POV-Ray : Newsgroups : povray.beta-test : sphere sweep bounding boxes calculated incorrectly Server Time
4 Jul 2026 01:50:22 EDT (-0400)
  sphere sweep bounding boxes calculated incorrectly (Message 11 to 15 of 15)
Subject: Re: sphere sweep bounding boxes calculated incorrectly
Date: 13 Jan 2002 17:22:56
Message: <3c4208c0$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote...
> Confirmation?
Yes.
This is the same bug that can cause radiosity to be calculated incorrectly
for sphere sweeps!  Note that setting Bounding_Threshold to zero in the INI
file (or command line) will "fix" the problem.
-Nathan
Date: 13 Jan 2002 17:40:19
Message: <3c420cd3@news.povray.org>
In article <3c4208c0$1@news.povray.org> , "Nathan Kopp" <nat### [at] koppcom>
Ah, good to know that my change in beta 10 then corrected that bug.
However, why does radioity depend on a tight bounding box...?
    Thorsten
e-mail: tho### [at] trfde
Date: 13 Jan 2002 23:25:07
Message: <3c425da3$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote...
incorrectly
INI
You know, I don't really know.  That radiosity code is still a bit of a
mystery in some places.  All I know is that the bounding problems were
causing problems with radiosity, and fixing the bounding problems (by using
Bounding_Threshold=0) fixed the radiosity problems in my tests.
I just tested the latest version and it seems that the radiosity problem is
also now solved for sphere sweeps.
-Nathan
Date: 14 Jan 2002 00:56:11
Message: <+cfY4GA2DnQ8EweH@econym.demon.co.uk>
>> Confirmation?
>Yes.
On my machine, setting bounding_threshold to zero causes scenes that
contain no objects to crash. [I wonder if this is the missing ingredient
which causes some people to have all their objectless scenes crash -
perhaps they have bounding_threshold=0 in their ini file for some
reason.]
It also doesn't "fix" the problem that the min_extent (or max_extent) of
the sphere sweep always includes <0,0,0>.
Mike Williams
Gentleman of Leisure
Date: 14 Jan 2002 07:21:05
Message: <3c42cd31$1@news.povray.org>
In article <+cfY### [at] econymdemoncouk> , Mike Williams
Yes, that is to be expected because the bounding box is an object property,
and bounding only makes additional use of this property, so it is always
available, regardless of the use of bounding boxes for acceleration.
    Thorsten
