POV-Ray : Newsgroups : povray.beta-test : too much flushing / slow pre/post parse Server Time
26 Mar 2026 04:13:12 EDT (-0400)
  too much flushing / slow pre/post parse (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: too much flushing / slow pre/post parse
Date: 25 Apr 2004 05:26:38
Message: <408b844e@news.povray.org>
In article <Xns94D633C1AFF81raf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
<spa### [at] raf256com> wrote:
> From Pov 3.5 (or even 3.1) there still is a delay after and of render.
Well, if the behavior is the same in previous versions, your post is a
feature request...
> It is caused by
> - closing/flushing output file, -f elimitase it
Of course, if you don't output the image to file, the image file does not
have to be written and rendering will be faster.  Obviously, this cannot be
avoided if you want an image written to disk.
> - flushing all streams, -Ga eliminates it partialy
Information output takes time.
> - rendeing of message window slooowly scrolling (in Win32 version), hidding
> messages window helps it.
Maybe you should get a faster graphics card if scrolling is too slow? - On
the other hand, I have yet to see scrolling being slow, so probably your
system is having other problems.  Maybe your graphics card driver is missing
and Windos defaulted to the universal VGA driver?
> Once I turned off everything (all outputs/streams etc) and then one render
> took 0.05 second (it was ofcourse siiiimple image in 50x50 resolution), so
> could accualy watch a little povray animtion in real time :)
> It would be nice to make this behaviour default.
You can easily edit povray.ini if you want such a default.
> I.e make two render buttons - one designed for preview (no streams or
> messages, is there is no errors), and one for normal render (all streams,
> output file).
So POV-Ray is to magically predict there will be no errors or warnings and
disable all output prior to even having parsed the scene?  Sure.
    Thorsten
e-mail: tho### [at] trfde
Date: 25 Apr 2004 07:29:18
Message: <Xns94D689184D2Draf256com@203.29.75.35>
tho### [at] trfde news:408b844e@news.povray.org
>> hidding messages window helps it.
> - On the other hand, I have yet to see scrolling being slow, so
> probably your system is having other problems.  Maybe your graphics
> card driver is missing and Windos defaulted to the universal VGA
> driver?
GeForce 4 Fx :) This is *very* fast card. Ofcourse with newest drivers etc.
But newbies to PovRay cant. Same thing as with Sound settings (greate job
btw).
>> streams, output file).
> and disable all output prior to even having parsed the scene?  Sure.
*TWO* render buttons.
Or even better three,
[Run preview]
[Run Normal]
[Run Finla]]
And in .ini files You could define i.e.
[run_preview]
-a -g -Ga
[run_normal]
[run_final]
+a0.03 +ar2 +am2
Ofcourse this is obvious for You, me, and other povray users.
But software designer realy should think as a normal-peopes, that dont have
a clue what .ini file is, and want to faslty have choose quality/speed,
without reading tons of help. No all pov-users are programmers You know :)
http://www.raf256.com/3d/
Computer Graphics
Date: 25 Apr 2004 07:50:14
Message: <408ba5f6@news.povray.org>
In article <Xns94D689184D2Draf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
> [run_preview]
> -a -g -Ga
> [run_normal]
> [run_final]
> +a0.03 +ar2 +am2
Did you actually think about the consequences of your suggestion?
Essentially when previewing a scene during development of said scene you
could not see any errors.  Nor could new users see it.  POV-Ray would just
stop!
It should be absolutely obvious that neither new users nor any user for that
matter should be offered a user interface that shows no information in the
event of errors or warnings.  If an advanced users really elects to not care
about any errors and warnings it might be acceptable.  However, for a
default configuration to just not show any problems at all is about as wrong
as user interface design can possibly be!
    Thorsten
Date: 25 Apr 2004 08:05:55
Message: <Xns94D68F4D4E276raf256com@203.29.75.35>
tho### [at] trfde news:408ba5f6@news.povray.org
> for that matter should be offered a user interface that shows no
> information in the event of errors or warnings.  If an advanced users
> really elects to not care about any errors and warnings it might be
> acceptable.  However, for a default configuration to just not show any
> problems at all is about as wrong as user interface design can
> possibly be!
Well right. Maybe just remove statistics stream and fie output then (from
preview mode)?
But generaly idea of easy accesible 3 rendre modes (3 buttons, maybe 3
short cuts) is not so bad idea? it is uded in every other rendering
software i.e. moray (wireframe / raytrace / etc)
Computer Graphics
Date: 25 Apr 2004 08:09:07
Message: <Xns94D68FD82F2CAraf256com@203.29.75.35>
spa### [at] raf256com news:Xns94D68F4D4E276raf256com@203.29.75.35
> (from preview mode)?
And disable saving INI to RERUN/ because rotating rerun hisotre needs to
open/read/write/close over 10 files. Some ini option for not writing rerun,
and add this also to preview.
Computer Graphics
Date: 25 Apr 2004 08:55:07
Message: <408bb52b$1@news.povray.org>
In article <Xns94D68F4D4E276raf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
> preview mode)?
You can already disable individual streams.  Please refer to the user manual
for details.
    Thorsten
Date: 25 Apr 2004 08:57:41
Message: <408bb5c5@news.povray.org>
In article <Xns94D68FD82F2CAraf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
Hmm, maybe what you are looking for is a command-line version of POV-Ray?  I
think there are some optimised command-line versions of POV-Ray 3.5 that run
on Windows available.  I suppose others here know the links and can help you
out, if not Google should provide links to them as well.
    Thorsten
Date: 25 Apr 2004 10:30:38
Message: <Xns94D6A7D59F57Draf256com@203.29.75.35>
tho### [at] trfde news:408bb52b$1@news.povray.org
> manual for details.
I know.
I suggest to add predefined .ini and bind it to a key and to button.
alt+1 or button GO(fast) = turned off most streams -f +sp32 +ep4
alt+2 or button GO
alt+3 or button GO(final) = +a0.03 +f
and maybe also
alt+4 .. alt+9 - will fastly select quickres.ini section [fast_4] ..
[fast_9] and render it.
I know it is possible, but new-users might not.
Computer Graphics
Date: 25 Apr 2004 10:35:33
Message: <Xns94D6A8AAE9C8Craf256com@203.29.75.35>
tho### [at] trfde news:408bb5c5@news.povray.org
> POV-Ray?  I think there are some optimised command-line versions of
> POV-Ray 3.5 that run on Windows available.  I suppose others here know
> the links and can help you out, if not Google should provide links to
> them as well.
Thanks, but that was not what I ment, sorry if I was unclear (bad english).
I ment to turn off writting /render/rerun
I disabel writting to /render/rerun (just by renaming this dir ro _retun)
and it gave grate boost in speed of post-render.
The delay between finishing render and possiblitity to contue editing
(beta-4.win32) is now about 0.1 second (ewen with all streams on, comes out
that streams was NOT the problem).
Computer Graphics
Date: 25 Apr 2004 15:14:08
Message: <MPG.1af5bb00bd178f47989a27@news.povray.org>
In article <Xns94D6A7D59F57Draf256com@203.29.75.35>, spa### [at] raf256com
says...
> > manual for details.
> I know.
> alt+2 or button GO
> and maybe also
Wouldn't something like the 'drop-down on a button' things like some
browsers have make more sense. Just click the button for normal behaviour
or the little drop down arrow to get alternative behaviors. That way the
option is there, but you don't need 2-3 extra buttons. And I tend to
agree here. New users won't know how to set these things manually, and in
the case of the re-run issue, you can't apparently even turn that off
anyway, even though Rafal says it can drastically speed things up for
those of us that *never* or rarely use it in the first place. Renaming
the directory so that it simply fails in all cases isn't much of an
option, since when you do need it, you have to rename the directory again
to reenable it. :(
void main () {
    call functional_code()
  else
    call crash_windows();
