POV-Ray : Newsgroups : povray.advanced-users : Radiosity problem when using conventional lightning Server Time
11 Apr 2026 05:15:08 EDT (-0400)
  Radiosity problem when using conventional lightning (Message 1 to 6 of 6)
Subject: Radiosity problem when using conventional lightning
Date: 16 Apr 2003 08:30:07
Message: <web.3e9d4bd669337fd4bef0bd7d0@news.povray.org>
It is necessary to set light source object ambient to high to get realistic
highlights to shiny surfaces. Problem is that I can't remove ambient object
from radiosity calculations. This causes ugly errors in lightning because
there is a ambient light source in scene. I tried to use "no_image" object
modifier and put visible light source under light source "looks_like"
statement.
How can I remove light_source object from radiosity calculations? Is there
any way cheat Pov-Ray radiosity algorithm? Like putting some invisible
object around ligh source object so radiosity algorithm take samples from
object surrounding light_source?
Matti
Subject: Re: Radiosity problem when using conventional lightning
Date: 16 Apr 2003 08:33:15
Message: <20030416143318.13b11cd2.jaimevives@ignorancia.org>
On Wed, 16 Apr 2003 08:25:58 EDT
> there any way cheat Pov-Ray radiosity algorithm? Like putting some
> invisible object around ligh source object so radiosity algorithm take
> samples from object surrounding light_source?
  I use a transparent object with a very bright emission media, but it
only works if you keep "media off" on radiosity block (I never use media
interacting with radiosity).
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 16 Apr 2003 09:31:53
Message: <3e9d5b48@news.povray.org>
  I don't really understand why it's more preferable to use a bright
object as a light source for radiosity than using a light_source.
  From my experience, using a light_source gives better lighting faster
(no need for extreme radiosity settings).
Date: 16 Apr 2003 10:05:05
Message: <3e9d6311@news.povray.org>
The problem (as far as i understand it) is that he has a classical
light_source, but uses an object with high ambient, to 'materialize' the
light, and this high ambient is causing troubles with radiosity..
Maybe try a 2 pass rendering, first pass to compute the radiosity solution
in a scene without your high ambient objects, radiosity saved in a file.
Then second pass with always sample off, load radiosity from file, and scene
with your bright objects
M
Date: 16 Apr 2003 10:26:53
Message: <3e9d682d@news.povray.org>
or look at max_sample in the documentation
M
Date: 1 Jun 2003 15:39:08
Message: <1doan9c7mvfze.8cvqfi6encyn.dlg@40tude.net>
> statement.
> Matti
I understand your problem and that is EXACTLY why I made a patch to fix it.
My patch adds a no_radiosity keyword that works like no_image or no_shadow
only it removes the object from radiosity calculations even when calculated
through mirrors. I hate to keep people waiting so long but progress has
been standing still for the past several months. I've got a lot of fixing
to do and not much time to do it in.
Anyway, back on track, if you give your bright ambient object no_shadow and
no_image, it will stop most radiosity calculations from interfering with
your lighting. If you want to see the object itself, look at the entire
scene through a mirror (I usually coupled the ambient object trick with my
poor mirrorflare include).
light_source#macro G(E)sphere{z+E*y*5e-3.04rotate-z*E*6pigment{rgbt#end{
20*y-10#local n=162;1}#while(n)#local n=n-.3;G(n)x}}G(-n).7}}#end//GregE
