:50
Message: <Xns90567D065894tsiivolacchutfi@204.213.191.228>
Remco de Korte <rem### [at] xs4allnl> wrote in <3A9AFF6D.BC7DD671@xs4all.nl>:
Dunno if it is the codec or my computer, but unfortunately I was unable to
view these...
I think that with MegaPOV you could, since all the triangles should have a
normal vector - and therefore you could use the inside texture thingie. I
think. Haven't tried.
Actually, it could possibly be done with meshes even in normal POV-Ray, but
it would have been a bit messy: You can apply textures to individual
triangles, just make a "hollow" paper, where the top and bottom surfaces
meet only at folding points, and are something like 0.000001 apart at
maximum.
Darn I hope I could see this. Before I decided to go the mesh-route I was
considering something similar, along with a plenty of other options. How
did you handle the points where the paper is folded several times over the
same spot?
Yours,
  -- Nikodemus
