POV-Ray : Newsgroups : povray.advanced-users : format of hf_gray_16 .bmp files? Server Time
7 Apr 2026 19:24:44 EDT (-0400)
  format of hf_gray_16 .bmp files? (Message 11 to 20 of 27)
<<< Previous 10 Messages Goto Latest 10 Messages Next 7 Messages >>>
Subject: Re: format of hf_gray_16 .bmp files?
Date: 7 Jul 2005 15:01:10
Message: <VBi2$BA5UWzCFwJs@econym.demon.co.uk>
Wasn't it Christoph Hormann who wrote:
>Mike Williams wrote:
>> When I use POVRay to generate a hf_gray_16 TGA file, it works as a
>> height_field.
>> When I do exactly the same thing with a PPM file generated with
>> hf_gray_16 and +fp. I get an error "Parse Error: File is not in PPM
>> format (type 53)" when I try to use it as a height_field. (POVRay 3.6
>> Windows 98se).
>As said with hf_gray_16 POV-Ray generates PGM files - you have to
>specify them as 'pgm' in the heightfield statement.
Wow, how confusing. You're right and the documentation is wrong.
Mike Williams
Gentleman of Leisure
Date: 7 Jul 2005 15:25:01
Message: <dajvfd$dko$1@chho.imagico.de>
What exactly do you think is wrong in the docs?
Of course the documentation of hf_gray_16 should be more elaborate -
important information is missing but i am not aware of anything being wrong.
http://www.tu-bs.de/~y0013390/ (Last updated 01 Jul. 2005)
Date: 7 Jul 2005 15:35:02
Message: <dajvth$dot$1@chho.imagico.de>
Darren New wrote:
> Oh, you mean OS/2 took a Windows format and modified it, but called it
> the same thing, and screwed things up? OK. ;-)
I am sure MS would describe things like this.
> Seriously, they're *all* bitmap formats. I figured you meant the
> microsoft bitmap format. Typing "OS/2 bitmap storage" into google and
> hitting "I'm feeling lucky" gets you that bitmap format.
No, but this isn't really the topic - i just wanted to point out that
there is nothing even approximately as well defined as the PPM/PGM specs
for BMP.
Date: 7 Jul 2005 15:42:26
Message: <42cd85a2$1@news.povray.org>
 > for BMP.
OK. I'd disagree, given the resources I pointed you to and the number of
people who have written to the specs. And in spite of the specs being
well-defined for PPM/PGM, it's not the case that everyone importing
those formats follows the specs either, including POV-Ray.
     The samba was clearly inspired
     by the margarita.
Date: 7 Jul 2005 15:49:36
Message: <ZPlVMAAlYYzCFwo5@econym.demon.co.uk>
It says that you can use a PPM file as a 16-bit height field, but you
have to use a PGM file (and the syntax is "height_field pgm filename").
It says that +fp outputs a PPM file, but if hf_gray_16 is active the
output is a PGM file with an incorrect extension.
I don't think that there's any way that someone could guess the correct
way to use PGM hf_gray_16 files by reading the documentation.
Mike Williams
Date: 7 Jul 2005 15:55:02
Message: <dak17s$dvs$1@chho.imagico.de>
In what way does POV-Ray's reading of PPM/PGM not follow the specs?
Date: 7 Jul 2005 16:20:01
Message: <dak2g9$e9p$1@chho.imagico.de>
You can use a PPM file in a height_field,
height_field {
   ppm "test.ppm"
works for any valid PPM - of course not for a PGM.
That's right.
What's unclear about the use of PGMs? - you can use them in
heightfields, image maps and elsewhere just like any other image file
format supported.
Date: 7 Jul 2005 19:35:42
Message: <psnpkEAvpbzCFw87@econym.demon.co.uk>
>height_field {
>   ppm "test.ppm"
Doesn't that only work for 8-bit PPM files, whereas the documentation
states that it works for 16-bit PPMs.
Mike Williams
Date: 7 Jul 2005 21:01:14
Message: <crjrc1duj4ahig659akln9iqrdmf83fbg5@4ax.com>
I've looked into a .tga height field file. It looks like only the red and green pixel
components are
used. The blue and alpha components are always 0. So, I guess that I can get a 16 bit
hf_gray_16
file if I set the red and green bytes between 0 and 0xffff. If so, which is the most
significant
byte?
Ralph
Date: 7 Jul 2005 21:14:30
Message: <42cdd376$1@news.povray.org>
In some places it required either one space or one newline in the header
where the spec specified "whitespace". My code was doing something like
print "P5 $width $height $depth" and POV-Ray was looking for a newline
after the P5 or some such. I don't remember the exact details.
     by the margarita.
