POV-Ray : Newsgroups : povray.advanced-users : Radiosity flouroescent lighting troubles Server Time
22 Mar 2026 02:50:38 EDT (-0400)
  Radiosity flouroescent lighting troubles (Message 31 to 40 of 47)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: Radiosity flouroescent lighting troubles
Date: 29 Nov 2002 10:01:17
Message: <580fuu4eg5rnsk3fvr1aotj5t5pqh4ufa6@4ax.com>
On Fri, 29 Nov 2002 15:01:24 +0100, Mark Weyer
<wey### [at] fregemathematikuni-freiburgde> wrote:
>Why is the lookup array fixed? It might be calculated at program start,
>allowing for varying length.
Probably for the same reason most other jitters use fixed arrays - for
true platform independence (at least that's how I read it).
Peter Popov ICQ : 15002700
Date: 29 Nov 2002 10:16:49
Message: <3de784e1@news.povray.org>
Hi Christoph,
The cos-theta distribution on the hemisphere is given by creating an
even distribution on a unit circle and then projecting up or down to a
unit hemisphere.
You can see this by taking a copy of the radiosity sample array, editing
it to pov syntax and including it in a small scene which puts a sphere
at the <X,Y,0> points. If you do an animation which adds 1 or a few
sample positions each frame you can see how the distribution builds up.
Mike Andrews.
Christoph Hormann wrote:
> Quoting from the source:
> A bit of theory: The goal is to create a set of "random" direction rays
> so that the probability of close-to-normal versus close-to-tangent rolls
> off in a cos-theta curve, where theta is the deviation from normal.
> That is, lots of rays close to normal, and very few close to tangent.
> You also want to have all of the rays be evenly spread, no matter how
> many you want to use.  The lookup array has an array of points carefully
> chosen to meet all of these criteria.
> The problem is similar to the classical "How can I arrange N points evenly
> on a sphere" problem like described in:
> http://www.ogre.nu/sphere.htm
> Just that it is hemispherical, not really uniform and it not only has to
> be good for N points but also for N-X points (X = 1..N-1)
> Christoph
Date: 29 Nov 2002 10:23:51
Message: <3DE78686.8FFBA5EB@gmx.de>
Mark Weyer wrote:
> How was the built-in array created? (I would like to know,
> which quality I have to beat). In fact you already mentioned,
> that you want the same quality contraints for initial segments
> of the array, so my earlier suggestion might already do the trick.
You don't need to know how the original distribution was created to
compare quality.  If you follow the link i posted you will find several
measurements of the quality of distributions.  Apart from the maximum
uniformity the distribution should not be regular to be well suited for
radiosity sampling.
Last updated 15 Nov. 2002 _____./\/^>_*_<^\/\.______
Date: 29 Nov 2002 10:29:33
Message: <3DE787DA.DD661D55@gmx.de>
Michael Andrews wrote:
> Hi Christoph,
> unit hemisphere.
It is fairly possible that this is the method how the directions array was
originally created but there is no way how to prove this.
Another method (which probably produces higher quality for a fixed number
of rays if done well) would be a repulsion algorithm with a non uniform
force field (i.e. higher repulsive forces between the points at low angle)
Date: 29 Nov 2002 10:39:43
Message: <3DE78C86.171B378C@frege.mathematik.uni-freiburg.de>
> If you have a light source almost tangential to the surface it doesn't
> illuminate much and one almost normal to the surface gives high
> illumination. So, if all the samples are weighted the same you want most
> samples from the normal direction and few from tangential to give the
> best estimate.
Ok, that explains it. As a purist I was assuming you take an
even distribution and weight the samples with cos. But it would
be hard to sell that to running-time-theists...
> I suppose it could be, and I've thought about doing this. However you
> would have to calculate an array for each level of radiosity recursion
> because the code reduces the number of samples taken at each subsequent
> recursion level. And the results wouldn't be very different anyway.
The way Christoph was putting it, you reuse an initial segment of the
array. My current approach would be to build in a precomputed array
for everyday use with the possibility to replace it by something larger.
  Mark
Date: 29 Nov 2002 10:44:16
Message: <3DE78D99.5CBE035@frege.mathematik.uni-freiburg.de>
> > unit hemisphere.
I do not see why the quality is better than using repulsion
inside the unit circle with a uniform force field before projecting.
  Mark
Date: 29 Nov 2002 11:11:12
Message: <3DE791A0.B5682EBB@gmx.de>
To me it seems fairly obvious that projecting a disc on a hemisphere does
not maintain the distance relations and therefore reduces the uniformity
of a distribution.
To be precise, the points at the rim of the hemisphere will be quite dense
in direction of the circumference but will be moved apart in theta
direction.
Date: 29 Nov 2002 13:20:04
Message: <3de7afd4@news.povray.org>
> of a distribution.
The point is that you do not want a uniform distribution on the
hemisphere ...
> direction.
Ahh! If you used a unit circle to do the repulsion thing then you are
quite right - you do not get an even distribution at the edge: all the
outermost points would be pressed against the rim.
This is why I used a 2 radius circle when I was doing the Delaunay
triangulation, and adding samples until I had enough in the unit circle.
That way you get an even distribution right across the unit circle -
right to the rim of the hemisphere.
You could do the same with a repulsion algorithm - fill a circle of
greater than 1 radius and keep adding a sample and repelling to
completion untill you have the right number of samples within the 1 unit
circle.
> Christoph
Mike Andrews.
Date: 29 Nov 2002 13:47:50
Message: <3DE7B656.7B53B80E@gmx.de>
The radius of the circle does not matter, once you project it on a
hemisphere you get an anisotropic distribution (meaning the density of the
points depends on the direction like explained in my last post).  But feel
free to try it out, i'm sure if you check the quality of the results you
will see it.
Date: 29 Nov 2002 15:33:14
Message: <3de7cf0a$1@news.povray.org>
> will see it.
This anisotropy is inevitable - the density of the samples is decreasing
  with theta but constant in phi. If you plot the radiosity sample
positions you can see this quite clearly with the official samples.
> Christoph
Mike Andrews.
