POV-Ray : Newsgroups : povray.advanced-users : Limits of isosurface object Server Time
17 May 2025 09:35:40 EDT (-0400)
  Limits of isosurface object (Message 1 to 7 of 7)
Subject: Limits of isosurface object
Date: 30 Aug 2002 11:55:04
Message: <web.3d6f93d0dbb361415e7f0160@news.povray.org>
What are the hard limits on the isosurface object?
How does the code scales wrt expression complexity?
what is the hard limit on the function in terms of operations and what are
practical limits?
Is it feasible to have a function of the form:
s(x) = p(x) + SUM{lambda * phi(|x - xi|), i=0..N}
where x and xi are vectors, with N very large (circa 100000)?
Alex
Subject: Re: Limits of isosurface object
Date: 30 Aug 2002 12:08:47
Message: <3D6F988F.8630EEA2@gmx.de>
> practical limits?
In short: RTFM.
Practical limits: Your computer's memory and your patience.
Date: 30 Aug 2002 12:26:52
Message: <j17vmuguoevjb9kh2ervlm0u2se9eqkb9u@4ax.com>
On Fri, 30 Aug 2002 18:08:47 +0200, Christoph Hormann <chr### [at] gmxde>
And your computer's cooler ;-)
ABX
Date: 30 Aug 2002 12:30:28
Message: <chrishuff-59D05D.12295230082002@netplex.aussie.org>
In article <web.3d6f93d0dbb361415e7f0160@news.povray.org>,
What hard limits do you mean? Isosurface limitations are mainly the same
as for other objects, though they may be more vulernable to precision
problems.
> practical limits?
The documentation lists all these limits. Did you even bother to try
looking it up?
Functions can't handle vectors. You might be able to do this at least
partially with functions, it depends on how it is done and what you are
trying to accomplish.
http://tag.povray.org/
Date: 30 Aug 2002 15:13:09
Message: <3d6fc3c4@news.povray.org>
  Actually there was a limit on how many operands you can have in a function.
I don't remember now how much it was.
  Also the amount of funtions in total was limited.
Date: 30 Aug 2002 15:30:36
Message: <Q+zvCBAlc8b9EwUg@econym.demon.co.uk>
But that's only a soft limit. You could get around it by splitting your
function into several bits and pre-declaring them, then declaring your
main function in terms of those bits. And if that's not enough you can
split the bits into smaller bits.
Mike Williams
Gentleman of Leisure
Date: 31 Aug 2002 03:25:03
Message: <web.3d706effb8df080615e7f0160@news.povray.org>
Christopher James Huff wrote:
>In article <web.3d6f93d0dbb361415e7f0160[at]news.povray.org>,
>problems.
>> practical limits?
>looking it up?
>Christopher James Huff <cja### [at] earthlinknet>
>http://home.earthlink.net/~cjameshuff/
>POV-Ray TAG: chr### [at] tagpovrayorg
My bad, I was on a karma-burning streak yesterday.
Apologies to all involved.
I did bother to look it up, after you pointed your finger to it.
That answered my ques nicely.
Alex
