POV-Ray : Newsgroups : povray.advanced-users : Fishtail math ><}}}*> Server Time
14 Mar 2026 02:02:38 EDT (-0400)
  Fishtail math ><}}}*> (Message 11 to 20 of 26)
<<< Previous 10 Messages Goto Latest 10 Messages Next 6 Messages >>>
Subject: Re: Fishtail math ><}}}*>
Date: 19 Nov 1999 17:52:36
Message: <8E83FDBF4seed7@212.120.113.81>
Peter Popov wrote:
>//try this
>#declare Pos=array[11]
>#declare i=0;
>#while (i<11) #declare Pos[i]=<i,0,0>; #declare i=i+1; #end
>#declare i=1;
>#while (i<11)
>  #declare Pos[i]=vrotate((Pos[i]-Pos[i-1]),<0,0,10*clock>)+Pos[i-1];
>  #declare i=i+1;
>#end
No, I'm afraid that's not what I'm looking for. What I expected to see is
the spheres arranged in a arc, about one quarter of a circle.
mmm, all spheres end up on a circle, the length of the arcsegment between
two spheres is known (1 in this case). The angle between the two vectors
circle will always go through the origin, where the first sphere is.
With this, I think the radius and centerposition of the circle can be
calculated. Once this circle is known, take the distance frome any sphere
on the x-axis to the origin. Take an arcsegment of the circle with the same
length and put the sphere there.
Would it work? I'll sleep over this and try if I can figure it out
tomorrow.
Thanks Peter for your effort.
Ingo
Date: 19 Nov 1999 19:04:52
Message: <4OM1ONJO3=BUzyt4OW6oH853Ryf2@4ax.com>
>tomorrow.
>Ingo
I got your intentions wrong. This should do what you want, as
described in your original post.
#declare i=0;
#declare i=0;
#while (i<10)
  #declare j=i+1;
  #while (j<11)
    #declare Pos[i]=
    vrotate((Pos[j]-Pos[i]),<0,0,10*clock>)+Pos[i];
    #declare j=j+1;
  #declare i=i+1;
If it doesn't, I'll look at it tomorrow.
Peter Popov
ICQ: 15002700
Date: 19 Nov 1999 19:38:49
Message: <3835ED87.8C910B8E@xs4all.nl>
ingo wrote:
> >How much stress will that cause?
> >And you're not telling me that you've never had to stretch while
> moving
> >haven't you?
> >Anyway, it's probably bad physics for a robot, but it works (for me)
> in
> >an image.
> That's true, but it's like YKYHBRTLW You create a motor using every
> part
> ..... even the ones that don't show ..... just for authenticity.
> Ingo
> Photography: http://members.home.nl/ingoogni/
> Pov-Ray    : http://members.home.nl/seed7/
I was obviously missing the point.
I would suggest a recursive macro.
Remco
Date: 20 Nov 1999 04:13:41
Message: <8E8465C1Eseed7@212.120.113.81>
>#declare i=0;
>#declare i=0;
>#while (i<10)
>  #declare j=i+1;
>  #while (j<11)
>    #declare Pos[i]=
>    #declare j=j+1;
>  #end
>  #declare i=i+1;
>#end
Sorry but no, ten spheres end up at <10,0.9,0> and one at <10,0,0>.
Ingo
Date: 20 Nov 1999 07:21:18
Message: <38369190.12D9F64F@my-dejanews.com>
I think there is a more serious problem with the sin cos solution.
The sin cos solution prevents non unique positions along the x axis.  Many
kinds of aquatic animals, maybe some fish, would bend their bodies around so
much that there might be two points of the body at some given x.
Remco de Korte wrote:
> ingo wrote:
> > I'm trying to animate the tail of an ASCII-fish. I figured out how to
> > do it
> > the long way but I'm looking for a short cut.
> > Concider eleven spheres on a string from the origin to <10,0>.
> > around the current position of the second sphere.
> > 3. leave the first and second sphere in its position. rotate the whole
> > tenth
> > sphere.
> > Now, is there a direct way to calculate the position of a sphere,
> > without
> > going through the above loop. What will the position of sphere 7 be
> > when
> > Ingo
> I don't know if I understand your method exactly but I did a similar
> thing with a reasonable result using sin/cos-functions. This gives a
> nice curve. The position of each sphere is based on its place in the
> string _plus_ a clock value. This way the first sphere will move also.
> This is easy to avoid by moving the whole string relative to the
> translation of this first sphere. Sounds far more complicated then it
> actually is 8)
> Groeten!
> Remco
Date: 20 Nov 1999 07:43:44
Message: <8E8487412seed7@212.120.113.81>
>between two spheres is known (1 in this case)........
Got it, I think:
#declare i=0;
#while (i<11)
   #declare i=i+1;
#declare Angle   = radians(10*clock);
#declare Length  = Pos[1].x-Pos[0].x;
#declare Radius  = Length/Angle;
#declare Lcord   = (Radius/sin(0.5*pi-(Angle/2)))*sin(Angle);
#declare Ccenter = <-0.5*Lcord, Radius, 0>;
#declare i=0;
#while (i<11)
   #if (Pos[i].x=0)
      // do nothing
   #else
      #declare L= Pos[i].x;
      #declare Alpha= L/Radius;
      #declare Pos[i]=
(vrotate(<0,-radius,0>,<0,0,degrees(Alpha)>))+Ccenter;
   #declare i=i+1;
#declare i=0;
#while (i<11)
   sphere{ Pos[i],0.2 pigment {rgb <1,0,0>}}
   #declare i=i+1;
Ingo
Date: 20 Nov 1999 07:48:09
Message: <38369889@news.povray.org>
This just crashed my UVPOV during the creation of the bounding slabs. It
said something about Reallocing Finite to 33...
Date: 20 Nov 1999 08:04:52
Message: <8E84859B8seed7@212.120.113.81>
Ooops, posted it a bit too ethousiastic.
Add after the #declare Angle statement
#if (Angle !=0)
   and before the last #declare i=0
Also the x-coordinate value of Ccenter seems to be not ok yet.
Ingo
Date: 20 Nov 1999 08:52:48
Message: <3836A79B.6502BDE8@xs4all.nl>
> Many
> around so
I don't understand. This is just the thing that makes sin or cos a
reasonable choice, I thought.
I'm obviously missing something very important here. The only thing that
I have to support my choice is a working animation that does what it
should do for me, but, admittedly, is probably not what a hardcore
pov-er would consider realistic.
Remco
Date: 20 Nov 1999 09:27:18
Message: <8E849EBDBseed7@212.120.113.81>
>> Many
>> around so
>reasonable choice, I thought.......
For a simple fishtail you're right. But sometimes it's a sport doing thing
a certain way. Run a 60 frame animation of the below scene (~5 minutes), it
shows what Greg means.
#version 3.1;
global_settings {assumed_gamma 1.0}
light_source {
   < 500, 500,-500>
   rgb 1
   location  <4, 0, -10>
   look_at   <4, 0.0,0.0>
   angle 90
// generates number between min & max
// based on Value between 0, 1.
#macro Vmm(Min,Max,Value)
   (Min+((Max-Min)*Value))
#end //macro
#declare Pos=array[150]
#declare i=0;
#while (i<150)
   #declare Pos[i]=<i/10,0,0>;
   #declare i=i+1;
#declare Angle   = radians(Vmm(-4,4,clock));
#if (Angle !=0)
   #declare Ccenter = <0, Radius, 0>;
   #declare i=0;
   #while (i<150)
      #if (Pos[i].x=0)
         // do nothing
      #else
         #declare Pos[i]=
(vrotate(<0,-Radius,0>,<0,0,degrees(Alpha)>))+Ccenter;
      #declare i=i+1;
#declare i=0;
#while (i<150)
   sphere{ Pos[i],0.3 pigment {rgb <1,0,0>}}
   #declare i=i+1;
Ingo
