On 2017-01-11 01:59 AM (-4), clipka wrote:
> POV-Ray 3.7.1 has now officially entered public beta testing phase.
> Source code and Windows binaries are available on GitHub:
> https://github.com/POV-Ray/povray/releases/tag/v3.7.1-beta.2
> (beta.1 was an internal release only.)
> The beta version is designed to install in its own dedicated directory,
> and live happily alongside an existing 3.7 installation.
> Happy testing!
The parser chokes on .ini files that are not in the current directory,
but are in the library path.
I wish I could say in what manner it choked, but the message was that
infuriatingly unspecific:
Problem with option setting
[Command line is echoed here.]
Failed to parse command-line option
Once again, if the parser had given a more helpful message, I could have
saved nearly an hour and a half figuring out what went wrong. I've been
complaining about this for five or six years now. PLEASE FIX THIS!
On 2017-01-11 11:37 AM (-4), clipka wrote:
> If that fails, please provide us with the corresponding scene file, so
> we can try to reproduce the problem on a Windows version, where we have
> more debugging aids at our disposal.
The very first two scenes I tried failed in the same manner that
LanuHum's scene did. (They also failed with alpha.8927145.) Since
then, all of the scenes I've tried have rendered successfully.
Unfortunately, both of those first two scenes use an include file that
is more than 1 megabyte.
> Those addresses are of no help to us whatsoever. You'd have to compile
> POV-Ray in a manner that the backtrace spits out function names and/or
> file names and line numbers.
Oh, I forgot to add: -version reports the compiler settings as:
Compilation settings:
Build architecture: x86_64-suse-linux-gnu
Built/Optimized for: x86_64-suse-linux-gnu (using -march=native)
Compiler vendor: gnu
Compiler version: g++ 4.8
Compiler flags: -pipe -Wno-multichar -Wno-write-strings
-fno-enforce-eh-specs -Wno-non-template-friend -s -O3 -ffast-math
-march=native -pthread
I don't know how to change the build scripts to include debugging
information.
Those first two scenes did not actually use the data in the 1 megabyte
file, so I dropped it, concatenated everything else into a single file,
then took a hatchet to the file.
Guess what? The one thing those two scenes had in common that all my
other tests did not was Greek text.
This appears to be the same charset utf8 bug that ThH uncovered. And
since LanuHum probably uses a lot of Cyrillic text, I'm guessing that
his is the same problem.
Correction: only one of them didn't use the 1 MB file. I'm not thinking
straight today.
Am 02.02.2017 um 03:26 schrieb Cousin Ricky:
Sounds totally plausible.
If that is the case, then the next beta should fix it.
Am 01.02.2017 um 23:30 schrieb Cousin Ricky:
> On 2017-01-11 01:36 PM (-4), clipka wrote:
>> It would be interesting to know whether the latest tagged alpha
>> (v3.7.1-alpha.8927145) works better than the beta. Since we've made only
>> very few changes to the source code since then, that would give us a
>> clear hint where to search for things that might be going wrong.
> Alpha.8927145 crashes. Alpha.8917471 runs splendidly.
That fits well with the theory that it's the "utf8" bug you're experiencing.
Am 02.02.2017 um 00:38 schrieb Cousin Ricky:
This seems to be one of various shortcomings of my arch nemesis, the
"VFE" layer, which appears to provide no way whatsoever to pass on any
details why it rejects the command-line.
I've been gaining ground in my uphill battle against the VFE (my intent
being to get rid of it entirely), but it takes time, and this particular
corner of the battlefield isn't one of the strategic positions I'm
focusing on. Once I manage to get close enough to the VFE's heart to
drive a stake through it, I expect this issue to become quite easy to
fix as well.
> [Clipka wrote...]
> [Clipka wrote...]
> [Cousin Ricky wrote...]
> [Clipka wrote...]
Sorry to be late with this, but...
I can confirm this charset utf8 crash bug, in two versions of POV-Ray (on
Windows 7 64-bit):
Alpha.8927145
and
3.7.1-beta 2
Does NOT crash when using the 'original' v3.7.0 version.
(I used the appropriate pvengine64 versions for each.)
The scene that I did the tests with is mentioned here (I simply commented-out
the scene's 'charset utf8' entry in global_settings)...
http://news.povray.org/povray.beta-test.binaries/thread/%3Cweb.5897b07b6a1a359883fb31c0%40news.povray.org%3E/
and
http://news.povray.org/povray.text.scene-files/thread/%3Cweb.4a7c8c12a399eaf3df22a6900%40news.povray.org%3E/?ttop=41306
4&toff=50
> Windows 7 64-bit):
> Alpha.8927145
> and
> 3.7.1-beta 2
> and
> 4&toff=50
The latest master branch does not crash. I look forward to beta 3.
