POV-Ray : Newsgroups : povray.advanced-users : Finding an object=B4s location Server Time
11 Apr 2026 01:55:51 EDT (-0400)
  Finding an object=B4s location (Message 1 to 8 of 8)
Subject: Finding an object=B4s location
Date: 17 Nov 2003 20:10:01
Message: <web.3fb9705e4b0664231e2d84430@news.povray.org>
Hi, Boys,
I have this problem for an IRTC entry, but it should be interesting in
general.
I have a scene with, say, a dozen of objects. Every object is built at
<0,0,0> and then translated + rotated the same way: every object gets the
translations+rotations from all objects before plus an additional
translate+rotate.
Is there any way to ask POV-Ray where exactly the last object is located? I
can find its location of course drawing triangles on paper ;-) but I am
looking for some "magic" feature that writes the location directly to the
message window or something else.
TIA for any hints
Rm
Subject: Re: Finding an object=B4s location
Date: 17 Nov 2003 21:08:38
Message: <3fb97f26$1@news.povray.org>
I
Instead of transforming the object directly, do this:
#declare trans = transformation {
rotate...
scale...
translate...
then, use transformation{ trans } to transform the object, and you can also
use the vtransform() function with the same transformation and find the
place where a certain point is transformed to.
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: Finding an object=3DB4s location
Date: 17 Nov 2003 22:45:01
Message: <web.3fb9948fad415b1f1e2d84430@news.povray.org>
I thought of vtransform{} and also I thought of min_extent/max_extent as the
doc says in both cases it will return values, but I cannot figure out to
(means, I have no clue how to get it to work correctly).
Do You know of any scene file out there where I can see the code "in
wildlife"?
Thanks
Rm
Date: 18 Nov 2003 04:15:54
Message: <3fb9e34a$1@news.povray.org>
news:web.3fb9705e4b0664231e2d84430@news.povray.org...
The only way I know is to calculate the position using vector functions and
then using the value for screen output.
For example :
#declare
MyPos=vaxis_rotate(vaxis_rotate(<10,30,-20>,y,50)+<50,-10,12>,z,30);
#debug
concat(str(Mypos.x,0,3),",",str(Mypos.y,0,3),",",str(Mypos.z,0,3),"\n")
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 18 Nov 2003 10:10:32
Message: <cjameshuff-71CABF.10071718112003@netplex.aussie.org>
In article <web.3fb9705e4b0664231e2d84430@news.povray.org>,
What's the location of an object? There is no such thing.
The min_extent() function returns the lower-left-front corner of the
bounding box of the object, the max_extent() function returns the
upper-right-back corner. The documentation explains this fully, I
suggest you read it again. The vtransform() macro (parentheses, not
curly brackets...it's a macro) transforms a point with a given
transformation. Pick the point you want to treat as the "center" of the
object and transform it with the same transformation you used on the
object.
http://tag.povray.org/
Date: 19 Nov 2003 00:23:04
Message: <3fbafe38@news.povray.org>
Gilles Tran wrote:
> #debug
Yepp. Can't test it right now, (the Windows machine crashed last night) but
this seems to be exactly what I'm looking for.
Merci
Rm
Date: 19 Nov 2003 00:37:15
Message: <3fbb018b@news.povray.org>
Hmmmmmm ....
HmHmmHmmm ... If You wanted to name me whatever You succeeded. You also
managed to quote the docs correctly. How about answering the question next
time?
Rm
Date: 21 Nov 2003 14:29:56
Message: <cjameshuff-4B66F6.14243821112003@netplex.aussie.org>
In article <3fbb018b@news.povray.org>,
Er, thank you?
> You also managed to quote the docs correctly. How about answering the
> question next time?
I did. Your exact question has no answer, because the question itself is
nonsense, but I gave you two ways of accomplishing your apparent goal.
To repeat myself: there is no magic way of getting the object's
"location", because in general, there is no such thing. What's the
location of a person? Their center of mass? The point in between the
centers of area of their feet? Or even simpler: what's the location of a
triangle? A triangle has at least twenty known "centers", starting with
the incenter, centroid, circumcenter, and orthocenter, and your desired
"location" may be none of these.
(http://mathworld.wolfram.com/Center.html,
http://mathworld.wolfram.com/TriangleCenter.html)
Instead of some mysterious location value, you can get an approximation
of the extents of the object along each axis, or pick a point to call
the location of the object and transform that point with the same
transform you applied to the object.
