POV-Ray : Newsgroups : povray.advanced-users : file reading mistake Server Time
18 Mar 2026 22:23:07 EDT (-0400)
  file reading mistake (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: file reading mistake
Date: 29 Jan 2006 06:03:55
Message: <43dca11b$1@news.povray.org>
> What the hell does POV make of that data when it reads it?
It reads comma-separated values. Strings have to be in quotation marks,
vectors use the < and >, and floats are just plain numbers. I'm not sure
about comments starting with double-slash (//), but I think they are
ignored.
POV-Ray's reading capabilities aren't meant to read "ordinary" files. Just
stuff like this.
"string", <1,1,1>, 321.514, "another_string", 4.2333, <3,6>
Tim
aka "Tim Nikias v2.0"
Date: 29 Jan 2006 06:44:07
Message: <43dcaa87$1@news.povray.org>
What he said.
It allows you to (for example) do a bunch of calculations, save the
result to a file, and load it back in during the next frame of the
animation.
POV-Ray doesn't have the ability to read arbitrary files. Nor to write
them, really. (It can write arbitrary text files. But it can't read them
back.)
If you wanted, I suppose you could write some kind of preprocessor which
sticks quote marks round everything first...
Date: 29 Jan 2006 10:10:24
Message: <43dcdae0$1@news.povray.org>
Zarkoff nous apporta ses lumieres en ce 29/01/2006 05:51:
> // File generated by SpilinEditor v1.2
> // POV-Ray v3.0 syntax
> #declare testSpln =
> lathe{
>  cubic_spline
>  14,
>  <3.630000,6.150000>,
>  <2.590000,5.280000>,
>  <1.880000,3.690000>,
>  <2.400000,1.720000>,
>  <3.370000,1.050000>,
>  <4.850000,0.690000>,
>  <6.370000,0.880000>,
>  <7.490001,1.920000>,
>  <7.410001,2.700000>,
>  <6.860000,3.320000>,
>  <6.170000,3.080000>,
>  <5.330000,3.680000>,
>  <5.120000,4.530000>,
>  <5.620000,4.950000>
> // end of file
If that's the full content of the file, just #include it.
The lines starting by "//" are comments and will be ignored.
The rest is correct syntax for a lathe object. If the identifier name don't suit you,
just change it
  in your editor.
Zoroastrianism: Shit happens half on the time.
Date: 29 Jan 2006 12:10:01
Message: <web.43dcf5effd77404147a74af70@news.povray.org>
> stuff like this.
Why did they limit it? That means I have to go into all the Spline Editor
files I'm using and chop all that unreadable data off myself -- or write a
C program to do it... Which means I'd have been better off using an old DOS
type C program.
If they would have done what seems the simpler programming thing and let the
POV user format how data is read then POV-ray would soon be reading files
from Maya, Lightwave and 3D-max.
Why did they rob us of that power?
If you're going to have file reading - why not go all the way... fseek, user
formatting, etc..
fseek and file positioning and char by char reading would make the whole
file reading and writing operations more powerful.
Date: 29 Jan 2006 12:31:48
Message: <43dcfc04$1@news.povray.org>
I agree with you.
However, they did not. The end.
As I said in my other post, it's really ment for saving variables
between frames of an animation so you can load them back in the next frame.
Notice also that POV-Ray can *write* arbitrary text into an output file.
Just not *read* it. (Odd, but true.)
Also note the other reply; you can read this particular file just with
#include, since it's already in POV-Ray SDL format...
Date: 29 Jan 2006 15:12:04
Message: <43dd2194$1@news.povray.org>
DOS
> type C program.
Design decision? After all, POV-Ray is supposed to be a script-based
raytracer. It does come with this nice and handy SDL, but it's a bonus,
POV-Ray, after all, is just a raytracer. You're not supposed to be
programming with it, you're supposed to describe a scene and let it
raytrace.
Tim
Date: 23 Jun 2006 13:25:01
Message: <web.449c233dfd77404145bc30e10@news.povray.org>
I have another strange "read" issue. Indeed I only want to transfer
variables from one frame to another, but A LOT of them. My file goes like
this:
-0.00164469
-0.0512107
0
-0.612596
-0.609269
-0.605894
-0.602472
When I read that in, by using a simple
#read (DATA, newVar)
the line with the "0" is simply ignored - instead of the 0 being saved in
"newVar". I have to convert the lines with "0" to "-0.0" ("0.0" isn't
enough) to prevent that. Is this a feature or...?
Viktor.
Date: 23 Jun 2006 13:54:10
Message: <449c2ac2@news.povray.org>
Try separating the values with commas.
Date: 24 Jun 2006 00:55:00
Message: <web.449cc533fd774041335d9630@news.povray.org>
"Viktor" <vik### [at] spamfencenet> wrote:
> -0.00164469
> -0.0512107
> 0
> -0.612596
> -0.609269
> -0.605894
> -0.602472
It is a RTFM!
Date: 24 Jun 2006 12:44:02
Message: <449d6bd2$1@news.povray.org>
Viktor nous apporta ses lumieres en ce 23/06/2006 13:22:
> this:
> -0.00164469
> -0.0512107
> 0
> -0.612596
> -0.609269
> -0.605894
> -0.602472
> Regards,
> Viktor.
It reads the data as: -0.00164469, -0.05121070 (note the extra zero), -0.612596,
-0.609269,
-0.605894, -0.602472
The lone 0 is treated as the last digit of the preceding value. Another integer would
have been
treated the same way, but would have been easier to spot as it would have altered the
preceding value.
Put a comma after each value but the last.
A short cut is the longest distance between two points.
