POV-Ray : Newsgroups : povray.advanced-users : Truck and trailer Server Time
17 May 2025 09:35:40 EDT (-0400)
  Truck and trailer (Message 1 to 10 of 35)
Subject: Truck and trailer
Date: 27 Aug 2002 06:45:11
Message: <web.3d6b57f7612a00a4bbe30ae0@news.povray.org>
Hello all,
How does a trailer follow the car/truck that is pulling it through bends, is
there some magic formula for it? All I can figure out is that the angle
between the two is related to the length of the trailer but beyond that I'm
a bit lost.
Is it clear what I'm asking?
TIA,
Subject: Re: Truck and trailer
Date: 27 Aug 2002 07:29:58
Message: <3d6b62b6@news.povray.org>
"Thomas" <tho### [at] gmxnet> wrote in message
news:web.3d6b57f7612a00a4bbe30ae0@news.povray.org...
> Hello all,
    The trailer is physically attached to the car/truck.
> is there some magic formula for it?
    No. It's all down to the physical connection between the two, no 'magic'
is
required. In fact you do know magic doesn't actually exist don't you ?
(sorry, couldn't resist...)
Pandora/Scott Hill/[::O:M:C::]Scorpion
Software Engineer.
http://www.pandora-software.com
Date: 27 Aug 2002 07:40:05
Message: <web.3d6b64e6a31ba4aabbe30ae0@news.povray.org>
>news:web.3d6b57f7612a00a4bbe30ae0[at]news.povray.org...
>> Hello all,
I know that ;)
What I meant is how does the angle between the two changes when the
combination goes through a corner, I would like to animate this. But at the
moment the trailer moves side ways, which doesn't look particular
realistic.
>is
Really???? ;)
Date: 27 Aug 2002 08:55:12
Message: <3D6B76AD.54ABCE85@gmx.de>
> realistic.
If you don't want to do an accurate physical simulation you can start with
some basic rules (for a 2 wheel trailer):
- the wheels of the trailer have a fixed distance to one another.
- the wheels of the trailer have a fixed distance to the link.
- the wheels can only move on the ground in their current direction.
- the wheels' directions are always orthogonal to the line between them.
So all you have to do is take care about these three rules being obeyed
while moving the whole system.  I suppose you have already modelled the
movement of the pulling vehicle so all you have to do is taking the
position of the car-trailer link and applying these rules in many small
steps along the movement path.  And if it doesn't look all right just use
smaller steps.  ;-)
Date: 27 Aug 2002 09:16:35
Message: <3d6b7bb3$1@news.povray.org>
is
I'm
> a bit lost.
Yes. I don't know the solution though.
The hitch point should shift based on the change of direction of the pulling
vehicle's front wheels while the rear wheel axle center acts as a pivot
point, maybe. I think you'd use the angle from along centerline of front to
rear wheels and match that for the trailer hitch to its wheels as though the
hitch were a front wheel.
Date: 27 Aug 2002 09:20:03
Message: <web.3d6b7b4ea31ba4aabbe30ae0@news.povray.org>
Hmmmm this might be usefull, but I was looking for something more physical
correct.
Just re-reading your four lines there seems to suggest that the trailer can
not make a curve at all since they only can move in there current
direction. Or is that just me mis reading it.
Date: 27 Aug 2002 09:47:21
Message: <3D6B82E9.A975ABC3@gmx.de>
> correct.
The limited physical correctness of this approach is just in terms of
dynamics.  Taking this into account would complicate the problem quite a
lot.
The emphasis is on *current* direction.  You will probably have to weaken
this requirement a bit (i. e. not use it as a strict rule) to make sure
the distance between the wheels stays the same.
Date: 27 Aug 2002 10:02:56
Message: <3D6B868F.D45FB604@gmx.de>
BTW, you can also think of it a different way: The two wheels and their
axis always move on a circle with it's center somewhere on the axis.
Date: 27 Aug 2002 11:50:10
Message: <web.3d6b9ebba31ba4aabbe30ae0@news.povray.org>
That's what someone here at work suggested as well, but the truck is moving
along a spline and I don't think that it is easy to determine the radius of
the spline at any given point.
Date: 27 Aug 2002 12:05:49
Message: <3D6BA35D.797F0EFE@gmx.de>
That's not the point, the trailer won't follow the same path as the truck
anyway, it was just meant to give an idea how things are supposed to work.
BTW, taking a piece of paper and drawing the trailer and it's movement
will be quite helpful for finding a good method calculating it's movement.
